[PATCH 1/1] sparc: Fix context switch on SMP
Mon Nov 16 09:09:13 UTC 2015
Hello Daniel,
could you please add comments to the move to PSR which are not followed
by three nops and explain why they are not necessary.
On 16/11/15 10:03, Daniel Cederman wrote:
> We must not load registers (e.g. PSR) from the heir context area before
> the heir stopped execution.
>   c/src/lib/libbsp/sparc/shared/irq_asm.S | 30 +++++++++++++-----------------
>   1 file changed, 13 insertions(+), 17 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index f7222e7..5931e77 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -127,14 +127,9 @@ SYM(_CPU_Context_restore_heir):
>            *      g5 = scratch
> -        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = saved psr
>           and     %o2, SPARC_PSR_CWP_MASK, %g3  ! g3 = CWP
> -                                              ! g1 = psr w/o cwp
> -        andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
> -        or      %g1, %g3, %g1                 ! g1 = heirs psr
> -        mov     %g1, %psr                     ! restore status register and
> -                                              ! **** DISABLE TRAPS ****
> +        andn    %o2, SPARC_PSR_ET_MASK, %g1   ! g1 = psr with traps disabled
> +        mov     %g1, %psr                     ! **** DISABLE TRAPS ****
>           mov     %wim, %g2                     ! g2 = wim
>           mov     1, %g4
>           sll     %g4, %g3, %g4                 ! g4 = WIM mask for CW invalid
> @@ -173,19 +168,13 @@ save_frame_loop:
>   done_flushing:
> -        add     %g3, 1, %g3                   ! calculate desired WIM
> -        and     %g3, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
> +        mov     %g1, %psr                     ! restore cwp
> +        add     %g3, 1, %g2                   ! calculate desired WIM
> +        and     %g2, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g2
>           mov     1, %g4
> -        sll     %g4, %g3, %g4                 ! g4 = new WIM
> +        sll     %g4, %g2, %g4                 ! g4 = new WIM
>           mov     %g4, %wim
> -        or      %g1, SPARC_PSR_ET_MASK, %g1
> -        mov     %g1, %psr                     ! **** ENABLE TRAPS ****
> -                                              !   and restore CWP
> -        nop
> -        nop
> -        nop
>   #if defined(RTEMS_SMP)
>           ! The executing context no longer executes on this processor
>           st      %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> @@ -202,6 +191,13 @@ try_update_is_executing:
>           ! The next load is in a delay slot, which is all right
>   #endif
> +        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = heir psr
> +        andn    %g1, SPARC_PSR_CWP_MASK, %g1  ! g1 = heir psr w/o cwp
> +        or      %g1, %g3, %g1                 ! g1 = heir psr with cwp
> +        or      %g1, SPARC_PSR_ET_MASK, %g1   ! g1 = heir psr traps enabled
> +        mov     %g1, %psr                     ! restore status register and
> +                                              ! **** ENABLE TRAPS ****
>           ld      [%o1 + G5_OFFSET], %g5        ! restore the global registers
>           ld      [%o1 + G7_OFFSET], %g7
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
