[PATCH] Add RTEMS 4.12 build set
Fri Nov 6 15:28:16 UTC 2015
I think Chris may want to change the way RSB deals with versions, so
hold off on committing until he can comment. I assume this is just cp
from 4.11 to 4.12 plus search-replace?
On Fri, Nov 6, 2015 at 10:21 AM, Sebastian Huber
>  rtems/config/4.12/rtems-all.bset                   | 17 ++++++++
>  rtems/config/4.12/rtems-arm.bset                   |  4 ++
>  rtems/config/4.12/rtems-autotools-base.bset        | 23 +++++++++++
>  rtems/config/4.12/rtems-autotools-internal.bset    | 13 ++++++
>  rtems/config/4.12/rtems-autotools.bset             | 22 ++++++++++
>  rtems/config/4.12/rtems-bfin.bset                  |  3 ++
>  rtems/config/4.12/rtems-default.bset               |  8 ++++
>  rtems/config/4.12/rtems-epiphany.bset              | 48 ++++++++++++++++++++++
>  rtems/config/4.12/rtems-i386.bset                  |  4 ++
>  rtems/config/4.12/rtems-lm32.bset                  |  3 ++
>  rtems/config/4.12/rtems-m32c.bset                  |  3 ++
>  rtems/config/4.12/rtems-m68k.bset                  |  3 ++
>  rtems/config/4.12/rtems-microblaze.bset            |  3 ++
>  rtems/config/4.12/rtems-mips.bset                  |  3 ++
>  rtems/config/4.12/rtems-moxie.bset                 |  3 ++
>  rtems/config/4.12/rtems-nios2.bset                 |  3 ++
>  rtems/config/4.12/rtems-or1k.bset                  | 43 +++++++++++++++++++
>  rtems/config/4.12/rtems-powerpc.bset               |  4 ++
>  rtems/config/4.12/rtems-sh.bset                    |  3 ++
>  rtems/config/4.12/rtems-sparc.bset                 |  4 ++
>  rtems/config/4.12/rtems-sparc64.bset               |  3 ++
>  rtems/config/4.12/rtems-v850.bset                  |  3 ++
>  rtems/config/rtems-4.12-base.bset                  |  7 ++++
>  ...tems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg | 16 ++++++++
>  rtems/config/tools/rtems-tools-4.12-1.cfg          |  1 +
>  source-builder/config/gcc-6-1.cfg                  | 31 ++++++++++++++
>  26 files changed, 278 insertions(+)
>  create mode 100644 rtems/config/4.12/rtems-all.bset
>  create mode 100644 rtems/config/4.12/rtems-arm.bset
>  create mode 100644 rtems/config/4.12/rtems-autotools-base.bset
>  create mode 100644 rtems/config/4.12/rtems-autotools-internal.bset
>  create mode 100644 rtems/config/4.12/rtems-autotools.bset
>  create mode 100644 rtems/config/4.12/rtems-bfin.bset
>  create mode 100644 rtems/config/4.12/rtems-default.bset
>  create mode 100644 rtems/config/4.12/rtems-epiphany.bset
>  create mode 100644 rtems/config/4.12/rtems-i386.bset
>  create mode 100644 rtems/config/4.12/rtems-lm32.bset
>  create mode 100644 rtems/config/4.12/rtems-m32c.bset
>  create mode 100644 rtems/config/4.12/rtems-m68k.bset
>  create mode 100644 rtems/config/4.12/rtems-microblaze.bset
>  create mode 100644 rtems/config/4.12/rtems-mips.bset
>  create mode 100644 rtems/config/4.12/rtems-moxie.bset
>  create mode 100644 rtems/config/4.12/rtems-nios2.bset
>  create mode 100644 rtems/config/4.12/rtems-or1k.bset
>  create mode 100644 rtems/config/4.12/rtems-powerpc.bset
>  create mode 100644 rtems/config/4.12/rtems-sh.bset
>  create mode 100644 rtems/config/4.12/rtems-sparc.bset
>  create mode 100644 rtems/config/4.12/rtems-sparc64.bset
>  create mode 100644 rtems/config/4.12/rtems-v850.bset
>  create mode 100644 rtems/config/rtems-4.12-base.bset
>  create mode 100644 rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
>  create mode 100644 rtems/config/tools/rtems-tools-4.12-1.cfg
>  create mode 100644 source-builder/config/gcc-6-1.cfg
> diff --git a/rtems/config/4.12/rtems-all.bset b/rtems/config/4.12/rtems-all.bset
> new file mode 100644
> index 0000000..bc0766f
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-all.bset
> @@ -0,0 +1,17 @@
> +4.12/rtems-arm
> +4.12/rtems-bfin
> +4.12/rtems-epiphany
> +4.12/rtems-i386
> +4.12/rtems-lm32
> +4.12/rtems-m32c
> +4.12/rtems-m68k
> +4.12/rtems-microblaze
> +4.12/rtems-mips
> +4.12/rtems-moxie
> +4.12/rtems-nios2
> +4.12/rtems-or1k
> +4.12/rtems-powerpc
> +4.12/rtems-sh
> +4.12/rtems-sparc
> +4.12/rtems-sparc64
> +4.12/rtems-v850
> diff --git a/rtems/config/4.12/rtems-arm.bset b/rtems/config/4.12/rtems-arm.bset
> index 0000000..ead6dda
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-arm.bset
> @@ -0,0 +1,4 @@
> +%define release 1
> +%define rtems_arch arm
> +%define with_libgomp
> +%include 4.12/rtems-default.bset
> diff --git a/rtems/config/4.12/rtems-autotools-base.bset b/rtems/config/4.12/rtems-autotools-base.bset
> index 0000000..f68df75
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-autotools-base.bset
> @@ -0,0 +1,23 @@
> +# Tools Set for RTEMS 4.12 Internal Autotools Stable
> +%define release 1
> +%define rtems_arch none
> +# The RTEMS 4.12 base defines.
> +%include rtems-4.12-base.bset
> +# The autotools package.
> +package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
> +# Tools configuration.
> +tools/rtems-autoconf-2.69-1
> +tools/rtems-automake-1.12.6-1
> diff --git a/rtems/config/4.12/rtems-autotools-internal.bset b/rtems/config/4.12/rtems-autotools-internal.bset
> index 0000000..772c032
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-autotools-internal.bset
> @@ -0,0 +1,13 @@
> +# Do not use via the command line.
> +%define _internal_autotools yes
> +%define _disable_collecting yes
> +%define _disable_packaging  yes
> +%define _disable_reporting  yes
> +%define _disable_installing yes
> +%include 4.12/rtems-autotools-base.bset
> diff --git a/rtems/config/4.12/rtems-autotools.bset b/rtems/config/4.12/rtems-autotools.bset
> index 0000000..ee80120
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-autotools.bset
> @@ -0,0 +1,22 @@
> +# Tools Set for RTEMS 4.12 Autotools Stable
> +# Autoconf and automake are not relocatable and cannot be cross-compiled.
> +# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
> +# bootstrapping and this requires a current autoconf and automake. The RSB
> +# provides to support by:
> +#  1. Building and installing autoconf and automake with a prefix to a
> +#     temporary internal path.
> +#  2. Using the temporary internal build, build and install another copy
> +#     using the final prefix location.
> +# A magic internal path that would break if changes in the defaults.mc
> +# macro file are made.
> +%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
> +4.12/rtems-autotools-internal
> +4.12/rtems-autotools-base
> diff --git a/rtems/config/4.12/rtems-bfin.bset b/rtems/config/4.12/rtems-bfin.bset
> index 0000000..bf4c9c5
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-bfin.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch bfin
> diff --git a/rtems/config/4.12/rtems-default.bset b/rtems/config/4.12/rtems-default.bset
> index 0000000..65909ef
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-default.bset
> @@ -0,0 +1,8 @@
> +devel/expat-2.1.0-1
> +tools/rtems-binutils-2.25-1
> +tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1
> +tools/rtems-gdb-7.9-1
> +tools/rtems-tools-4.12-1
> diff --git a/rtems/config/4.12/rtems-epiphany.bset b/rtems/config/4.12/rtems-epiphany.bset
> index 0000000..9192152
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-epiphany.bset
> @@ -0,0 +1,48 @@
> +# Tools Set for RTEMS Epiphany 4.12 Stable
> +%define release 1
> +%define rtems_arch epiphany
> +# Get GNU tools from external repositories.
> +%define binutils_external 1
> +%define gcc_external 1
> +%define gdb_external 1
> +# Expanded names of the GNU tools
> +%define binutils_expand_name epiphany-binutils-gdb-b6c483b4a98424731e6e44558cb4b9863751fb1b
> +%define gcc_expand_name epiphany-gcc-f7051762470c42ce7f01baa7edeb113d51c7dd72
> +%define gdb_expand_name epiphany-binutils-gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b
> +# Fetch GNU tools from external repos (temporarly).
> +%source set binutils https://github.com/adapteva/epiphany-binutils-gdb/archive/b6c483b4a98424731e6e44558cb4b9863751fb1b.zip
> +%hash md5 b6c483b4a98424731e6e44558cb4b9863751fb1b.zip 8fc71b965425a9b683489597048c49dc
> +%source set gcc https://github.com/adapteva/epiphany-gcc/archive/f7051762470c42ce7f01baa7edeb113d51c7dd72.zip
> +%hash md5 f7051762470c42ce7f01baa7edeb113d51c7dd72.zip c43c2e631418e932e2048607b694e99a
> +%source set gdb https://github.com/adapteva/epiphany-binutils-gdb/archive/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
> +%hash md5 f05996c7c42e6b2781946acbab153a481ce3fd0b.zip 05a4b208151a079bfbe2bed9c592ab43
> +tools/rtems-binutils-2.23.1-1
> +tools/rtems-gcc-4.9.2-newlib-git-1
> +tools/rtems-gdb-7.8.1-1
> diff --git a/rtems/config/4.12/rtems-i386.bset b/rtems/config/4.12/rtems-i386.bset
> index 0000000..c765249
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-i386.bset
> @@ -0,0 +1,4 @@
> +%define release 1
> +%define rtems_arch i386
> diff --git a/rtems/config/4.12/rtems-lm32.bset b/rtems/config/4.12/rtems-lm32.bset
> index 0000000..54850e3
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-lm32.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch lm32
> diff --git a/rtems/config/4.12/rtems-m32c.bset b/rtems/config/4.12/rtems-m32c.bset
> index 0000000..f6c3fe1
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-m32c.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch m32c
> diff --git a/rtems/config/4.12/rtems-m68k.bset b/rtems/config/4.12/rtems-m68k.bset
> index 0000000..c82a0ea
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-m68k.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch m68k
> diff --git a/rtems/config/4.12/rtems-microblaze.bset b/rtems/config/4.12/rtems-microblaze.bset
> index 0000000..a030a83
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-microblaze.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch microblaze
> diff --git a/rtems/config/4.12/rtems-mips.bset b/rtems/config/4.12/rtems-mips.bset
> index 0000000..2e00be8
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-mips.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch mips
> diff --git a/rtems/config/4.12/rtems-moxie.bset b/rtems/config/4.12/rtems-moxie.bset
> index 0000000..072ecae
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-moxie.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch moxie
> diff --git a/rtems/config/4.12/rtems-nios2.bset b/rtems/config/4.12/rtems-nios2.bset
> index 0000000..218d42f
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-nios2.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch nios2
> diff --git a/rtems/config/4.12/rtems-or1k.bset b/rtems/config/4.12/rtems-or1k.bset
> index 0000000..e1e4c34
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-or1k.bset
> @@ -0,0 +1,43 @@
> +# Tools Set for RTEMS or1k 4.12 Stable
> +%define release 1
> +%define rtems_arch or1k
> +# or1k specific patches
> +#gcc
> +%patch add gcc -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.3-or1k-rtems-29072014.diff
> +%hash  md5 gcc-4.8.3-or1k-rtems-29072014.diff 97be92fbe69a355625633a8d128fb5f5
> +#gdb
> +%patch add gdb -p1 https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> +%hash  md5 gdb-7.7-or1k-rtems.diff 7565167e02652ff300dd31015499633e
> +# or1k specific configurations
> +# Disable GDB simulator. Use the external simulator.
> +%define gdb-disable-sim 1
> +tools/rtems-gcc-4.8.3-newlib-git-1
> +tools/rtems-gdb-7.7-1
> diff --git a/rtems/config/4.12/rtems-powerpc.bset b/rtems/config/4.12/rtems-powerpc.bset
> index 0000000..1000cff
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-powerpc.bset
> @@ -0,0 +1,4 @@
> +%define release 1
> +%define rtems_arch powerpc
> diff --git a/rtems/config/4.12/rtems-sh.bset b/rtems/config/4.12/rtems-sh.bset
> index 0000000..87a581b
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-sh.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch sh
> diff --git a/rtems/config/4.12/rtems-sparc.bset b/rtems/config/4.12/rtems-sparc.bset
> index 0000000..4eaeee7
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-sparc.bset
> @@ -0,0 +1,4 @@
> +%define release 1
> +%define rtems_arch sparc
> diff --git a/rtems/config/4.12/rtems-sparc64.bset b/rtems/config/4.12/rtems-sparc64.bset
> index 0000000..a6ad478
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-sparc64.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch sparc64
> diff --git a/rtems/config/4.12/rtems-v850.bset b/rtems/config/4.12/rtems-v850.bset
> index 0000000..1f2a08e
> --- /dev/null
> +++ b/rtems/config/4.12/rtems-v850.bset
> @@ -0,0 +1,3 @@
> +%define release 1
> +%define rtems_arch v850
> diff --git a/rtems/config/rtems-4.12-base.bset b/rtems/config/rtems-4.12-base.bset
> index 0000000..fef8135
> --- /dev/null
> +++ b/rtems/config/rtems-4.12-base.bset
> @@ -0,0 +1,7 @@
> +# Base defines for RTEMS 4.12
> +%define rtems_version 4.12
> +%include rtems-base.bset
> diff --git a/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg b/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
> index 0000000..3f44d3f
> --- /dev/null
> +++ b/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
> @@ -0,0 +1,16 @@
> +%include %{_configdir}/checks.cfg
> +%include %{_configdir}/base.cfg
> +%define gcc_version    6-20151101
> +%define newlib_version 2.2.0.20151023
> +%define mpfr_version   2.4.2
> +%define mpc_version    0.8.1
> +%define gmp_version    4.3.2
> +%define with_threads 1
> +%define with_plugin  0
> +%define with_iconv   1
> +%source set gcc ftp://gcc.gnu.org/pub/gcc/snapshots/%{gcc_version}/gcc-%{gcc_version}.tar.bz2
> +%include %{_configdir}/gcc-6-1.cfg
> diff --git a/rtems/config/tools/rtems-tools-4.12-1.cfg b/rtems/config/tools/rtems-tools-4.12-1.cfg
> index 0000000..7b5eb7e
> --- /dev/null
> +++ b/rtems/config/tools/rtems-tools-4.12-1.cfg
> @@ -0,0 +1 @@
> +%include tools/rtems-tools-1.cfg
> diff --git a/source-builder/config/gcc-6-1.cfg b/source-builder/config/gcc-6-1.cfg
> index 0000000..9f75d6e
> --- /dev/null
> +++ b/source-builder/config/gcc-6-1.cfg
> @@ -0,0 +1,31 @@
> +# GCC 6 Version 1.
> +# This configuration file configure's, make's and install's gcc. It uses
> +# newlib, MPFR, MPC, and GMP in a one-tree build configuration.
> +# Source
> +# GCC core and G++
> +%source set gcc ftp://ftp.gnu.org/gnu/gcc/gcc-%{gcc_version}/gcc-%{gcc_version}.tar.bz2
> +# Newlib
> +%source set newlib ftp://sourceware.org/pub/newlib/newlib-%{newlib_version}.tar.gz
> +# Packages GCC requires
> +%source set mpfr http://www.mpfr.org/mpfr-%{mpfr_version}/mpfr-%{mpfr_version}.tar.bz2
> +%source set mpc http://www.multiprecision.org/mpc/download/mpc-%{mpc_version}.tar.gz
> +%source set gmp ftp://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
> +# GCC Common build script.
> +%include %{_configdir}/gcc-common-1.cfg
> 1.8.4.5
> devel mailing list
> devel at rtems.org
