[PATCH 7/7] bsp/tms570: use common tms570ls3137.inc file for all board ling variants.
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Nov 12 22:11:33 UTC 2015
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
 .../libbsp/arm/tms570/make/custom/tms570ls3137.inc   | 20 ++++++++++++++++++++
 .../arm/tms570/make/custom/tms570ls3137_hdk.cfg      | 17 +----------------
 .../tms570/make/custom/tms570ls3137_hdk_intram.cfg   | 17 +----------------
 .../tms570/make/custom/tms570ls3137_hdk_sdram.cfg    | 17 +----------------
 .../make/custom/tms570ls3137_hdk_with_loader.cfg     | 17 +----------------
 5 files changed, 24 insertions(+), 64 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc
new file mode 100644
index 0000000..869cf71
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc
@@ -0,0 +1,20 @@
+# Config file for TMS570LS3137 board.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian -mfpu=vfpv3-d16 -mfloat-abi=hard
+CFLAGS_OPTIMIZE_V = -O2 -ggdb
+BINEXT?=.bin
+# This defines the operations performed on the linked executable.
+# is currently required.
+define bsp-post-link
+    $(OBJCOPY) -O binary --strip-all \
+        $(basename $@)$(EXEEXT) $(basename $@)$(BINEXT)
+    $(SIZE) $(basename $@)$(EXEEXT)
+endef
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
index 869cf71..d769895 100644
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
@@ -2,19 +2,4 @@
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU = arm
-CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian -mfpu=vfpv3-d16 -mfloat-abi=hard
-CFLAGS_OPTIMIZE_V = -O2 -ggdb
-BINEXT?=.bin
-# This defines the operations performed on the linked executable.
-# is currently required.
-define bsp-post-link
-    $(OBJCOPY) -O binary --strip-all \
-        $(basename $@)$(EXEEXT) $(basename $@)$(BINEXT)
-    $(SIZE) $(basename $@)$(EXEEXT)
-endef
+include $(RTEMS_ROOT)/make/custom/tms570ls3137.inc
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
index e90414a..d769895 100644
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
@@ -2,19 +2,4 @@
-RTEMS_CPU = arm
-BINEXT?=.bin
-endef
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
@@ -2,19 +2,4 @@
-RTEMS_CPU = arm
-BINEXT?=.bin
-endef
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg
@@ -2,19 +2,4 @@
-RTEMS_CPU = arm
-BINEXT?=.bin
-endef
1.9.1
