[rtems-libbsd commit] builder.py: addTargetSourceCPUDependentSourceFiles
Thu Oct 1 19:28:44 UTC 2015
On 1/10/2015 2:56 am, Sebastian Huber wrote:
> diff --git a/wscript b/wscript
> index 673479f..88334e4 100644
> --- a/wscript
> +++ b/wscript
> @@ -1053,42 +1053,41 @@ def build(bld):
>                'rtemsbsd/telnetd/pty.c',
>                'rtemsbsd/telnetd/telnetd.c']
>      if bld.get_env()["RTEMS_ARCH"] == "arm":
> -        source += ['freebsd/sys/arm/arm/in_cksum.c']
> +        source += ['freebsd/sys/mips/mips/in_cksum.c']
This looks wrong and checking git it is wrong.
>      if bld.get_env()["RTEMS_ARCH"] == "avr":
> -        source += ['freebsd/sys/avr/avr/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "bfin":
> -        source += ['freebsd/sys/bfin/bfin/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "cflags":
>          source += ['default']
>      if bld.get_env()["RTEMS_ARCH"] == "h8300":
> -        source += ['freebsd/sys/h8300/h8300/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "i386":
>          source += ['freebsd/sys/i386/i386/in_cksum.c',
>                     'freebsd/sys/i386/i386/legacy.c',
>                     'freebsd/sys/x86/pci/pci_bus.c']
>      if bld.get_env()["RTEMS_ARCH"] == "lm32":
> -        source += ['freebsd/sys/lm32/lm32/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "m32c":
> -        source += ['freebsd/sys/m32c/m32c/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "m32r":
> -        source += ['freebsd/sys/m32r/m32r/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "m68k":
> -        source += ['freebsd/sys/m68k/m68k/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "mips":
>      if bld.get_env()["RTEMS_ARCH"] == "nios2":
> -        source += ['freebsd/sys/nios2/nios2/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "powerpc":
>          source += ['freebsd/sys/powerpc/powerpc/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "sh":
> -        source += ['freebsd/sys/sh/sh/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "sparc":
> -        source += ['freebsd/sys/mips/mips/in_cksum.c',
> -                   'freebsd/sys/sparc/sparc/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "sparc64":
>          source += ['freebsd/sys/sparc64/sparc64/in_cksum.c']
>      if bld.get_env()["RTEMS_ARCH"] == "v850":
> -        source += ['freebsd/sys/v850/v850/in_cksum.c']
They all seem wrong which is a puzzling as to how this builds.
