[PATCH] score: Fix race condition on SMP
Wed Nov 11 12:54:07 UTC 2015
We must ensure that the Thread_Control::Wait information update is
visible to the target thread before we update its wait flags, otherwise
we may return out of date events or a wrong status.
 cpukit/rtems/src/eventseize.c     |  6 +++++
 cpukit/rtems/src/eventsurrender.c | 55 +++++++++++++++++++++++----------------
 cpukit/score/src/threadtimeout.c  | 47 +++++++++++++++++++--------------
 3 files changed, 67 insertions(+), 41 deletions(-)
diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
index a9290b3..9c41b77 100644
--- a/cpukit/rtems/src/eventseize.c
+++ b/cpukit/rtems/src/eventseize.c
@@ -100,6 +100,12 @@ void _Event_Seize(
   _Thread_Set_state( executing, block_state );
+   * See _Event_Surrender() and _Thread_Timeout(), corresponding atomic
+   * variable is Thread_Control::Wait::flags.
+  _Atomic_Fence( ATOMIC_ORDER_ACQUIRE );
   success = _Thread_Wait_flags_try_change(
     executing,
     intend_to_block,
diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
index 1565860..6a14467 100644
--- a/cpukit/rtems/src/eventsurrender.c
+++ b/cpukit/rtems/src/eventsurrender.c
@@ -34,6 +34,20 @@ static void _Event_Satisfy(
   *(rtems_event_set *) the_thread->Wait.return_argument = seized_events;
+static bool _Event_Is_blocking_on_event(
+  const Thread_Control *the_thread,
+  Thread_Wait_flags     wait_class
+  Thread_Wait_flags wait_flags;
+  Thread_Wait_flags wait_mask;
+  wait_flags = _Thread_Wait_flags_get( the_thread );
+  wait_mask = THREAD_WAIT_CLASS_MASK | THREAD_WAIT_STATE_READY_AGAIN;
+  return ( wait_flags & wait_mask ) == wait_class;
 static bool _Event_Is_satisfied(
   rtems_event_set       pending_events,
@@ -59,46 +73,43 @@ void _Event_Surrender(
   ISR_lock_Context  *lock_context
-  rtems_event_set   pending_events;
-  rtems_event_set   seized_events;
-  Thread_Wait_flags wait_flags;
-  bool              unblock;
+  rtems_event_set pending_events;
+  rtems_event_set seized_events;
+  bool            unblock;
   _Thread_Lock_acquire_default_critical( the_thread, lock_context );
   _Event_sets_Post( event_in, &event->pending_events );
   pending_events = event->pending_events;
-  wait_flags = _Thread_Wait_flags_get( the_thread );
   if (
-    ( wait_flags & THREAD_WAIT_CLASS_MASK ) == wait_class
+    _Event_Is_blocking_on_event( the_thread, wait_class )
       && _Event_Is_satisfied( the_thread, pending_events, &seized_events )
-    Thread_Wait_flags intend_to_block;
-    Thread_Wait_flags blocked;
-    bool success;
+    Thread_Wait_flags ready_again;
+    bool              success;
+    _Event_Satisfy( the_thread, event, pending_events, seized_events );
-    intend_to_block = wait_class | THREAD_WAIT_STATE_INTEND_TO_BLOCK;
-    blocked = wait_class | THREAD_WAIT_STATE_BLOCKED;
+    /* See _Event_Seize() */
+    _Atomic_Fence( ATOMIC_ORDER_RELEASE );
+    ready_again = wait_class | THREAD_WAIT_STATE_READY_AGAIN;
     success = _Thread_Wait_flags_try_change_critical(
       the_thread,
-      intend_to_block,
-      wait_class | THREAD_WAIT_STATE_READY_AGAIN
+      wait_class | THREAD_WAIT_STATE_INTEND_TO_BLOCK,
+      ready_again
     if ( success ) {
-      _Event_Satisfy( the_thread, event, pending_events, seized_events );
       unblock = false;
-    } else if ( _Thread_Wait_flags_get( the_thread ) == blocked ) {
-      _Thread_Wait_flags_set(
-        the_thread,
+    } else {
+      _Assert(
+        _Thread_Wait_flags_get( the_thread )
+          == wait_class | THREAD_WAIT_STATE_BLOCKED
+      _Thread_Wait_flags_set( the_thread, ready_again );
       unblock = true;
-    } else {
-      unblock = false;
   } else {
     unblock = false;
diff --git a/cpukit/score/src/threadtimeout.c b/cpukit/score/src/threadtimeout.c
index 0e04998..45c2292 100644
--- a/cpukit/score/src/threadtimeout.c
+++ b/cpukit/score/src/threadtimeout.c
@@ -39,35 +39,44 @@ void _Thread_Timeout( Objects_Id id, void *arg )
   void              *thread_lock;
   ISR_lock_Context   lock_context;
-  Thread_Wait_flags  wait_class;
-  bool               success;
   bool               unblock;
   the_thread = arg;
   thread_lock = _Thread_Lock_acquire( the_thread, &lock_context );
-  wait_class = wait_flags & THREAD_WAIT_CLASS_MASK;
-  success = _Thread_Wait_flags_try_change_critical(
-    the_thread,
-    intend_to_block,
-  if ( success ) {
+  if ( ( wait_flags & THREAD_WAIT_STATE_READY_AGAIN ) == 0 ) {
+    Thread_Wait_flags wait_class;
+    bool              success;
     _Thread_Do_timeout( the_thread );
-    unblock = false;
+     * This fence is only necessary for the events, see _Event_Seize().  The
+     * thread queues use the thread lock for synchronization.
+    wait_class = wait_flags & THREAD_WAIT_CLASS_MASK;
+    success = _Thread_Wait_flags_try_change_critical(
       the_thread,
+      ready_again
-    _Thread_Do_timeout( the_thread );
-    unblock = true;
+    if ( success ) {
+      unblock = false;
+    } else {
+      _Assert(
+      unblock = true;
   } else {
     unblock = false;
1.8.4.5
