[PATCH 3/3] C11 threads support
Thu Oct 8 05:28:29 UTC 2015
Hello Jeff,
I sent the RTEMS implementation of this API to the RTEMS list only:
https://lists.rtems.org/pipermail/devel/2015-September/012597.html
https://lists.rtems.org/pipermail/devel/2015-September/012598.html
It is a slight modification of the FreeBSD libstdthreads. The original
FreeBSD implementation uses <pthread.h>, so it would be possible to add
this as a default implementation for Newlib. I am not sure how to
integrate this in the build system. If desired, this could be done in a
second step.
On 08/10/15 00:04, Jeff Johnston wrote:
> I am ok with this although I would like to hear that at least RTEMS or another configuration
> supports or plans to support threads.h and functions.  C11 says that the flag __STDC_NO_THREADS__
> can be used to indicate that threads.h and the functions are missing.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
