[PATCH-V2 1/1] sparc: Fix context switch on SMP
Mon Nov 16 10:27:19 UTC 2015
On 16/11/15 11:06, Daniel Cederman wrote:
> @@ -202,6 +193,13 @@ try_update_is_executing:
>           ! The next load is in a delay slot, which is all right
>   #endif
> +        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = heir psr
> +        andn    %g1, SPARC_PSR_CWP_MASK, %g1  ! g1 = heir psr w/o cwp
> +        or      %g1, %g3, %g1                 ! g1 = heir psr with cwp
> +        or      %g1, SPARC_PSR_ET_MASK, %g1   ! g1 = heir psr traps enabled
Do we really need the "or      %g1, SPARC_PSR_ET_MASK, %g1"? I think we
should simply use the value of the saved PSR and omit this step.
> +        mov     %g1, %psr                     ! restore status register and
> +                                              ! **** ENABLE TRAPS ****
>           ld      [%o1 + G5_OFFSET], %g5        ! restore the global registers
>           ld      [%o1 + G7_OFFSET], %g7
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
