[PATCH 5/7] bsp/tms570: use POM only when application image does not start at address 0.
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Nov 12 22:11:31 UTC 2015
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
  https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
Signed-off-by: Premysl Houdek <kom541000 at gmail.com>
 c/src/lib/libbsp/arm/tms570/include/tms570-pom.h   |  3 +-
 c/src/lib/libbsp/arm/tms570/irq/irq.c              | 23 +++++
 c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c       | 99 ++++++++++++++++++++--
 c/src/lib/libbsp/arm/tms570/startup/bspstart.c     | 42 ++++++++-
 .../arm/tms570/startup/linkcmds.tms570ls3137_hdk   |  2 +
 .../startup/linkcmds.tms570ls3137_hdk_intram       |  2 +
 .../tms570/startup/linkcmds.tms570ls3137_hdk_sdram |  2 +
 7 files changed, 159 insertions(+), 14 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h b/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
index 215d608..2c54a01 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570-pom.h
@@ -48,8 +48,7 @@ extern "C" {
 #define TMS570_POM_REGADDRMASK    ((1<<23)-1)
-int mem_dump(void *buf, unsigned long start, unsigned long len, int blen);
+void tms570_initialize_and_clear(void);
 void tms570_pom_remap(void);
diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c b/c/src/lib/libbsp/arm/tms570/irq/irq.c
index 2e6e3db..7a2a55f 100644
--- a/c/src/lib/libbsp/arm/tms570/irq/irq.c
+++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
@@ -201,6 +201,29 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
    * can be provided by VIM hardware
   sctlr &= ~(1 << 24);
+  #if 0
+     * Option to enable exception table bypass for interrupts
+     * Because RTEMS requires all interrupts to be serviced through
+     * common _ARMV4_Exception_interrupt handler to allow task switching
+     * on exit from interrupt working correctly, vim_vec cannot point
+     * directly to individual vector handlers and need to point
+     * to single entry path. But if TMS570_VIM.IRQINDEX is then used
+     * to target execution to corresponding service then for some
+     * peripherals (i.e. EMAC) interrupt is already acknowledged
+     * by VIM and IRQINDEX is read as zero which leads to spurious
+     * interrupt and peripheral not serviced/blocked.
+     * To analyze this behavior we used trampolines which setup
+     * bsp_interrupt_vector_inject and pass execution to
+     * _ARMV4_Exception_interrupt. It works but is more ugly than
+     * use of POM remap for these cases where application does not
+     * start at address 0x00000000. If RTEMS image is placed at
+     * memory space beginning then no of these constructs is necessary.
+    sctlr |= 1 << 24;
+  #endif
   asm volatile ("mcr p15, 0, %0, c1, c0, 0\n": : "r" (sctlr));
   return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
index 749dd9d..6de64fe 100644
--- a/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
+++ b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
@@ -22,8 +22,61 @@
 #include <stdint.h>
 #include <bsp/tms570-pom.h>
 #include <bsp/linker-symbols.h>
+#include <rtems/score/armv4.h>
 #include <bsp.h>
+ * Placement of exceptions target addresses in memory
+ * when insructions with opcode 0xe59ff018
+ *      ldr pc, [pc, #0x18]
+ * are used to fill ARM exception vectors area
+typedef struct{
+  uint32_t reserved1;
+  uint32_t except_addr_undef;
+  uint32_t except_addr_swi;
+  uint32_t except_addr_prefetch;
+  uint32_t except_addr_abort;
+  uint32_t reserved2;
+  uint32_t except_addr_irq;
+  uint32_t except_addr_fiq;
+}vec_remap_table;
+void bsp_block_on_exception(void);
+void bsp_block_on_exception(void){
+  while(1);
+extern char bsp_int_vec_overlay_start[];
+ * Global overlay target address holds shared MSB bits for all regions
+ * It is set to linker RAM_INT_VEC region - i.e. area reserved
+ * at internal SRAM memory start, address 0x08000000
+uint32_t pom_global_overlay_target_address_start =
+                                 (uintptr_t)bsp_int_vec_overlay_start;
+ * @brief initialize and clear parameters overlay module (POM)
+ * clears all remap regions. The actual POM enable is left to the first user.
+ * @retval Void
+  int i;
+  TMS570_POM.GLBCTRL = 0 | (TMS570_POM_GLBCTRL_OTADDR(~0) &
+                            pom_global_overlay_target_address_start);
+  for ( i = 0; i < TMS570_POM_REGIONS; ++i ) {
+    TMS570_POM.REG[i].REGSIZE = TMS570_POM_REGSIZE_SIZE(TMS570_POM_REGSIZE_DISABLED);
  * @brief remaps vector table
@@ -33,22 +86,50 @@
-  int i;
-  uint32_t vec_overlay_start = 0x08000000;
-  uint32_t temp = 0;
+  uint32_t vec_overlay_start = pom_global_overlay_target_address_start;
+   * Copy RTEMS the first level exception processing code
+   * to RAM area which can be used for later as POM overlay
+   * of Flash vectors. The code is expected to have for of eight
+   *   ldr pc, [pc,#0x18]
+   * instructions followed by eight words with actual exception
+   * service routines target addresses. This is case of RTEMS default
+   * table found in
+   *   c/src/lib/libbsp/arm/shared/start/start.S
   memcpy((void*)vec_overlay_start, bsp_start_vector_table_begin, 64);
-  TMS570_POM.GLBCTRL = 0;
-  for ( i = 0; i < TMS570_POM_REGIONS; ++i ) {
-    TMS570_POM.REG[i].REGSIZE = TMS570_POM_REGSIZE_SIZE(TMS570_POM_REGSIZE_DISABLED);
+  #if 0
+    /* Fill exception table by catch error infinite loop for debugging */
+    vec_remap_table* vec_table = (vec_remap_table*)(vec_overlay_start+32);
+    vec_table->except_addr_undef = (uint32_t)bsp_block_on_exception;
+    vec_table->except_addr_swi = (uint32_t)bsp_block_on_exception;
+    vec_table->except_addr_prefetch = (uint32_t)bsp_block_on_exception;//_ARMV4_Exception_prefetch_abort;
+    vec_table->except_addr_abort = (uint32_t)bsp_block_on_exception;//_ARMV4_Exception_data_abort;
+    vec_table->except_addr_irq = (uint32_t)_ARMV4_Exception_interrupt;
+    vec_table->except_addr_fiq = (uint32_t)bsp_block_on_exception;//_ARMV4_Exception_interrupt;
+  #endif
-  TMS570_POM.REG[0].PROGSTART = TMS570_POM_PROGSTART_STARTADDRESS(0);
+   * The overlay vectors replacement area cannot be used directly
+   * to replace jump instructions on start of Flash because instruction
+   * fetch through POM is not reliable supported (works in most times
+   * but sometimes fails).
+   * Area of 64 bytes starting at address 0x00000040 is replaced.
+   * This way target addresses are placed between 0x00000060
+   * and 0x0000007F. If boot loader startup code contains instructions
+   *   ldr pc,[pc,#0x58]
+   * (opcode 0xe59ff058) then the jump target addresses are replaced
+   * by pointers to actual RTEMS exceptions service functions.
+  TMS570_POM.REG[0].PROGSTART = TMS570_POM_PROGSTART_STARTADDRESS(64);
   TMS570_POM.REG[0].OVLSTART = TMS570_POM_OVLSTART_STARTADDRESS(vec_overlay_start);
   TMS570_POM.REG[0].REGSIZE = TMS570_POM_REGSIZE_SIZE(TMS570_POM_REGSIZE_64B);
   TMS570_POM.GLBCTRL = TMS570_POM_GLBCTRL_ON_OFF(0xa) |
                        TMS570_POM_GLBCTRL_ETO(0xa) |
-                       (TMS570_POM_GLBCTRL_OTADDR(~0) & vec_overlay_start);
+                       (TMS570_POM_GLBCTRL_OTADDR(~0) &
diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspstart.c b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
index 31ad1e7..b7e2b62 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/tms570/startup/bspstart.c
@@ -27,13 +27,49 @@
 #include <bsp/irq-generic.h>
 #include <bsp/start.h>
 #include <bsp/bootcard.h>
+#include <bsp/linker-symbols.h>
+#include <rtems/endian.h>
 void bsp_start( void )
-  /* set the cpu mode to supervisor and big endian */
-  arm_cpu_mode = 0x213;
+  #if BYTE_ORDER == BIG_ENDIAN
+     * If CPU is big endian (TMS570 family variant)
+     * set the CPU mode to supervisor and big endian.
+     * Do not set mode if CPU is little endian
+     * (RM48 family variant) for which default mode 0x13
+     * defined in cpukit/score/cpu/arm/cpu.c
+     * is right.
+    arm_cpu_mode = 0x213;
+  #endif
-  tms570_pom_remap();
+  tms570_initialize_and_clear();
+   * If RTEMS image does not start at address 0x00000000
+   * then first level exception table at memory begin has
+   * to be replaced to point to RTEMS handlers addresses.
+   * There is no VBAR or other option because Cortex-R
+   * does provides only fixed address 0x00000000 for exceptions
+   * (0xFFFF0000-0xFFFF001C alternative SCTLR.V = 1 cannot
+   * be used because target area corersponds to PMM peripheral
+   * registers on TMS570).
+   * Alternative is to use jumps over SRAM based trampolines
+   * but that is not compatible with
+   *   Check TCRAM1 ECC error detection logic
+   * which intentionally introduces data abort during startup
+   * to check SRAM and if exception processing goes through
+   * SRAM then it leads to CPU error halt.
+   * So use of POM to replace jumps to vectors target
+   * addresses seems to be the best option.
+  if ( (uintptr_t)bsp_start_vector_table_begin != 0 ) {
+    tms570_pom_remap();
   /* Interrupts */
   bsp_interrupt_initialize();
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
index 0cdc783..a32562f 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk
@@ -27,4 +27,6 @@ REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM_INT);
 bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 1024;
 bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
+bsp_int_vec_overlay_start = ORIGIN(RAM_INT_VEC);
 INCLUDE linkcmds.armv4
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
index c33dd6c..7cb683d 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram
diff --git a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
index 17039f1..0117410 100644
--- a/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
+++ b/c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram
@@ -27,4 +27,6 @@ REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM_EXT);
1.9.1
