[PATCH] bsp/tms570: unite code duplication in pinmux and clean SCI close per review remarks.
Pavel Pisa pisa at cmp.felk.cvut.cz
Wed Nov 18 17:45:32 UTC 2015
Signed-off-by: Premysl Houdek <kom541000 at gmail.com>
 c/src/lib/libbsp/arm/tms570/console/tms570-sci.c    | 12 +++++++-----
 c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h |  9 +++++++++
 c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c         | 18 +++++-------------
 3 files changed, 21 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
index a799a66..fac258d 100644
--- a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
+++ b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
@@ -525,17 +525,19 @@ static void tms570_sci_interrupt_last_close(
   tms570_sci_context *ctx = (tms570_sci_context *) base;
   rtems_interrupt_lock_context lock_context;
+  rtems_interval tw;
+  int32_t baudrate;
   /* Turn off RX interrupts */
   rtems_termios_device_lock_acquire(base, &lock_context);
   tms570_sci_disable_interrupts(ctx);
   rtems_termios_device_lock_release(base, &lock_context);
-  if ( 0 /* for flush on close */ ) {
-    /* Flush device */
-    while ( ( ctx->regs->FLR & TMS570_SCI_FLR_TX_EMPTY ) == 0 ) {
-      ;/* Wait until all data has been sent */
+  tw = rtems_clock_get_ticks_per_second();
+  baudrate = rtems_termios_baud_to_number(cfgetospeed(&tty->termios));
+  tw = tw * 10 / baudrate + 1;
+  while ( ( ctx->regs->FLR & TMS570_SCI_FLR_TX_EMPTY ) == 0 ) {
+     rtems_task_wake_after(tw);
   /* uninstall ISR */
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h b/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
index 46c4ae5..8979f23 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
@@ -111,6 +111,15 @@ void tms570_bsp_pin_set_function(int pin_num, int pin_fnc);
 void tms570_bsp_pin_clear_function(int pin_num, int pin_fnc);
+static inline void
+tms570_bsp_pin_to_pinmmrx(volatile uint32_t **pinmmrx, unsigned int *pin_shift,
+                          int pin_num)
+  pin_num = (pin_num & TMS570_PIN_NUM_MASK) >> TMS570_PIN_NUM_SHIFT;
+  *pinmmrx = &TMS570_IOMM.PINMUX.PINMMR0 + (pin_num >> 2);
+  *pin_shift = (pin_num & 0x3)*8;
 #endif
diff --git a/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c b/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
index 79d6b1e..fed23fa 100644
--- a/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
+++ b/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
@@ -31,7 +31,7 @@
  * entries array. Predefined values for pins are in a format
  * TMS570_BALL_<column><row> (for example TMS570_BALL_N19).
  * The multiplexer allows to interconnect one pin to multiple
- * signal sources/sings in the theory but it is usually bad choice.
+ * signal sources/sinks in the theory but it is usually bad choice.
  * The function sets only specified function and clears all other
  * connections.
@@ -45,16 +45,12 @@ void
   unsigned int pin_shift;
-  typeof(TMS570_IOMM.PINMUX.PINMMR0) *pinmmrx;
+  volatile uint32_t *pinmmrx;
   if ( pin_fnc == TMS570_PIN_FNC_AUTO ) {
     pin_fnc = (pin_num & TMS570_PIN_FNC_MASK) >> TMS570_PIN_FNC_SHIFT;
-  pin_num = (pin_num & TMS570_PIN_NUM_MASK) >> TMS570_PIN_NUM_SHIFT;
-  pinmmrx = &TMS570_IOMM.PINMUX.PINMMR0;
-  pinmmrx += (pin_num >> 2);
-  pin_shift = (pin_num & 0x3)*8;
+  tms570_bsp_pin_to_pinmmrx(&pinmmrx, &pin_shift, pin_num);
   *pinmmrx = (*pinmmrx & ~(0xff << pin_shift)) | (1 << (pin_fnc + pin_shift));
@@ -74,15 +70,11 @@ void
   *pinmmrx = *pinmmrx & ~(1 << (pin_fnc+pin_shift));
1.9.1
