[rtems-libbsd commit] builder.py: addTargetSourceCPUDependentSourceFiles
Thu Oct 1 19:38:02 UTC 2015
On 2/10/2015 8:33 am, Sebastian Huber wrote:
> Why do you think it is wrong?
Because the check is for 'arm' and the file is 'mips'.
> The background for this change is that we need an explicit one-to-one mapping of libbsd and original FreeBSD files.
> ----- Chris Johns <chrisj at rtems.org> schrieb:
>> On 1/10/2015 2:56 am, Sebastian Huber wrote:
>>> diff --git a/wscript b/wscript
>>> index 673479f..88334e4 100644
>>> --- a/wscript
>>> +++ b/wscript
>>> @@ -1053,42 +1053,41 @@ def build(bld):
>>>                'rtemsbsd/telnetd/pty.c',
>>>                'rtemsbsd/telnetd/telnetd.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "arm":
>>> -        source += ['freebsd/sys/arm/arm/in_cksum.c']
>>> +        source += ['freebsd/sys/mips/mips/in_cksum.c']
>> This looks wrong and checking git it is wrong.
>>>      if bld.get_env()["RTEMS_ARCH"] == "avr":
>>> -        source += ['freebsd/sys/avr/avr/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "bfin":
>>> -        source += ['freebsd/sys/bfin/bfin/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "cflags":
>>>          source += ['default']
>>>      if bld.get_env()["RTEMS_ARCH"] == "h8300":
>>> -        source += ['freebsd/sys/h8300/h8300/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "i386":
>>>          source += ['freebsd/sys/i386/i386/in_cksum.c',
>>>                     'freebsd/sys/i386/i386/legacy.c',
>>>                     'freebsd/sys/x86/pci/pci_bus.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "lm32":
>>> -        source += ['freebsd/sys/lm32/lm32/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "m32c":
>>> -        source += ['freebsd/sys/m32c/m32c/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "m32r":
>>> -        source += ['freebsd/sys/m32r/m32r/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "m68k":
>>> -        source += ['freebsd/sys/m68k/m68k/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "mips":
>>>      if bld.get_env()["RTEMS_ARCH"] == "nios2":
>>> -        source += ['freebsd/sys/nios2/nios2/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "powerpc":
>>>          source += ['freebsd/sys/powerpc/powerpc/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "sh":
>>> -        source += ['freebsd/sys/sh/sh/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "sparc":
>>> -        source += ['freebsd/sys/mips/mips/in_cksum.c',
>>> -                   'freebsd/sys/sparc/sparc/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "sparc64":
>>>          source += ['freebsd/sys/sparc64/sparc64/in_cksum.c']
>>>      if bld.get_env()["RTEMS_ARCH"] == "v850":
>>> -        source += ['freebsd/sys/v850/v850/in_cksum.c']
>> They all seem wrong which is a puzzling as to how this builds.
>> Chris
>> devel mailing list
>> devel at rtems.org
