[PATCH] Require __getreent()
Wed Nov 25 14:47:58 UTC 2015
On 25/11/15 15:32, Marcos Díaz wrote:
> Hi Sebastian we are using newlib-2.1.0, what we want to know is why is
> this change necessary now, why it was as before. Thanks!
In this Newlib version the patch is included.  However, its not a good
idea to use an arbitrary Newlib version with the RTEMS master. You
should use the versions defined by the RSB. We use this since 2013 and
this patch removes only some dead code.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
