[PATCH 1/7] bsp/tms570: EMAC control header file corrected and EMAC interrupt vector added
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Nov 12 22:11:27 UTC 2015
Signed-off-by: Premysl Houdek <kom541000 at gmail.com>
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
 c/src/lib/libbsp/arm/tms570/Makefile.am            |   2 +-
 c/src/lib/libbsp/arm/tms570/include/irq.h          |   4 +
 .../libbsp/arm/tms570/include/ti_herc/reg_emac.h   | 230 -----------------
 .../libbsp/arm/tms570/include/ti_herc/reg_emacc.h  | 285 +++++++++++++++++++++
 c/src/lib/libbsp/arm/tms570/include/tms570.h       |   4 +-
 c/src/lib/libbsp/arm/tms570/preinstall.am          |   6 +-
 6 files changed, 295 insertions(+), 236 deletions(-)
 delete mode 100644 c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h
 create mode 100644 c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index b9c7fd4..a278aa2 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -50,7 +50,7 @@ include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_dcc.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_dma.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_dmm.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_efuse.h
-include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_emac.h
+include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_emacc.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_emacm.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_emif.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_esm.h
diff --git a/c/src/lib/libbsp/arm/tms570/include/irq.h b/c/src/lib/libbsp/arm/tms570/include/irq.h
index f35e7fe..2952582 100644
--- a/c/src/lib/libbsp/arm/tms570/include/irq.h
+++ b/c/src/lib/libbsp/arm/tms570/include/irq.h
@@ -103,6 +103,10 @@
 #define TMS570_IRQ_HET2_LEVEL_1 73
 #define TMS570_IRQ_SCI2_LEVEL_1 74
 #define TMS570_IRQ_HET_TU2_LEVEL_1 75
+#define TMS570_IRQ_EMAC_MISC 76
+#define TMS570_IRQ_EMAC_TX   77
+#define TMS570_IRQ_EMAC_THRESH 78
+#define TMS570_IRQ_EMAC_RX   79
 #define TMS570_IRQ_HWA_INT_REQ_H 80
 #define TMS570_IRQ_HWA_INT_REQ_H 81
 #define TMS570_IRQ_DCC_DONE_INTERRUPT 82
diff --git a/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h b/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h
deleted file mode 100644
index 31fe7ef..0000000
--- a/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h
+++ /dev/null
@@ -1,230 +0,0 @@
-/* The header file is generated by make_header.py from EMAC.json */
-/* Current script's version can be found at: */
-/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
- * Copyright (c) 2014-2015, Premysl Houdek <kom541000 at gmail.com>
- * Czech Technical University in Prague
- * Zikova 1903/4
- * 166 36 Praha 6
- * Czech Republic
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice, this
- *    list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- *    this list of conditions and the following disclaimer in the documentation
- *    and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
- * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
- * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
- * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
- * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
- * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * The views and conclusions contained in the software and documentation are those
- * of the authors and should not be interpreted as representing official policies,
- * either expressed or implied, of the FreeBSD Project.
-#ifndef LIBBSP_ARM_TMS570_EMAC
-#define LIBBSP_ARM_TMS570_EMAC
-#include <bsp/utility.h>
-typedef struct{
-  uint32_t REVID;             /*MDIO Revision ID Register*/
-  uint32_t CONTROL;           /*MDIO Control Register*/
-  uint32_t ALIVE;             /*PHY Alive Status register*/
-  uint32_t LINK;              /*PHY Link Status Register*/
-  uint32_t LINKINTRAW;        /*MDIO Link Status Change Interrupt (Unmasked) Register*/
-  uint32_t LINKINTMASKED;     /*MDIO Link Status Change Interrupt (Masked) Register*/
-  uint8_t reserved1 [8];
-  uint32_t USERINTRAW;        /*MDIO User Command Complete Interrupt (Unmasked) Register*/
-  uint32_t USERINTMASKED;     /*MDIO User Command Complete Interrupt (Masked) Register*/
-  uint32_t USERINTMASKSET;    /*MDIO User Command Complete Interrupt Mask Set Register*/
-  uint32_t USERINTMASKCLEAR;  /*MDIO User Command Complete Interrupt Mask Clear Register*/
-  uint8_t reserved2 [80];
-  uint32_t USERACCESS0;       /*MDIO User Access Register 0*/
-  uint32_t USERPHYSEL0;       /*MDIO User PHY Select Register 0*/
-  uint32_t USERACCESS1;       /*MDIO User Access Register 1*/
-  uint32_t USERPHYSEL1;       /*MDIO User PHY Select Register 1*/
-} tms570_emac_t;
-/*---------------------TMS570_EMAC_REVID---------------------*/
-/* field: REV - Identifies the MDIO Module revision. */
-/* Whole 32 bits */
-/*--------------------TMS570_EMAC_CONTROL--------------------*/
-/* field: IDLE - State machine IDLE status bit. */
-#define TMS570_EMAC_CONTROL_IDLE BSP_BIT32(31)
-/* field: ENABLE - State machine enable control bit. */
-#define TMS570_EMAC_CONTROL_ENABLE BSP_BIT32(30)
-/* field: HIGHEST_USER_CHANNEL - Highest user channel that is available in the module. It is currently set to 1. */
-#define TMS570_EMAC_CONTROL_HIGHEST_USER_CHANNEL(val) BSP_FLD32(val,24, 28)
-#define TMS570_EMAC_CONTROL_HIGHEST_USER_CHANNEL_GET(reg) BSP_FLD32GET(reg,24, 28)
-#define TMS570_EMAC_CONTROL_HIGHEST_USER_CHANNEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
-/* field: PREAMBLE - Preamble disable */
-#define TMS570_EMAC_CONTROL_PREAMBLE BSP_BIT32(20)
-/* field: FAULT - Fault indicator. */
-#define TMS570_EMAC_CONTROL_FAULT BSP_BIT32(19)
-/* field: FAULTENB - Fault detect enable. */
-#define TMS570_EMAC_CONTROL_FAULTENB BSP_BIT32(18)
-/* field: CLKDIV - Clock Divider bits. */
-#define TMS570_EMAC_CONTROL_CLKDIV(val) BSP_FLD32(val,0, 15)
-#define TMS570_EMAC_CONTROL_CLKDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
-#define TMS570_EMAC_CONTROL_CLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
-/*---------------------TMS570_EMAC_ALIVE---------------------*/
-/* field: ALIVE - MDIO Alive bits. */
-/*----------------------TMS570_EMAC_LINK----------------------*/
-/* field: LINK - MDIO Link state bits. This register is updated after a read of the generic status register of a PHY. */
-/*-------------------TMS570_EMAC_LINKINTRAW-------------------*/
-/* field: USERPHY1 - MDIO Link change event, raw value. */
-#define TMS570_EMAC_LINKINTRAW_USERPHY1 BSP_BIT32(1)
-/* field: USERPHY0 - MDIO Link change event, raw value. */
-#define TMS570_EMAC_LINKINTRAW_USERPHY0 BSP_BIT32(0)
-/*-----------------TMS570_EMAC_LINKINTMASKED-----------------*/
-/* field: USERPHY1 - MDIO Link change interrupt, masked value. */
-#define TMS570_EMAC_LINKINTMASKED_USERPHY1 BSP_BIT32(1)
-/* field: USERPHY0 - MDIO Link change interrupt, masked value. */
-#define TMS570_EMAC_LINKINTMASKED_USERPHY0 BSP_BIT32(0)
-/*-------------------TMS570_EMAC_USERINTRAW-------------------*/
-/* field: USERACCESS1 - MDIO User command complete event bit. */
-#define TMS570_EMAC_USERINTRAW_USERACCESS1 BSP_BIT32(1)
-/* field: USERACCESS0 - MDIO User command complete event bit. */
-#define TMS570_EMAC_USERINTRAW_USERACCESS0 BSP_BIT32(0)
-/*-----------------TMS570_EMAC_USERINTMASKED-----------------*/
-/* field: USERACCESS1 - Masked value of MDIO User command complete interrupt. */
-#define TMS570_EMAC_USERINTMASKED_USERACCESS1 BSP_BIT32(1)
-/* field: USERACCESS0 - Masked value of MDIO User command complete interrupt. */
-#define TMS570_EMAC_USERINTMASKED_USERACCESS0 BSP_BIT32(0)
-/*-----------------TMS570_EMAC_USERINTMASKSET-----------------*/
-/* field: USERACCESS1 - MDIO user interrupt mask set for USERINTMASKED[1]. */
-#define TMS570_EMAC_USERINTMASKSET_USERACCESS1 BSP_BIT32(1)
-/* field: USERACCESS0 - MDIO user interrupt mask set for USERINTMASKED[0]. */
-#define TMS570_EMAC_USERINTMASKSET_USERACCESS0 BSP_BIT32(0)
-/*----------------TMS570_EMAC_USERINTMASKCLEAR----------------*/
-/* field: USERACCESS1 - MDIO user command complete interrupt mask clear for USERINTMASKED[1]. */
-#define TMS570_EMAC_USERINTMASKCLEAR_USERACCESS1 BSP_BIT32(1)
-/* field: USERACCESS0 - MDIO user command complete interrupt mask clear for USERINTMASKED[0]. */
-#define TMS570_EMAC_USERINTMASKCLEAR_USERACCESS0 BSP_BIT32(0)
-/*------------------TMS570_EMAC_USERACCESS0------------------*/
-/* field: GO - Go bit. */
-#define TMS570_EMAC_USERACCESS0_GO BSP_BIT32(31)
-/* field: WRITE - Write enable bit. */
-#define TMS570_EMAC_USERACCESS0_WRITE BSP_BIT32(30)
-/* field: ACK - Acknowledge bit. This bit is set if the PHY acknowledged the read transaction. */
-#define TMS570_EMAC_USERACCESS0_ACK BSP_BIT32(29)
-/* field: REGADR - Register address bits. */
-#define TMS570_EMAC_USERACCESS0_REGADR(val) BSP_FLD32(val,21, 25)
-#define TMS570_EMAC_USERACCESS0_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
-#define TMS570_EMAC_USERACCESS0_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
-/* field: PHYADR - PHY address bits. This field specifies the PHY to be accessed for this transaction. */
-#define TMS570_EMAC_USERACCESS0_PHYADR(val) BSP_FLD32(val,16, 20)
-#define TMS570_EMAC_USERACCESS0_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
-#define TMS570_EMAC_USERACCESS0_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
-/* field: DATA - User data bits. */
-#define TMS570_EMAC_USERACCESS0_DATA(val) BSP_FLD32(val,0, 15)
-#define TMS570_EMAC_USERACCESS0_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
-#define TMS570_EMAC_USERACCESS0_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
-/*------------------TMS570_EMAC_USERPHYSEL0------------------*/
-/* field: LINKSEL - Link status determination select bit. */
-#define TMS570_EMAC_USERPHYSEL0_LINKSEL BSP_BIT32(7)
-/* field: LINKINTENB - Link change interrupt enable. */
-#define TMS570_EMAC_USERPHYSEL0_LINKINTENB BSP_BIT32(6)
-/* field: PHYADRMON - PHY address whose link status is to be monitored. */
-#define TMS570_EMAC_USERPHYSEL0_PHYADRMON(val) BSP_FLD32(val,0, 4)
-#define TMS570_EMAC_USERPHYSEL0_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
-#define TMS570_EMAC_USERPHYSEL0_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
-/*------------------TMS570_EMAC_USERACCESS1------------------*/
-#define TMS570_EMAC_USERACCESS1_GO BSP_BIT32(31)
-#define TMS570_EMAC_USERACCESS1_WRITE BSP_BIT32(30)
-#define TMS570_EMAC_USERACCESS1_ACK BSP_BIT32(29)
-#define TMS570_EMAC_USERACCESS1_REGADR(val) BSP_FLD32(val,21, 25)
-#define TMS570_EMAC_USERACCESS1_REGADR_GET(reg) BSP_FLD32GET(reg,21, 25)
-#define TMS570_EMAC_USERACCESS1_REGADR_SET(reg,val) BSP_FLD32SET(reg, val,21, 25)
-#define TMS570_EMAC_USERACCESS1_PHYADR(val) BSP_FLD32(val,16, 20)
-#define TMS570_EMAC_USERACCESS1_PHYADR_GET(reg) BSP_FLD32GET(reg,16, 20)
-#define TMS570_EMAC_USERACCESS1_PHYADR_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
-#define TMS570_EMAC_USERACCESS1_DATA(val) BSP_FLD32(val,0, 15)
-#define TMS570_EMAC_USERACCESS1_DATA_GET(reg) BSP_FLD32GET(reg,0, 15)
-#define TMS570_EMAC_USERACCESS1_DATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
-/*------------------TMS570_EMAC_USERPHYSEL1------------------*/
-#define TMS570_EMAC_USERPHYSEL1_LINKSEL BSP_BIT32(7)
-#define TMS570_EMAC_USERPHYSEL1_LINKINTENB BSP_BIT32(6)
-#define TMS570_EMAC_USERPHYSEL1_PHYADRMON(val) BSP_FLD32(val,0, 4)
-#define TMS570_EMAC_USERPHYSEL1_PHYADRMON_GET(reg) BSP_FLD32GET(reg,0, 4)
-#define TMS570_EMAC_USERPHYSEL1_PHYADRMON_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
-#endif /* LIBBSP_ARM_TMS570_EMAC */
diff --git a/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h b/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h
new file mode 100644
index 0000000..c7c564c
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h
@@ -0,0 +1,285 @@
+/* The header file is generated by make_header.py from EMACC.json */
+/* Current script's version can be found at: */
+/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
+ * Copyright (c) 2014-2015, Premysl Houdek <kom541000 at gmail.com>
+ * Czech Technical University in Prague
+ * Zikova 1903/4
+ * 166 36 Praha 6
+ * Czech Republic
+ * All rights reserved.
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice, this
+ *    list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ *    this list of conditions and the following disclaimer in the documentation
+ *    and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * The views and conclusions contained in the software and documentation are those
+ * of the authors and should not be interpreted as representing official policies,
+ * either expressed or implied, of the FreeBSD Project.
+#ifndef LIBBSP_ARM_TMS570_EMACC
+#define LIBBSP_ARM_TMS570_EMACC
+#include <bsp/utility.h>
+typedef struct{
+  uint32_t REVID;             /*EMAC Control Module Revision ID Register*/
+  uint32_t SOFTRESET;         /*EMAC Control Module Software Reset Register*/
+  uint8_t reserved1 [4];
+  uint32_t INTCONTROL;        /*EMAC Control Module Interrupt Control Register*/
+  uint32_t C0RXTHRESHEN;      /*EMAC Control Module Receive Threshold Interrupt Enable Register*/
+  uint32_t C0RXEN;            /*EMAC Control Module Receive Interrupt Enable Register*/
+  uint32_t C0TXEN;            /*EMAC Control Module Transmit Interrupt Enable Register*/
+  uint32_t C0MISCEN;          /*EMAC Control Module Miscellaneous Interrupt Enable Register*/
+  uint8_t reserved2 [32];
+  uint32_t C0RXTHRESHSTAT;    /*EMAC Control Module Receive Threshold Interrupt Status Register*/
+  uint32_t C0RXSTAT;          /*EMAC Control Module Receive Interrupt Status Register*/
+  uint32_t C0TXSTAT;          /*EMAC Control Module Transmit Interrupt Status Register*/
+  uint32_t C0MISCSTAT;        /*EMAC Control Module Miscellaneous Interrupt Status Register*/
+  uint8_t reserved3 [32];
+  uint32_t C0RXIMAX;          /*EMAC Control Module Receive Interrupts Per Millisecond Register*/
+  uint32_t C0TXIMAX;          /*EMAC Control Module Transmit Interrupts Per Millisecond Register*/
+} tms570_emacc_t;
+/*---------------------TMS570_EMACC_REVID---------------------*/
+/* field: REV - Identifies the EMAC Control Module revision. */
+/* Whole 32 bits */
+/*-------------------TMS570_EMACC_SOFTRESET-------------------*/
+/* field: RESET - Software reset bit for the EMAC Control Module. */
+#define TMS570_EMACC_SOFTRESET_RESET BSP_BIT32(0)
+/*------------------TMS570_EMACC_INTCONTROL------------------*/
+/* field: C0TXPACEEN - Enable pacing for TX interrupt pulse generation */
+#define TMS570_EMACC_INTCONTROL_C0TXPACEEN BSP_BIT32(17)
+/* field: C0RXPACEEN - Enable pacing for RX interrupt pulse generation */
+#define TMS570_EMACC_INTCONTROL_C0RXPACEEN BSP_BIT32(16)
+/* field: INTPRESCALE - Number of internal EMAC module reference clock periods within a 4 us time window (see */
+#define TMS570_EMACC_INTCONTROL_INTPRESCALE(val) BSP_FLD32(val,0, 11)
+#define TMS570_EMACC_INTCONTROL_INTPRESCALE_GET(reg) BSP_FLD32GET(reg,0, 11)
+#define TMS570_EMACC_INTCONTROL_INTPRESCALE_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
+/*-----------------TMS570_EMACC_C0RXTHRESHEN-----------------*/
+/* field: RXCH7THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 7 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH7THRESHEN BSP_BIT32(7)
+/* field: RXCH6THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 6 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH6THRESHEN BSP_BIT32(6)
+/* field: RXCH5THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 5 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH5THRESHEN BSP_BIT32(5)
+/* field: RXCH4THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 4 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH4THRESHEN BSP_BIT32(4)
+/* field: RXCH3THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 3 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH3THRESHEN BSP_BIT32(3)
+/* field: RXCH2THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 2 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH2THRESHEN BSP_BIT32(2)
+/* field: RXCH1THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 1 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH1THRESHEN BSP_BIT32(1)
+/* field: RXCH0THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 0 */
+#define TMS570_EMACC_C0RXTHRESHEN_RXCH0THRESHEN BSP_BIT32(0)
+/*--------------------TMS570_EMACC_C0RXEN--------------------*/
+/* field: RXCH7EN - Enable C0RXPULSE interrupt generation for RX Channel 7 */
+#define TMS570_EMACC_C0RXEN_RXCH7EN BSP_BIT32(7)
+/* field: RXCH6EN - Enable C0RXPULSE interrupt generation for RX Channel 6 */
+#define TMS570_EMACC_C0RXEN_RXCH6EN BSP_BIT32(6)
+/* field: RXCH5EN - Enable C0RXPULSE interrupt generation for RX Channel 5 */
+#define TMS570_EMACC_C0RXEN_RXCH5EN BSP_BIT32(5)
+/* field: RXCH4EN - Enable C0RXPULSE interrupt generation for RX Channel 4 */
+#define TMS570_EMACC_C0RXEN_RXCH4EN BSP_BIT32(4)
+/* field: RXCH3EN - Enable C0RXPULSE interrupt generation for RX Channel 3 */
+#define TMS570_EMACC_C0RXEN_RXCH3EN BSP_BIT32(3)
+/* field: RXCH2EN - Enable C0RXPULSE interrupt generation for RX Channel 2 */
+#define TMS570_EMACC_C0RXEN_RXCH2EN BSP_BIT32(2)
+/* field: RXCH1EN - Enable C0RXPULSE interrupt generation for RX Channel 1 */
+#define TMS570_EMACC_C0RXEN_RXCH1EN BSP_BIT32(1)
+/* field: RXCH0EN - Enable C0RXPULSE interrupt generation for RX Channel 0 */
+#define TMS570_EMACC_C0RXEN_RXCH0EN BSP_BIT32(0)
+/*--------------------TMS570_EMACC_C0TXEN--------------------*/
+/* field: TXCH7EN - Enable C0TXPULSE interrupt generation for TX Channel 7 */
+#define TMS570_EMACC_C0TXEN_TXCH7EN BSP_BIT32(7)
+/* field: TXCH6EN - TXCH6EN */
+#define TMS570_EMACC_C0TXEN_TXCH6EN BSP_BIT32(6)
+/* field: TXCH5EN - Enable C0TXPULSE interrupt generation for TX Channel 5 */
+#define TMS570_EMACC_C0TXEN_TXCH5EN BSP_BIT32(5)
+/* field: TXCH4EN - Enable C0TXPULSE interrupt generation for TX Channel 4 */
+#define TMS570_EMACC_C0TXEN_TXCH4EN BSP_BIT32(4)
+/* field: TXCH3EN - Enable C0TXPULSE interrupt generation for TX Channel 3 */
+#define TMS570_EMACC_C0TXEN_TXCH3EN BSP_BIT32(3)
+/* field: TXCH2EN - Enable C0TXPULSE interrupt generation for TX Channel 2 */
+#define TMS570_EMACC_C0TXEN_TXCH2EN BSP_BIT32(2)
+/* field: TXCH1EN - Enable C0TXPULSE interrupt generation for TX Channel 1 */
+#define TMS570_EMACC_C0TXEN_TXCH1EN BSP_BIT32(1)
+/* field: TXCH0EN - Enable C0TXPULSE interrupt generation for TX Channel 0 */
+#define TMS570_EMACC_C0TXEN_TXCH0EN BSP_BIT32(0)
+/*-------------------TMS570_EMACC_C0MISCEN-------------------*/
+/* field: STATPENDEN - Enable C0MISCPULSE interrupt generation when EMAC statistics interrupts are generated */
+#define TMS570_EMACC_C0MISCEN_STATPENDEN BSP_BIT32(3)
+/* field: HOSTPENDEN - HOSTPENDEN */
+#define TMS570_EMACC_C0MISCEN_HOSTPENDEN BSP_BIT32(2)
+/* field: LINKINT0EN - Enable C0MISCPULSE interrupt generation when MDIO LINKINT0 interrupts (corresponding to */
+#define TMS570_EMACC_C0MISCEN_LINKINT0EN BSP_BIT32(1)
+/* field: USERINT0EN - Enable C0MISCPULSE interrupt generation when MDIO USERINT0 interrupts (corresponding */
+#define TMS570_EMACC_C0MISCEN_USERINT0EN BSP_BIT32(0)
+/*----------------TMS570_EMACC_C0RXTHRESHSTAT----------------*/
+/* field: RXCH7THRESHSTAT - Interrupt status for RX Channel 7 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH7THRESHSTAT BSP_BIT32(7)
+/* field: RXCH6THRESHSTAT - Interrupt status for RX Channel 6 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH6THRESHSTAT BSP_BIT32(6)
+/* field: RXCH5THRESHSTAT - Interrupt status for RX Channel 5 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH5THRESHSTAT BSP_BIT32(5)
+/* field: RXCH4THRESHSTAT - Interrupt status for RX Channel 4 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH4THRESHSTAT BSP_BIT32(4)
+/* field: RXCH3THRESHSTAT - Interrupt status for RX Channel 3 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH3THRESHSTAT BSP_BIT32(3)
+/* field: RXCH2THRESHSTAT - Interrupt status for RX Channel 2 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH2THRESHSTAT BSP_BIT32(2)
+/* field: RXCH1THRESHSTAT - Interrupt status for RX Channel 1 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH1THRESHSTAT BSP_BIT32(1)
+/* field: RXCH0THRESHSTAT - Interrupt status for RX Channel 0 masked by the C0RXTHRESHEN register */
+#define TMS570_EMACC_C0RXTHRESHSTAT_RXCH0THRESHSTAT BSP_BIT32(0)
+/*-------------------TMS570_EMACC_C0RXSTAT-------------------*/
+/* field: RXCH7STAT - RXCH7STAT */
+#define TMS570_EMACC_C0RXSTAT_RXCH7STAT BSP_BIT32(7)
+/* field: RXCH6STAT - Interrupt status for RX Channel 6 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH6STAT BSP_BIT32(6)
+/* field: RXCH5STAT - Interrupt status for RX Channel 5 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH5STAT BSP_BIT32(5)
+/* field: RXCH4STAT - Interrupt status for RX Channel 4 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH4STAT BSP_BIT32(4)
+/* field: RXCH3STAT - Interrupt status for RX Channel 3 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH3STAT BSP_BIT32(3)
+/* field: RXCH2STAT - H2STAT Interrupt status for RX Channel 2 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH2STAT BSP_BIT32(2)
+/* field: RXCH1STAT - Interrupt status for RX Channel 1 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH1STAT BSP_BIT32(1)
+/* field: RXCH0STAT - Interrupt status for RX Channel 0 masked by the C0RXEN register */
+#define TMS570_EMACC_C0RXSTAT_RXCH0STAT BSP_BIT32(0)
+/*-------------------TMS570_EMACC_C0TXSTAT-------------------*/
+/* field: TXCH7STAT - Interrupt status for TX Channel 7 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH7STAT BSP_BIT32(7)
+/* field: TXCH6STAT - TXCH6STAT */
+#define TMS570_EMACC_C0TXSTAT_TXCH6STAT BSP_BIT32(6)
+/* field: TXCH5STAT - Interrupt status for TX Channel 5 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH5STAT BSP_BIT32(5)
+/* field: TXCH4STAT - Interrupt status for TX Channel 4 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH4STAT BSP_BIT32(4)
+/* field: TXCH3STAT - Interrupt status for TX Channel 3 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH3STAT BSP_BIT32(3)
+/* field: TXCH2STAT - Interrupt status for TX Channel 2 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH2STAT BSP_BIT32(2)
+/* field: TXCH1STAT - Interrupt status for TX Channel 1 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH1STAT BSP_BIT32(1)
+/* field: TXCH0STAT - Interrupt status for TX Channel 0 masked by the C0TXEN register */
+#define TMS570_EMACC_C0TXSTAT_TXCH0STAT BSP_BIT32(0)
+/*------------------TMS570_EMACC_C0MISCSTAT------------------*/
+/* field: STATPENDSTAT - Interrupt status for EMAC STATPEND masked by the C0MISCEN register */
+#define TMS570_EMACC_C0MISCSTAT_STATPENDSTAT BSP_BIT32(3)
+/* field: HOSTPENDSTAT - Interrupt status for EMAC HOSTPEND masked by the C0MISCEN register */
+#define TMS570_EMACC_C0MISCSTAT_HOSTPENDSTAT BSP_BIT32(2)
+/* field: LINKINT0STAT - Interrupt status for MDIO LINKINT0 masked by the C0MISCEN register */
+#define TMS570_EMACC_C0MISCSTAT_LINKINT0STAT BSP_BIT32(1)
+/* field: USERINT0STAT - Interrupt status for MDIO USERINT0 masked by the C0MISCEN register */
+#define TMS570_EMACC_C0MISCSTAT_USERINT0STAT BSP_BIT32(0)
+/*-------------------TMS570_EMACC_C0RXIMAX-------------------*/
+/* field: RXIMAX - RXIMAX is the desired number of C0RXPULSE interrupts generated per millisecond when */
+#define TMS570_EMACC_C0RXIMAX_RXIMAX(val) BSP_FLD32(val,0, 5)
+#define TMS570_EMACC_C0RXIMAX_RXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
+#define TMS570_EMACC_C0RXIMAX_RXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
+/*-------------------TMS570_EMACC_C0TXIMAX-------------------*/
+/* field: TXIMAX - TXIMAX is the desired number of C0TXPULSE interrupts generated per millisecond when */
+#define TMS570_EMACC_C0TXIMAX_TXIMAX(val) BSP_FLD32(val,0, 5)
+#define TMS570_EMACC_C0TXIMAX_TXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
+#define TMS570_EMACC_C0TXIMAX_TXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
+#endif /* LIBBSP_ARM_TMS570_EMACC */
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570.h b/c/src/lib/libbsp/arm/tms570/include/tms570.h
index 3280950..439387e 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570.h
@@ -46,7 +46,7 @@
 #include <bsp/ti_herc/reg_dma.h>
 #include <bsp/ti_herc/reg_dmm.h>
 #include <bsp/ti_herc/reg_efuse.h>
-#include <bsp/ti_herc/reg_emac.h>
+#include <bsp/ti_herc/reg_emacc.h>
 #include <bsp/ti_herc/reg_emacm.h>
 #include <bsp/ti_herc/reg_emif.h>
 #include <bsp/ti_herc/reg_esm.h>
@@ -87,7 +87,7 @@
 #define TMS570_DMA (*(volatile tms570_dma_t*)0xFFFFF000)
 #define TMS570_DMM (*(volatile tms570_dmm_t*)0xFFFFF700)
 #define TMS570_EFUSE (*(volatile tms570_efuse_t*)0XFFF8C01C)
-#define TMS570_EMAC (*(volatile tms570_emac_t*)0xFCF78900)
+#define TMS570_EMACC (*(volatile tms570_emacc_t*)0xFCF78800)
 #define TMS570_EMACM (*(volatile tms570_emacm_t*)0xFCF78000)
 #define TMS570_EMIF (*(volatile tms570_emif_t*)0xFCFFE800)
 #define TMS570_ESM (*(volatile tms570_esm_t*)0XFFFFF500)
diff --git a/c/src/lib/libbsp/arm/tms570/preinstall.am b/c/src/lib/libbsp/arm/tms570/preinstall.am
index 54d90a0..c6408cb 100644
--- a/c/src/lib/libbsp/arm/tms570/preinstall.am
+++ b/c/src/lib/libbsp/arm/tms570/preinstall.am
@@ -146,9 +146,9 @@ $(PROJECT_INCLUDE)/bsp/ti_herc/reg_efuse.h: include/ti_herc/reg_efuse.h $(PROJEC
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/ti_herc/reg_efuse.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/ti_herc/reg_efuse.h
-$(PROJECT_INCLUDE)/bsp/ti_herc/reg_emac.h: include/ti_herc/reg_emac.h $(PROJECT_INCLUDE)/bsp/ti_herc/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emac.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emac.h
+$(PROJECT_INCLUDE)/bsp/ti_herc/reg_emacc.h: include/ti_herc/reg_emacc.h $(PROJECT_INCLUDE)/bsp/ti_herc/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emacc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emacc.h
 $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emacm.h: include/ti_herc/reg_emacm.h $(PROJECT_INCLUDE)/bsp/ti_herc/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/ti_herc/reg_emacm.h
1.9.1
