[PATCH 1/3] Import latest <sys/filio.h> from FreeBSD
Tue Nov 17 17:52:30 UTC 2015
I don't see any obvious issues with importing these. I was mainly
looking to make sure nothing disappeared that we might have
added over the years. I didn't spot anything.
--joel
On Tue, Nov 17, 2015 at 8:29 AM, Sebastian Huber <
> Required by new network stack.
>  cpukit/libcsupport/include/sys/filio.h  | 20 +++++++++++++-------
>  cpukit/libcsupport/include/sys/ioccom.h | 10 ----------
>  2 files changed, 13 insertions(+), 17 deletions(-)
> diff --git a/cpukit/libcsupport/include/sys/filio.h
> b/cpukit/libcsupport/include/sys/filio.h
> index f1a703a..df1b6f4 100644
> --- a/cpukit/libcsupport/include/sys/filio.h
> +++ b/cpukit/libcsupport/include/sys/filio.h
> @@ -15,10 +15,6 @@
>   * 2. Redistributions in binary form must reproduce the above copyright
>   *    notice, this list of conditions and the following disclaimer in the
>   *    documentation and/or other materials provided with the distribution.
> - * 3. All advertising materials mentioning features or use of this
> software
> - *    must display the following acknowledgement:
> - *     This product includes software developed by the University of
> - *     California, Berkeley and its contributors.
>   * 4. Neither the name of the University nor the names of its contributors
>   *    may be used to endorse or promote products derived from this
> software
>   *    without specific prior written permission.
> @@ -36,6 +32,7 @@
>   * SUCH DAMAGE.
>   *     @(#)filio.h     8.1 (Berkeley) 3/28/94
> + * $FreeBSD r195191 2009-06-30T13:38:49Z$
>  #ifndef        _SYS_FILIO_H_
> @@ -43,8 +40,6 @@
>  #include <sys/ioccom.h>
> -/* RTEMS defines all of these in sys/ioccom.h */
> -#if 0
>  /* Generic file-descriptor ioctl's. */
>  #define        FIOCLEX          _IO('f', 1)            /* set close on
> exec on fd */
>  #define        FIONCLEX         _IO('f', 2)            /* remove close on
> exec */
> @@ -53,6 +48,17 @@
>  #define        FIOASYNC        _IOW('f', 125, int)     /* set/clear async
> i/o */
>  #define        FIOSETOWN       _IOW('f', 124, int)     /* set owner */
>  #define        FIOGETOWN       _IOR('f', 123, int)     /* get owner */
> -#endif
> +#define        FIODTYPE        _IOR('f', 122, int)     /* get d_flags
> type part */
> +#define        FIOGETLBA       _IOR('f', 121, int)     /* get start blk #
> +struct fiodgname_arg {
> +       int     len;
> +       void    *buf;
> +#define        FIODGNAME       _IOW('f', 120, struct fiodgname_arg) /*
> get dev. name */
> +#define        FIONWRITE       _IOR('f', 119, int)     /* get # bytes
> (yet) to write */
> +#define        FIONSPACE       _IOR('f', 118, int)     /* get space in
> send queue */
> +/* Handle lseek SEEK_DATA and SEEK_HOLE for holey file knowledge. */
> +#define        FIOSEEKDATA     _IOWR('f', 97, off_t)   /* SEEK_DATA */
> +#define        FIOSEEKHOLE     _IOWR('f', 98, off_t)   /* SEEK_HOLE */
>  #endif /* !_SYS_FILIO_H_ */
> diff --git a/cpukit/libcsupport/include/sys/ioccom.h
> b/cpukit/libcsupport/include/sys/ioccom.h
> index d454328..1699fc9 100644
> --- a/cpukit/libcsupport/include/sys/ioccom.h
> +++ b/cpukit/libcsupport/include/sys/ioccom.h
> @@ -80,16 +80,6 @@ typedef uint32_t ioctl_command_t;
>  #define       RTEMS_IO_SNDWAKEUP      5
>  #define       RTEMS_IO_TCFLUSH        6
> -/* copied from libnetworking/sys/filio.h and commented out there */
> -/* Generic file-descriptor ioctl's. */
> -#define FIOCLEX          _IO('f', 1)            /* set close on exec on
> fd */
> -#define FIONCLEX         _IO('f', 2)            /* remove close on exec */
> -#define FIONREAD        _IOR('f', 127, int)     /* get # bytes to read */
> -#define FIONBIO         _IOW('f', 126, int)     /* set/clear non-blocking
> i/o */
> -#define FIOASYNC        _IOW('f', 125, int)     /* set/clear async i/o */
> -#define FIOSETOWN       _IOW('f', 124, int)     /* set owner */
> -#define FIOGETOWN       _IOR('f', 123, int)     /* get owner */
>  #ifdef _KERNEL
>  #if defined(COMPAT_FREEBSD6) || defined(COMPAT_FREEBSD5) || \
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151117/d575a336/attachment-0002.html>
