BBB GPIO api interrupt handler problem
Gedare Bloom
gedare at rtems.org
Mon Nov 9 18:33:08 UTC 2015
is printk safe to use in the interrupt context? does it blow the stack?
On Mon, Nov 9, 2015 at 1:11 PM, Federico Garcia Cruz <
federico.garciacruz at tallertechnologies.com> wrote:
> Hi everyone,
> I'm using the GPIO api for the BBB but I'm having problems with the
> interrupt handling.
> I'm blinking two leds in the main thread and I have a GPIO input with an
> interrupt attached that uses printk to print a message. The problem is that
> the interrupt handler prints the message but never returns (main thread
> leds stop blinking after that).
> Any suggestion?
> Here's my code:
> rtems_gpio_irq_state gpio_handler(void* /*arg*/)
> printk("interrupt handler\n");
> return IRQ_HANDLED;
> void* POSIX_Init(void*)
> rtems_mode previous_mode_set;
> rtems_task_mode(RTEMS_TIMESLICE | RTEMS_PREEMPT, RTEMS_TIMESLICE_MASK
> | RTEMS_PREEMPT_MASK, &previous_mode_set);
> rtems_status_code sc = rtems_gpio_initialize();
> printk("%d\n", sc);
> sc = rtems_gpio_request_pin(BBB_LED_USR0, DIGITAL_OUTPUT, true, false,
> NULL);
> printk("DIGITAL_OUTPUT: %d\n", sc);
> sc = rtems_gpio_request_pin(BBB_LED_USR3, DIGITAL_OUTPUT, true, false,
> NULL);
> sc = rtems_gpio_request_pin(BBB_P8_7, DIGITAL_INPUT, false, false,
> NULL);
> printk("DIGITAL_INPUT: %d\n", sc);
> sc = rtems_gpio_enable_interrupt(BBB_P8_7, FALLING_EDGE,
> UNIQUE_HANDLER, false, gpio_handler, NULL);
> printk("interrupt install: %d\n", sc);
> while(1)
> sleep(1);
> rtems_gpio_clear(BBB_LED_USR3);
> rtems_gpio_set(BBB_LED_USR0);
> sleep(1);
> rtems_gpio_set(BBB_LED_USR3);
> rtems_gpio_clear(BBB_LED_USR0);
> return NULL;
> Thanks in advance!
> <http://www.tallertechnologies.com>
> Software Engineer
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone: +54 351 4217888 / +54 351 4218211
> <http://www.linkedin.com/company/taller-technologies>
> <https://www.facebook.com/tallertechnologies>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151109/9338b4ed/attachment-0001.html>
