[PATCH 1/3] Import latest <sys/filio.h> from FreeBSD
Sebastian Huber
Tue Nov 17 14:29:00 UTC 2015
Required by new network stack.
cpukit/libcsupport/include/sys/filio.h | 20 +++++++++++++-------
cpukit/libcsupport/include/sys/ioccom.h | 10 ----------
2 files changed, 13 insertions(+), 17 deletions(-)
diff --git a/cpukit/libcsupport/include/sys/filio.h b/cpukit/libcsupport/include/sys/filio.h
index f1a703a..df1b6f4 100644
--- a/cpukit/libcsupport/include/sys/filio.h
+++ b/cpukit/libcsupport/include/sys/filio.h
@@ -15,10 +15,6 @@
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
- * 3. All advertising materials mentioning features or use of this software
- * must display the following acknowledgement:
- * This product includes software developed by the University of
- * California, Berkeley and its contributors.
* 4. Neither the name of the University nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
@@ -36,6 +32,7 @@
* SUCH DAMAGE.
* @(#)filio.h 8.1 (Berkeley) 3/28/94
+ * $FreeBSD r195191 2009-06-30T13:38:49Z$
#ifndef _SYS_FILIO_H_
@@ -43,8 +40,6 @@
#include <sys/ioccom.h>
-/* RTEMS defines all of these in sys/ioccom.h */
-#if 0
/* Generic file-descriptor ioctl's. */
#define FIOCLEX _IO('f', 1) /* set close on exec on fd */
#define FIONCLEX _IO('f', 2) /* remove close on exec */
@@ -53,6 +48,17 @@
#define FIOASYNC _IOW('f', 125, int) /* set/clear async i/o */
#define FIOSETOWN _IOW('f', 124, int) /* set owner */
#define FIOGETOWN _IOR('f', 123, int) /* get owner */
-#endif
+#define FIODTYPE _IOR('f', 122, int) /* get d_flags type part */
+#define FIOGETLBA _IOR('f', 121, int) /* get start blk # */
+struct fiodgname_arg {
+ int len;
+ void *buf;
+#define FIODGNAME _IOW('f', 120, struct fiodgname_arg) /* get dev. name */
+#define FIONWRITE _IOR('f', 119, int) /* get # bytes (yet) to write */
+#define FIONSPACE _IOR('f', 118, int) /* get space in send queue */
+/* Handle lseek SEEK_DATA and SEEK_HOLE for holey file knowledge. */
+#define FIOSEEKDATA _IOWR('f', 97, off_t) /* SEEK_DATA */
+#define FIOSEEKHOLE _IOWR('f', 98, off_t) /* SEEK_HOLE */
#endif /* !_SYS_FILIO_H_ */
diff --git a/cpukit/libcsupport/include/sys/ioccom.h b/cpukit/libcsupport/include/sys/ioccom.h
index d454328..1699fc9 100644
--- a/cpukit/libcsupport/include/sys/ioccom.h
+++ b/cpukit/libcsupport/include/sys/ioccom.h
@@ -80,16 +80,6 @@ typedef uint32_t ioctl_command_t;
#define RTEMS_IO_SNDWAKEUP 5
#define RTEMS_IO_TCFLUSH 6
-/* copied from libnetworking/sys/filio.h and commented out there */
-/* Generic file-descriptor ioctl's. */
-#define FIOCLEX _IO('f', 1) /* set close on exec on fd */
-#define FIONCLEX _IO('f', 2) /* remove close on exec */
-#define FIONREAD _IOR('f', 127, int) /* get # bytes to read */
-#define FIONBIO _IOW('f', 126, int) /* set/clear non-blocking i/o */
-#define FIOASYNC _IOW('f', 125, int) /* set/clear async i/o */
-#define FIOSETOWN _IOW('f', 124, int) /* set owner */
-#define FIOGETOWN _IOR('f', 123, int) /* get owner */
#ifdef _KERNEL
#if defined(COMPAT_FREEBSD6) || defined(COMPAT_FREEBSD5) || \
1.8.4.5
