[PATCH 4/7] bsp/tms570: updated reserved space for vector overlay in internal RAM
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Nov 12 22:11:30 UTC 2015
 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk        | 3 ++-
 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram | 4 ++--
 c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram  | 3 ++-
 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
index 5ecd4ed..0cdc783 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
@@ -1,7 +1,8 @@
 MEMORY {
 	ROM_INT (RX)  : ORIGIN = 0x00000000, LENGTH = 3M
-	RAM_INT (AIW) : ORIGIN = 0x08000000, LENGTH = 256k
+	RAM_INT_VEC :    ORIGIN = 0x08000000, LENGTH = 256
+	RAM_INT (AIWX) : ORIGIN = 0x08000100, LENGTH = 256k - 256
 	RAM_EXT (AIWX) : ORIGIN = 0x80000000, LENGTH = 8M
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
index dd40fe2..c33dd6c 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
@@ -1,8 +1,8 @@
 MEMORY {
-	RAM_INT_VEC :    ORIGIN = 0x08000000, LENGTH = 1k
-	RAM_INT (AIWX) : ORIGIN = 0x08000400, LENGTH = 256k - 1k
 	RAM_EXT (AIW) :  ORIGIN = 0x80000000, LENGTH = 8M
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
index cb628c6..17039f1 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
@@ -1,7 +1,8 @@
 MEMORY {
1.9.1
