[PATCH] bsp/raspberrypi: Store the current taskid before waiting for the transient event in i2c-driver
Jan Sommer soja-lists at aries.uberspace.de
Mon Nov 30 22:16:30 UTC 2015
Before having the i2c device as an shared resource will create a deadlock because the taskid
for the transient_event is only stored during device registration.
 c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
index 14a2467..9bf90ec 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
@@ -91,6 +91,7 @@ static int rpi_i2c_bus_transfer(rpi_i2c_bus *bus)
       BCM2835_REG(BCM2835_I2C_C) |= (1 << 9);
       /* Sleep until the TX FIFO has free space for a new write. */
+      bus->task_id = rtems_task_self();
       if (
           rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout) !=
           RTEMS_SUCCESSFUL
2.5.0
