waf: Post-process object file
Tue Nov 10 09:35:07 UTC 2015
Hello,
for the libbsd we have the problem that we expose a lot of symbols from
the FreeBSD kernel space to the applications. There are several known
conflicts, e.g. FreeBSD log() vs. standard math library log(). The
current approach to solve this issue is to generate a file with lots of
#define xx _bsd_xx
defines to rename at C pre-processor level. This is however quite
brittle and doesn't work in general. An alternative would be to
post-process the kernel-space object files with something like this
objcopy --redefine-syms redefines.txt x.o
with a redefines.txt
xx=_bsd_xx
My question is now: how can I add this post-processing step to the waf
based libbsd build system?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
