[PATCH] Add STM32 HAL Files for F4 and F7
Wed Oct 14 20:54:47 UTC 2015
On 10/14/2015 3:35 PM, Gedare Bloom wrote:
> I don't have a problem on the surface of it, but can we get a clear
> statement of the licensing for the included code?
The patch is huge but includes the license in pdf and rtf format.
Based on the one source file I looked at, the license is BSD
w/advertising. I am not sure if this is the same with all files.
This is a cut and paste from a file added:
+  * <h2><center>© COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
+  * Redistribution and use in source and binary forms, with or without modification,
+  * are permitted provided that the following conditions are met:
+  *   1. Redistributions of source code must retain the above copyright notice,
+  *      this list of conditions and the following disclaimer.
+  *   2. Redistributions in binary form must reproduce the above copyright notice,
+  *      this list of conditions and the following disclaimer in the documentation
+  *      and/or other materials provided with the distribution.
+  *   3. Neither the name of STMicroelectronics nor the names of its contributors
+  *      may be used to endorse or promote products derived from this software
+  *      without specific prior written permission.
+  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
+  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
+  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> On Mon, Sep 28, 2015 at 4:25 PM, Isaac Gutekunst
> <isaac.gutekunst at vecna.com> wrote:
>> Hi Devel,
>> As mentioned earlier, Vecna has developed two BSP families using the HAL
>> code provide by ST as a foundation. The code isn't perfect, but it let us
>> get up to speed very fast, and provides a consistent abstraction across a
>> number of processors.
>> I formatted a giant patch with all the relevant files needed for the new BSP
>> that will be arriving later. The plan is to get this code approved and
>> merged, and then add the BSP piece by piece to reduce the amount of code
>> coming in at once.
>> This includes some HAL files that we aren't using in the BSP just yet. Let
>> me know if we should remove them. It's a rather absurd amount of code :)
>> As before, I can't get git-send-email to work. In addition, the patches are
>> giant, so I've inserted links to files in Google Drive.
>> https://drive.google.com/open?id=0BxaqNLUoI5onZ3lUUDNrYXlyX1U
>> https://drive.google.com/open?id=0BxaqNLUoI5onM3JsenRJRkotWm8
>> Isaac Gutekunst
>> Embedded Systems Software Engineer
>> www.vecna.com
>> Cambridge Research Laboratory
>> Vecna Technologies, Inc.
>> 36 Cambridge Park Drive
>> Cambridge, MA 02140
>> Office: (617) 864-0636 x3069
>> Fax: (617) 864-0638
>> http://vecna.com
>> Better Technology, Better World (TM)
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
