[PATCH] Require __getreent()
Sebastian Huber
Wed Nov 25 07:35:05 UTC 2015
This function is used by Newlib since 2013-07-09 (Git commit
9b51cd8c6b9cdd067d9648a7ab952884019c56a5).
cpukit/configure.ac | 4 ++++
cpukit/libcsupport/src/newlibc_reent.c | 9 --------
cpukit/sapi/include/confdefs.h | 2 +-
cpukit/score/include/rtems/score/threadimpl.h | 32 ---------------------------
cpukit/score/src/threaddispatch.c | 10 ---------
5 files changed, 5 insertions(+), 52 deletions(-)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index cdf9915..f1589a8 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -180,6 +180,10 @@ AC_CHECK_HEADER([signal.h],[
AC_CHECK_TYPES([sighandler_t])
+if test x"$RTEMS_USE_NEWLIB" = xyes ; then
+ AC_CHECK_DECLS([__getreent],[],[AC_MSG_ERROR([__getreent() in <sys/reent.h> is mandatory])],[#include <sys/reent.h>])
+fi
RTEMS_CHECK_MULTIPROCESSING
RTEMS_CHECK_POSIX_API
RTEMS_CHECK_NETWORKING
diff --git a/cpukit/libcsupport/src/newlibc_reent.c b/cpukit/libcsupport/src/newlibc_reent.c
index bf8847c..26da252 100644
--- a/cpukit/libcsupport/src/newlibc_reent.c
+++ b/cpukit/libcsupport/src/newlibc_reent.c
@@ -35,15 +35,6 @@ bool newlib_create_hook(
rtems_tcb *creating_task
-#if !defined(__DYNAMIC_REENT__)
- if (_Thread_libc_reent == 0)
- _REENT = _GLOBAL_REENT;
- _Thread_Set_libc_reent (&_REENT);
-#endif
_REENT_INIT_PTR((creating_task->libc_reent)); /* GCC extension: structure constants */
return true;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 0e83bf1..9ef0bc6 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2417,7 +2417,7 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0
#endif
-#if defined(RTEMS_NEWLIB) && defined(__DYNAMIC_REENT__)
+#if defined(RTEMS_NEWLIB)
struct _reent *__getreent(void)
#ifdef CONFIGURE_DISABLE_NEWLIB_REENTRANCY
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 906bdb1..cf32082 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -75,16 +75,6 @@ SCORE_EXTERN Thread_Information _Thread_Internal_information;
SCORE_EXTERN Thread_Control *_Thread_Allocated_fp;
#endif
- * The C library re-enter-rant global pointer. Some C library implementations
- * such as newlib have a single global pointer that changed during a context
- * switch. The pointer points to that global pointer. The Thread control block
- * holds a pointer to the task specific data.
-SCORE_EXTERN struct _reent **_Thread_libc_reent;
-#endif
#define THREAD_CHAIN_NODE_TO_THREAD( node ) \
RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Node.Chain )
@@ -1501,28 +1491,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Debug_set_real_processor(
#endif
- * This routine returns the C library re-enterant pointer.
-RTEMS_INLINE_ROUTINE struct _reent **_Thread_Get_libc_reent( void )
- return _Thread_libc_reent;
- * This routine set the C library re-enterant pointer.
-RTEMS_INLINE_ROUTINE void _Thread_Set_libc_reent (
- struct _reent **libc_reent
- _Thread_libc_reent = libc_reent;
-#endif
#ifdef __cplusplus
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index cce3aff..3ae8335 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -104,16 +104,6 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
&cpu_self->time_of_last_context_switch
- * Switch libc's task specific data.
- if ( _Thread_libc_reent ) {
- executing->libc_reent = *_Thread_libc_reent;
- *_Thread_libc_reent = heir->libc_reent;
-#endif
_User_extensions_Thread_switch( executing, heir );
_Thread_Save_fp( executing );
_Context_Switch( &executing->Registers, &heir->Registers );
1.8.4.5
