[PATCH 1/2] Delete _Region_Debug_Walk()
Thu Nov 26 13:14:26 UTC 2015
The expensive heap walks are superfluous due to the heap protection
enabled via RTEMS_DEBUG.
Update #2477.
 cpukit/rtems/include/rtems/rtems/regionimpl.h | 20 --------------------
 cpukit/rtems/src/regiondelete.c               |  1 -
 cpukit/rtems/src/regiongetsegment.c           |  4 ----
 cpukit/rtems/src/regionresizesegment.c        |  5 -----
 cpukit/rtems/src/regionreturnsegment.c        |  5 -----
 5 files changed, 35 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/regionimpl.h b/cpukit/rtems/include/rtems/rtems/regionimpl.h
index ae1a50d..078cf44 100644
--- a/cpukit/rtems/include/rtems/rtems/regionimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/regionimpl.h
@@ -146,26 +146,6 @@ RTEMS_INLINE_ROUTINE bool _Region_Free_segment (
 extern void _Region_Process_queue(Region_Control *the_region);
- *  @brief _Region_Debug_Walk
- *  This routine is invoked to verify the integrity of a heap associated
- *  with the_region.
-#ifdef RTEMS_DEBUG
-#define _Region_Debug_Walk( _the_region, _source ) \
-  do { \
-    if ( rtems_debug_is_enabled( RTEMS_DEBUG_REGION ) ) \
-      _Heap_Walk( &(_the_region)->Memory, _source, false ); \
-  } while ( 0 )
-#else
-#endif
 #ifdef __cplusplus
diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
index b5209da..bf6e461 100644
--- a/cpukit/rtems/src/regiondelete.c
+++ b/cpukit/rtems/src/regiondelete.c
@@ -40,7 +40,6 @@ rtems_status_code rtems_region_delete(
     switch ( location ) {
       case OBJECTS_LOCAL:
-        _Region_Debug_Walk( the_region, 5 );
         if ( the_region->number_of_used_blocks != 0 )
           return_status = RTEMS_RESOURCE_IN_USE;
         else {
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index 26437b5..864bd00 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -57,12 +57,8 @@ rtems_status_code rtems_region_get_segment(
           return_status = RTEMS_INVALID_SIZE;
         else {
-          _Region_Debug_Walk( the_region, 1 );
           the_segment = _Region_Allocate_segment( the_region, size );
-          _Region_Debug_Walk( the_region, 2 );
           if ( the_segment ) {
             the_region->number_of_used_blocks += 1;
             *segment = the_segment;
diff --git a/cpukit/rtems/src/regionresizesegment.c b/cpukit/rtems/src/regionresizesegment.c
index b1d9482..86d8a77 100644
--- a/cpukit/rtems/src/regionresizesegment.c
+++ b/cpukit/rtems/src/regionresizesegment.c
@@ -49,9 +49,6 @@ rtems_status_code rtems_region_resize_segment(
       case OBJECTS_LOCAL:
-        _Region_Debug_Walk( the_region, 7 );
         status = _Heap_Resize_block(
           &the_region->Memory,
           segment,
@@ -61,8 +58,6 @@ rtems_status_code rtems_region_resize_segment(
         *old_size = (uint32_t) osize;
-        _Region_Debug_Walk( the_region, 8 );
         if ( status == HEAP_RESIZE_SUCCESSFUL )
           /* unlocks allocator */
           _Region_Process_queue( the_region );
diff --git a/cpukit/rtems/src/regionreturnsegment.c b/cpukit/rtems/src/regionreturnsegment.c
index 98f2240..1af54f2 100644
--- a/cpukit/rtems/src/regionreturnsegment.c
+++ b/cpukit/rtems/src/regionreturnsegment.c
@@ -53,9 +53,6 @@ rtems_status_code rtems_region_return_segment(
       case OBJECTS_LOCAL:
-        _Region_Debug_Walk( the_region, 3 );
 #ifdef RTEMS_REGION_FREE_SHRED_PATTERN
         if ( !_Heap_Size_of_alloc_area( &the_region->Memory, segment, &size ) )
           return_status = RTEMS_INVALID_ADDRESS;
@@ -64,8 +61,6 @@ rtems_status_code rtems_region_return_segment(
 #endif
           status = _Region_Free_segment( the_region, segment );
-          _Region_Debug_Walk( the_region, 4 );
           if ( !status )
           else {
1.8.4.5
