[PATCH] libfdt: Initial import
Thu Oct 15 13:42:52 UTC 2015
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
 cpukit/Makefile.am                        |    1 +
 cpukit/configure.ac                       |    1 +
 cpukit/dtc/README                         |   20 +
 cpukit/dtc/README.license                 |   56 +
 cpukit/dtc/libfdt/Makefile.am             |   19 +
 cpukit/dtc/libfdt/TODO                    |    3 +
 cpukit/dtc/libfdt/fdt.c                   |  250 +++++
 cpukit/dtc/libfdt/fdt.h                   |  111 ++
 cpukit/dtc/libfdt/fdt_addresses.c         |   96 ++
 cpukit/dtc/libfdt/fdt_empty_tree.c        |   84 ++
 cpukit/dtc/libfdt/fdt_ro.c                |  679 ++++++++++++
 cpukit/dtc/libfdt/fdt_rw.c                |  492 +++++++++
 cpukit/dtc/libfdt/fdt_strerror.c          |   96 ++
 cpukit/dtc/libfdt/fdt_sw.c                |  288 +++++
 cpukit/dtc/libfdt/fdt_wip.c               |  118 ++
 cpukit/dtc/libfdt/libfdt.h                | 1653 +++++++++++++++++++++++++++++
 cpukit/dtc/libfdt/libfdt_env.h            |  111 ++
 cpukit/dtc/libfdt/libfdt_internal.h       |   95 ++
 cpukit/dtc/libfdt/preinstall.am           |   46 +
 testsuites/libtests/Makefile.am           |    1 +
 testsuites/libtests/configure.ac          |    1 +
 testsuites/libtests/libfdt01/Makefile.am  |   20 +
 testsuites/libtests/libfdt01/init.c       |  145 +++
 testsuites/libtests/libfdt01/libfdt01.doc |   20 +
 testsuites/libtests/libfdt01/libfdt01.scn |    2 +
 testsuites/libtests/libfdt01/some.c       |   52 +
 testsuites/libtests/libfdt01/some.dts     |   54 +
 testsuites/libtests/libfdt01/some.h       |   15 +
 28 files changed, 4529 insertions(+)
 create mode 100644 cpukit/dtc/README
 create mode 100644 cpukit/dtc/README.license
 create mode 100644 cpukit/dtc/libfdt/Makefile.am
 create mode 100644 cpukit/dtc/libfdt/TODO
 create mode 100644 cpukit/dtc/libfdt/fdt.c
 create mode 100644 cpukit/dtc/libfdt/fdt.h
 create mode 100644 cpukit/dtc/libfdt/fdt_addresses.c
 create mode 100644 cpukit/dtc/libfdt/fdt_empty_tree.c
 create mode 100644 cpukit/dtc/libfdt/fdt_ro.c
 create mode 100644 cpukit/dtc/libfdt/fdt_rw.c
 create mode 100644 cpukit/dtc/libfdt/fdt_strerror.c
 create mode 100644 cpukit/dtc/libfdt/fdt_sw.c
 create mode 100644 cpukit/dtc/libfdt/fdt_wip.c
 create mode 100644 cpukit/dtc/libfdt/libfdt.h
 create mode 100644 cpukit/dtc/libfdt/libfdt_env.h
 create mode 100644 cpukit/dtc/libfdt/libfdt_internal.h
 create mode 100644 cpukit/dtc/libfdt/preinstall.am
 create mode 100644 testsuites/libtests/libfdt01/Makefile.am
 create mode 100644 testsuites/libtests/libfdt01/init.c
 create mode 100644 testsuites/libtests/libfdt01/libfdt01.doc
 create mode 100644 testsuites/libtests/libfdt01/libfdt01.scn
 create mode 100644 testsuites/libtests/libfdt01/some.c
 create mode 100644 testsuites/libtests/libfdt01/some.dts
 create mode 100644 testsuites/libtests/libfdt01/some.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 063a795..86c20a9 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -6,6 +6,7 @@ include $(top_srcdir)/automake/multilib.am
 # librtemscpu
 SUBDIRS = . score rtems sapi posix
 SUBDIRS += dev
+SUBDIRS += dtc/libfdt
 SUBDIRS += libcrypt
 SUBDIRS += libcsupport libblock libfs
 SUBDIRS += libdrvmgr
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 01da86d..bf01ba0 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -445,6 +445,7 @@ AC_CONFIG_FILES([
 Doxyfile
 Makefile
 dev/Makefile
+dtc/libfdt/Makefile
 rtems/Makefile
 sapi/Makefile
 score/Makefile
diff --git a/cpukit/dtc/README b/cpukit/dtc/README
new file mode 100644
index 0000000..979974a
--- /dev/null
+++ b/cpukit/dtc/README
@@ -0,0 +1,20 @@
+The source tree contains the Device Tree Compiler (dtc) toolchain for
+working with device tree source and binary files and also libfdt, a
+utility library for reading and manipulating the binary format.
+DTC and LIBFDT are maintained by:
+David Gibson <david at gibson.dropbear.id.au>
+Jon Loeliger <jdl at jdl.com>
+Mailing list
+The following list is for discussion about dtc and libfdt implementation
+mailto:devicetree-compiler at vger.kernel.org
+Core device tree bindings are discussed on the devicetree-spec list:
+mailto:devicetree-spec at vger.kernel.org
+Home Page
+http://devicetree.org/Device_Tree_Compiler
diff --git a/cpukit/dtc/README.license b/cpukit/dtc/README.license
index 0000000..d56c88f
--- /dev/null
+++ b/cpukit/dtc/README.license
@@ -0,0 +1,56 @@
+Licensing and contribution policy of dtc and libfdt
+This dtc package contains two pieces of software: dtc itself, and
+libfdt which comprises the files in the libfdt/ subdirectory.  These
+two pieces of software, although closely related, are quite distinct.
+dtc does not incoporate or rely on libfdt for its operation, nor vice
+versa.  It is important that these two pieces of software have
+different license conditions.
+As the copyright banners in each source file attest, dtc is licensed
+under the GNU GPL.  The full text of the GPL can be found in the file
+entitled 'GPL' which should be included in this package.  dtc code,
+therefore, may not be incorporated into works which do not have a GPL
+compatible license.
+libfdt, however, is GPL/BSD dual-licensed.  That is, it may be used
+either under the terms of the GPL, or under the terms of the 2-clause
+BSD license (aka the ISC license).  The full terms of that license are
+given in the copyright banners of each of the libfdt source files.
+This is, in practice, equivalent to being BSD licensed, since the
+terms of the BSD license are strictly more permissive than the GPL.
+I made the decision to license libfdt in this way because I want to
+encourage widespread and correct usage of flattened device trees,
+including by proprietary or otherwise GPL-incompatible firmware or
+tools.  Allowing libfdt to be used under the terms of the BSD license
+makes that it easier for vendors or authors of such software to do so.
+This does mean that libfdt code could be "stolen" - say, included in a
+proprietary fimware and extended without contributing those extensions
+back to the libfdt mainline.  While I hope that doesn't happen, I
+believe the goal of allowing libfdt to be widely used is more
+important than avoiding that.  libfdt is quite small, and hardly
+rocket science; so the incentive for such impolite behaviour is small,
+and the inconvenience caused therby is not dire.
+Licenses such as the LGPL which would allow code to be used in non-GPL
+software, but also require contributions to be returned were
+considered.  However, libfdt is designed to be used in firmwares and
+other environments with unusual technical constraints.  It's difficult
+to anticipate all possible changes which might be needed to meld
+libfdt into such environments and so difficult to suitably word a
+license that puts the boundary between what is and isn't permitted in
+the intended place.  Again, I judged encouraging widespread use of
+libfdt by keeping the license terms simple and familiar to be the more
+important goal.
+**IMPORTANT** It's intended that all of libfdt as released remain
+permissively licensed this way.  Therefore only contributions which
+are released under these terms can be merged into the libfdt mainline.
+(principal original author of dtc and libfdt)
+2 November 2007
diff --git a/cpukit/dtc/libfdt/Makefile.am b/cpukit/dtc/libfdt/Makefile.am
index 0000000..9d76c63
--- /dev/null
+++ b/cpukit/dtc/libfdt/Makefile.am
@@ -0,0 +1,19 @@
+include $(top_srcdir)/automake/compile.am
+include_HEADERS = fdt.h libfdt.h libfdt_env.h
+project_lib_LIBRARIES = libfdt.a
+libfdt_a_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)
+libfdt_a_SOURCES =
+libfdt_a_SOURCES += fdt_addresses.c
+libfdt_a_SOURCES += fdt.c
+libfdt_a_SOURCES += fdt_empty_tree.c
+libfdt_a_SOURCES += fdt_ro.c
+libfdt_a_SOURCES += fdt_rw.c
+libfdt_a_SOURCES += fdt_strerror.c
+libfdt_a_SOURCES += fdt_sw.c
+libfdt_a_SOURCES += fdt_wip.c
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dtc/libfdt/TODO b/cpukit/dtc/libfdt/TODO
index 0000000..288437e
--- /dev/null
+++ b/cpukit/dtc/libfdt/TODO
@@ -0,0 +1,3 @@
+- Tree traversal functions
+- Graft function
+- Complete libfdt.h documenting comments
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 0000000..2ce6a44
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -0,0 +1,250 @@
+ * libfdt - Flat Device Tree manipulation
+ * Copyright (C) 2006 David Gibson, IBM Corporation.
+ * libfdt is dual licensed: you can use it either under the terms of
+ * the GPL, or the BSD license, at your option.
+ *  a) This library is free software; you can redistribute it and/or
+ *     modify it under the terms of the GNU General Public License as
+ *     published by the Free Software Foundation; either version 2 of the
+ *     License, or (at your option) any later version.
+ *     This library is distributed in the hope that it will be useful,
+ *     but WITHOUT ANY WARRANTY; without even the implied warranty of
+ *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ *     GNU General Public License for more details.
+ *     You should have received a copy of the GNU General Public
+ *     License along with this library; if not, write to the Free
+ *     Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
+ *     MA 02110-1301 USA
+ * Alternatively,
+ *  b) Redistribution and use in source and binary forms, with or
+ *     without modification, are permitted provided that the following
+ *     conditions are met:
+ *     1. Redistributions of source code must retain the above
+ *        copyright notice, this list of conditions and the following
+ *        disclaimer.
+ *     2. Redistributions in binary form must reproduce the above
+ *        disclaimer in the documentation and/or other materials
+ *        provided with the distribution.
+ *     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
+ *     CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
+ *     INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ *     MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ *     DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
+ *     CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ *     SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ *     NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ *     LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ *     HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ *     CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ *     OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
+ *     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include "libfdt_env.h"
+#include <fdt.h>
+#include <libfdt.h>
+#include "libfdt_internal.h"
+int fdt_check_header(const void *fdt)
+	if (fdt_magic(fdt) == FDT_MAGIC) {
+		/* Complete tree */
+		if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
+			return -FDT_ERR_BADVERSION;
+		if (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION)
+	} else if (fdt_magic(fdt) == FDT_SW_MAGIC) {
+		/* Unfinished sequential-write blob */
+		if (fdt_size_dt_struct(fdt) == 0)
+			return -FDT_ERR_BADSTATE;
+	} else {
+		return -FDT_ERR_BADMAGIC;
+	return 0;
+const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len)
+	const char *p;
+	if (fdt_version(fdt) >= 0x11)
+		if (((offset + len) < offset)
+		    || ((offset + len) > fdt_size_dt_struct(fdt)))
+			return NULL;
+	p = _fdt_offset_ptr(fdt, offset);
+	if (p + len < p)
+		return NULL;
+	return p;
+uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
+	const fdt32_t *tagp, *lenp;
+	uint32_t tag;
+	int offset = startoffset;
+	const char *p;
+	*nextoffset = -FDT_ERR_TRUNCATED;
+	tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE);
+	if (!tagp)
+		return FDT_END; /* premature end */
+	tag = fdt32_to_cpu(*tagp);
+	offset += FDT_TAGSIZE;
+	*nextoffset = -FDT_ERR_BADSTRUCTURE;
+	switch (tag) {
+	case FDT_BEGIN_NODE:
+		/* skip name */
+		do {
+			p = fdt_offset_ptr(fdt, offset++, 1);
+		} while (p && (*p != '\0'));
+		if (!p)
+		break;
+	case FDT_PROP:
+		lenp = fdt_offset_ptr(fdt, offset, sizeof(*lenp));
+		if (!lenp)
+		/* skip-name offset, length and value */
+		offset += sizeof(struct fdt_property) - FDT_TAGSIZE
+			+ fdt32_to_cpu(*lenp);
+		break;
+	case FDT_END:
+	case FDT_END_NODE:
+	case FDT_NOP:
+		break;
+	default:
+		return FDT_END;
+	if (!fdt_offset_ptr(fdt, startoffset, offset - startoffset))
+	*nextoffset = FDT_TAGALIGN(offset);
+	return tag;
+int _fdt_check_node_offset(const void *fdt, int offset)
+	if ((offset < 0) || (offset % FDT_TAGSIZE)
+	    || (fdt_next_tag(fdt, offset, &offset) != FDT_BEGIN_NODE))
+		return -FDT_ERR_BADOFFSET;
+	return offset;
+int _fdt_check_prop_offset(const void *fdt, int offset)
+	    || (fdt_next_tag(fdt, offset, &offset) != FDT_PROP))
+	return offset;
+int fdt_next_node(const void *fdt, int offset, int *depth)
+	int nextoffset = 0;
+	uint32_t tag;
+	if (offset >= 0)
+		if ((nextoffset = _fdt_check_node_offset(fdt, offset)) < 0)
+			return nextoffset;
+	do {
+		offset = nextoffset;
+		tag = fdt_next_tag(fdt, offset, &nextoffset);
+		switch (tag) {
+		case FDT_PROP:
+		case FDT_NOP:
+			break;
+			if (depth)
+				(*depth)++;
+			break;
+			if (depth && ((--(*depth)) < 0))
+			break;
+		case FDT_END:
+			if ((nextoffset >= 0)
+			    || ((nextoffset == -FDT_ERR_TRUNCATED) && !depth))
+				return -FDT_ERR_NOTFOUND;
+			else
+	} while (tag != FDT_BEGIN_NODE);
+	return offset;
+int fdt_first_subnode(const void *fdt, int offset)
+	int depth = 0;
+	offset = fdt_next_node(fdt, offset, &depth);
+	if (offset < 0 || depth != 1)
+	return offset;
+int fdt_next_subnode(const void *fdt, int offset)
+	int depth = 1;
+	 * With respect to the parent, the depth of the next subnode will be
+	 * the same as the last.
+	do {
+		if (offset < 0 || depth < 1)
+	} while (depth > 1);
+	return offset;
+const char *_fdt_find_string(const char *strtab, int tabsize, const char *s)
+	int len = strlen(s) + 1;
+	const char *last = strtab + tabsize - len;
+	const char *p;
+	for (p = strtab; p <= last; p++)
+		if (memcmp(p, s, len) == 0)
+			return p;
+	return NULL;
+int fdt_move(const void *fdt, void *buf, int bufsize)
+	FDT_CHECK_HEADER(fdt);
+	if (fdt_totalsize(fdt) > bufsize)
+		return -FDT_ERR_NOSPACE;
+	memmove(buf, fdt, fdt_totalsize(fdt));
+	return 0;
diff --git a/cpukit/dtc/libfdt/fdt.h b/cpukit/dtc/libfdt/fdt.h
index 0000000..526aedb
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt.h
@@ -0,0 +1,111 @@
+#ifndef _FDT_H
+#define _FDT_H
+ * Copyright 2012 Kim Phillips, Freescale Semiconductor.
+ * Alternatively,
+ *        disclaimer.
+#ifndef __ASSEMBLY__
+struct fdt_header {
+	fdt32_t magic;			 /* magic word FDT_MAGIC */
+	fdt32_t totalsize;		 /* total size of DT block */
+	fdt32_t off_dt_struct;		 /* offset to structure */
+	fdt32_t off_dt_strings;		 /* offset to strings */
+	fdt32_t off_mem_rsvmap;		 /* offset to memory reserve map */
+	fdt32_t version;		 /* format version */
+	fdt32_t last_comp_version;	 /* last compatible version */
+	/* version 2 fields below */
+	fdt32_t boot_cpuid_phys;	 /* Which physical CPU id we're
+					    booting on */
+	/* version 3 fields below */
+	fdt32_t size_dt_strings;	 /* size of the strings block */
+	/* version 17 fields below */
+	fdt32_t size_dt_struct;		 /* size of the structure block */
+struct fdt_reserve_entry {
+	fdt64_t address;
+	fdt64_t size;
+struct fdt_node_header {
+	fdt32_t tag;
+	char name[0];
+struct fdt_property {
+	fdt32_t tag;
+	fdt32_t len;
+	fdt32_t nameoff;
+	char data[0];
+#endif /* !__ASSEMBLY */
+#define FDT_MAGIC	0xd00dfeed	/* 4: version, 4: total size */
+#define FDT_TAGSIZE	sizeof(fdt32_t)
+#define FDT_BEGIN_NODE	0x1		/* Start node: full name */
+#define FDT_END_NODE	0x2		/* End node */
+#define FDT_PROP	0x3		/* Property: name off,
+					   size, content */
+#define FDT_NOP		0x4		/* nop */
+#define FDT_END		0x9
+#define FDT_V1_SIZE	(7*sizeof(fdt32_t))
+#define FDT_V2_SIZE	(FDT_V1_SIZE + sizeof(fdt32_t))
+#define FDT_V3_SIZE	(FDT_V2_SIZE + sizeof(fdt32_t))
+#define FDT_V16_SIZE	FDT_V3_SIZE
+#define FDT_V17_SIZE	(FDT_V16_SIZE + sizeof(fdt32_t))
+#endif /* _FDT_H */
diff --git a/cpukit/dtc/libfdt/fdt_addresses.c b/cpukit/dtc/libfdt/fdt_addresses.c
index 0000000..eff4dbc
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_addresses.c
@@ -0,0 +1,96 @@
+ * Copyright (C) 2014 David Gibson <david at gibson.dropbear.id.au>
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+int fdt_address_cells(const void *fdt, int nodeoffset)
+	const fdt32_t *ac;
+	int val;
+	int len;
+	ac = fdt_getprop(fdt, nodeoffset, "#address-cells", &len);
+	if (!ac)
+		return 2;
+	if (len != sizeof(*ac))
+		return -FDT_ERR_BADNCELLS;
+	val = fdt32_to_cpu(*ac);
+	if ((val <= 0) || (val > FDT_MAX_NCELLS))
+	return val;
+int fdt_size_cells(const void *fdt, int nodeoffset)
+	const fdt32_t *sc;
+	int val;
+	int len;
+	sc = fdt_getprop(fdt, nodeoffset, "#size-cells", &len);
+	if (!sc)
+		return 2;
+	if (len != sizeof(*sc))
+	val = fdt32_to_cpu(*sc);
+	if ((val < 0) || (val > FDT_MAX_NCELLS))
+	return val;
diff --git a/cpukit/dtc/libfdt/fdt_empty_tree.c b/cpukit/dtc/libfdt/fdt_empty_tree.c
index 0000000..f72d13b
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_empty_tree.c
@@ -0,0 +1,84 @@
+ * Copyright (C) 2012 David Gibson, IBM Corporation.
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+int fdt_create_empty_tree(void *buf, int bufsize)
+	int err;
+	err = fdt_create(buf, bufsize);
+	if (err)
+		return err;
+	err = fdt_finish_reservemap(buf);
+	if (err)
+		return err;
+	err = fdt_begin_node(buf, "");
+	if (err)
+		return err;
+	err =  fdt_end_node(buf);
+	if (err)
+		return err;
+	err = fdt_finish(buf);
+	if (err)
+		return err;
+	return fdt_open_into(buf, buf, bufsize);
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 0000000..e5b3136
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -0,0 +1,679 @@
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+static int _fdt_nodename_eq(const void *fdt, int offset,
+			    const char *s, int len)
+	const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
+	if (! p)
+		/* short match */
+		return 0;
+	if (memcmp(p, s, len) != 0)
+		return 0;
+	if (p[len] == '\0')
+		return 1;
+	else if (!memchr(s, '@', len) && (p[len] == '@'))
+		return 1;
+	else
+		return 0;
+const char *fdt_string(const void *fdt, int stroffset)
+	return (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset;
+static int _fdt_string_eq(const void *fdt, int stroffset,
+	const char *p = fdt_string(fdt, stroffset);
+	return (strlen(p) == len) && (memcmp(p, s, len) == 0);
+int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size)
+	*address = fdt64_to_cpu(_fdt_mem_rsv(fdt, n)->address);
+	*size = fdt64_to_cpu(_fdt_mem_rsv(fdt, n)->size);
+	return 0;
+int fdt_num_mem_rsv(const void *fdt)
+	int i = 0;
+	while (fdt64_to_cpu(_fdt_mem_rsv(fdt, i)->size) != 0)
+		i++;
+	return i;
+static int _nextprop(const void *fdt, int offset)
+	uint32_t tag;
+	int nextoffset;
+	do {
+		switch (tag) {
+		case FDT_END:
+			if (nextoffset >= 0)
+				return -FDT_ERR_BADSTRUCTURE;
+			else
+		case FDT_PROP:
+			return offset;
+	} while (tag == FDT_NOP);
+int fdt_subnode_offset_namelen(const void *fdt, int offset,
+			       const char *name, int namelen)
+	int depth;
+	for (depth = 0;
+	     (offset >= 0) && (depth >= 0);
+	     offset = fdt_next_node(fdt, offset, &depth))
+		if ((depth == 1)
+		    && _fdt_nodename_eq(fdt, offset, name, namelen))
+			return offset;
+	if (depth < 0)
+	return offset; /* error */
+int fdt_subnode_offset(const void *fdt, int parentoffset,
+		       const char *name)
+	return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name));
+int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen)
+	const char *end = path + namelen;
+	const char *p = path;
+	int offset = 0;
+	/* see if we have an alias */
+	if (*path != '/') {
+		const char *q = memchr(path, '/', end - p);
+		if (!q)
+			q = end;
+		p = fdt_get_alias_namelen(fdt, p, q - p);
+		if (!p)
+			return -FDT_ERR_BADPATH;
+		offset = fdt_path_offset(fdt, p);
+		p = q;
+	while (p < end) {
+		const char *q;
+		while (*p == '/') {
+			p++;
+			if (p == end)
+				return offset;
+		q = memchr(p, '/', end - p);
+		if (! q)
+			q = end;
+		offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p);
+		if (offset < 0)
+			return offset;
+		p = q;
+	return offset;
+int fdt_path_offset(const void *fdt, const char *path)
+	return fdt_path_offset_namelen(fdt, path, strlen(path));
+const char *fdt_get_name(const void *fdt, int nodeoffset, int *len)
+	const struct fdt_node_header *nh = _fdt_offset_ptr(fdt, nodeoffset);
+	int err;
+	if (((err = fdt_check_header(fdt)) != 0)
+	    || ((err = _fdt_check_node_offset(fdt, nodeoffset)) < 0))
+			goto fail;
+	if (len)
+		*len = strlen(nh->name);
+	return nh->name;
+ fail:
+	if (len)
+		*len = err;
+	return NULL;
+int fdt_first_property_offset(const void *fdt, int nodeoffset)
+	int offset;
+	if ((offset = _fdt_check_node_offset(fdt, nodeoffset)) < 0)
+		return offset;
+	return _nextprop(fdt, offset);
+int fdt_next_property_offset(const void *fdt, int offset)
+	if ((offset = _fdt_check_prop_offset(fdt, offset)) < 0)
+		return offset;
+const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
+						      int offset,
+						      int *lenp)
+	int err;
+	const struct fdt_property *prop;
+	if ((err = _fdt_check_prop_offset(fdt, offset)) < 0) {
+		if (lenp)
+			*lenp = err;
+		return NULL;
+	prop = _fdt_offset_ptr(fdt, offset);
+	if (lenp)
+		*lenp = fdt32_to_cpu(prop->len);
+	return prop;
+const struct fdt_property *fdt_get_property_namelen(const void *fdt,
+						    int offset,
+						    const char *name,
+						    int namelen, int *lenp)
+	for (offset = fdt_first_property_offset(fdt, offset);
+	     (offset >= 0);
+	     (offset = fdt_next_property_offset(fdt, offset))) {
+		if (!(prop = fdt_get_property_by_offset(fdt, offset, lenp))) {
+			offset = -FDT_ERR_INTERNAL;
+			break;
+		if (_fdt_string_eq(fdt, fdt32_to_cpu(prop->nameoff),
+				   name, namelen))
+			return prop;
+	if (lenp)
+		*lenp = offset;
+	return NULL;
+const struct fdt_property *fdt_get_property(const void *fdt,
+					    int nodeoffset,
+					    const char *name, int *lenp)
+	return fdt_get_property_namelen(fdt, nodeoffset, name,
+					strlen(name), lenp);
+const void *fdt_getprop_namelen(const void *fdt, int nodeoffset,
+				const char *name, int namelen, int *lenp)
+	prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp);
+	if (! prop)
+		return NULL;
+	return prop->data;
+const void *fdt_getprop_by_offset(const void *fdt, int offset,
+				  const char **namep, int *lenp)
+	prop = fdt_get_property_by_offset(fdt, offset, lenp);
+	if (!prop)
+		return NULL;
+	if (namep)
+		*namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
+const void *fdt_getprop(const void *fdt, int nodeoffset,
+	return fdt_getprop_namelen(fdt, nodeoffset, name, strlen(name), lenp);
+uint32_t fdt_get_phandle(const void *fdt, int nodeoffset)
+	const fdt32_t *php;
+	int len;
+	/* FIXME: This is a bit sub-optimal, since we potentially scan
+	 * over all the properties twice. */
+	php = fdt_getprop(fdt, nodeoffset, "phandle", &len);
+	if (!php || (len != sizeof(*php))) {
+		php = fdt_getprop(fdt, nodeoffset, "linux,phandle", &len);
+			return 0;
+	return fdt32_to_cpu(*php);
+const char *fdt_get_alias_namelen(const void *fdt,
+	int aliasoffset;
+	aliasoffset = fdt_path_offset(fdt, "/aliases");
+	if (aliasoffset < 0)
+		return NULL;
+	return fdt_getprop_namelen(fdt, aliasoffset, name, namelen, NULL);
+const char *fdt_get_alias(const void *fdt, const char *name)
+	return fdt_get_alias_namelen(fdt, name, strlen(name));
+int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen)
+	int pdepth = 0, p = 0;
+	int offset, depth, namelen;
+	const char *name;
+	if (buflen < 2)
+	for (offset = 0, depth = 0;
+	     (offset >= 0) && (offset <= nodeoffset);
+	     offset = fdt_next_node(fdt, offset, &depth)) {
+		while (pdepth > depth) {
+			do {
+				p--;
+			} while (buf[p-1] != '/');
+			pdepth--;
+		if (pdepth >= depth) {
+			name = fdt_get_name(fdt, offset, &namelen);
+			if (!name)
+				return namelen;
+			if ((p + namelen + 1) <= buflen) {
+				memcpy(buf + p, name, namelen);
+				p += namelen;
+				buf[p++] = '/';
+				pdepth++;
+		if (offset == nodeoffset) {
+			if (pdepth < (depth + 1))
+			if (p > 1) /* special case so that root path is "/", not "" */
+				p--;
+			buf[p] = '\0';
+			return 0;
+	if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0))
+	else if (offset == -FDT_ERR_BADOFFSET)
+	return offset; /* error from fdt_next_node() */
+int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset,
+				 int supernodedepth, int *nodedepth)
+	int offset, depth;
+	int supernodeoffset = -FDT_ERR_INTERNAL;
+	if (supernodedepth < 0)
+		if (depth == supernodedepth)
+			supernodeoffset = offset;
+			if (nodedepth)
+				*nodedepth = depth;
+			if (supernodedepth > depth)
+			else
+				return supernodeoffset;
+int fdt_node_depth(const void *fdt, int nodeoffset)
+	int nodedepth;
+	int err;
+	err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth);
+	if (err)
+		return (err < 0) ? err : -FDT_ERR_INTERNAL;
+	return nodedepth;
+int fdt_parent_offset(const void *fdt, int nodeoffset)
+	int nodedepth = fdt_node_depth(fdt, nodeoffset);
+	if (nodedepth < 0)
+		return nodedepth;
+	return fdt_supernode_atdepth_offset(fdt, nodeoffset,
+					    nodedepth - 1, NULL);
+int fdt_node_offset_by_prop_value(const void *fdt, int startoffset,
+				  const char *propname,
+				  const void *propval, int proplen)
+	int offset;
+	const void *val;
+	int len;
+	/* FIXME: The algorithm here is pretty horrible: we scan each
+	 * property of a node in fdt_getprop(), then if that didn't
+	 * find what we want, we scan over them again making our way
+	 * to the next node.  Still it's the easiest to implement
+	 * approach; performance can come later. */
+	for (offset = fdt_next_node(fdt, startoffset, NULL);
+	     offset >= 0;
+	     offset = fdt_next_node(fdt, offset, NULL)) {
+		val = fdt_getprop(fdt, offset, propname, &len);
+		if (val && (len == proplen)
+		    && (memcmp(val, propval, len) == 0))
+			return offset;
+int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle)
+	int offset;
+	if ((phandle == 0) || (phandle == -1))
+		return -FDT_ERR_BADPHANDLE;
+	 * potentially scan each property of a node in
+	 * fdt_get_phandle(), then if that didn't find what
+	 * we want, we scan over them again making our way to the next
+	 * node.  Still it's the easiest to implement approach;
+	 * performance can come later. */
+	for (offset = fdt_next_node(fdt, -1, NULL);
+	     offset >= 0;
+		if (fdt_get_phandle(fdt, offset) == phandle)
+			return offset;
+int fdt_stringlist_contains(const char *strlist, int listlen, const char *str)
+	int len = strlen(str);
+	const char *p;
+	while (listlen >= len) {
+		if (memcmp(str, strlist, len+1) == 0)
+			return 1;
+		p = memchr(strlist, '\0', listlen);
+		if (!p)
+			return 0; /* malformed strlist.. */
+		listlen -= (p-strlist) + 1;
+		strlist = p + 1;
+	return 0;
+int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property)
+	const char *list, *end;
+	int length, count = 0;
+	list = fdt_getprop(fdt, nodeoffset, property, &length);
+	if (!list)
+		return -length;
+	end = list + length;
+	while (list < end) {
+		length = strnlen(list, end - list) + 1;
+		/* Abort if the last string isn't properly NUL-terminated. */
+		if (list + length > end)
+			return -FDT_ERR_BADVALUE;
+		list += length;
+		count++;
+	return count;
+int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property,
+			  const char *string)
+	int length, len, idx = 0;
+	if (!list)
+		return -length;
+	len = strlen(string) + 1;
+		if (length == len && memcmp(list, string, length) == 0)
+			return idx;
+		list += length;
+		idx++;
+const char *fdt_stringlist_get(const void *fdt, int nodeoffset,
+			       const char *property, int idx,
+			       int *lenp)
+	int length;
+	if (!list) {
+		if (lenp)
+			*lenp = length;
+		return NULL;
+		if (list + length > end) {
+			if (lenp)
+				*lenp = -FDT_ERR_BADVALUE;
+			return NULL;
+		if (idx == 0) {
+			if (lenp)
+				*lenp = length - 1;
+			return list;
+		list += length;
+		idx--;
+	if (lenp)
+		*lenp = -FDT_ERR_NOTFOUND;
+	return NULL;
+int fdt_node_check_compatible(const void *fdt, int nodeoffset,
+			      const char *compatible)
+	const void *prop;
+	int len;
+	prop = fdt_getprop(fdt, nodeoffset, "compatible", &len);
+	if (!prop)
+		return len;
+	if (fdt_stringlist_contains(prop, len, compatible))
+		return 0;
+	else
+		return 1;
+int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
+	int offset, err;
+	 * property of a node in fdt_node_check_compatible(), then if
+	 * that didn't find what we want, we scan over them again
+	 * making our way to the next node.  Still it's the easiest to
+	 * implement approach; performance can come later. */
+	     offset >= 0;
+		err = fdt_node_check_compatible(fdt, offset, compatible);
+		if ((err < 0) && (err != -FDT_ERR_NOTFOUND))
+			return err;
+		else if (err == 0)
+			return offset;
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 0000000..70adec6
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -0,0 +1,492 @@
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+static int _fdt_blocks_misordered(const void *fdt,
+			      int mem_rsv_size, int struct_size)
+	return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8))
+		|| (fdt_off_dt_struct(fdt) <
+		    (fdt_off_mem_rsvmap(fdt) + mem_rsv_size))
+		|| (fdt_off_dt_strings(fdt) <
+		    (fdt_off_dt_struct(fdt) + struct_size))
+		|| (fdt_totalsize(fdt) <
+		    (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt)));
+static int _fdt_rw_check_header(void *fdt)
+	if (fdt_version(fdt) < 17)
+	if (_fdt_blocks_misordered(fdt, sizeof(struct fdt_reserve_entry),
+				   fdt_size_dt_struct(fdt)))
+		return -FDT_ERR_BADLAYOUT;
+	if (fdt_version(fdt) > 17)
+		fdt_set_version(fdt, 17);
+	return 0;
+#define FDT_RW_CHECK_HEADER(fdt) \
+		int __err; \
+		if ((__err = _fdt_rw_check_header(fdt)) != 0) \
+			return __err; \
+static inline int _fdt_data_size(void *fdt)
+	return fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt);
+static int _fdt_splice(void *fdt, void *splicepoint, int oldlen, int newlen)
+	char *p = splicepoint;
+	char *end = (char *)fdt + _fdt_data_size(fdt);
+	if (((p + oldlen) < p) || ((p + oldlen) > end))
+	if ((end - oldlen + newlen) > ((char *)fdt + fdt_totalsize(fdt)))
+	memmove(p + newlen, p + oldlen, end - p - oldlen);
+	return 0;
+static int _fdt_splice_mem_rsv(void *fdt, struct fdt_reserve_entry *p,
+			       int oldn, int newn)
+	int delta = (newn - oldn) * sizeof(*p);
+	int err;
+	err = _fdt_splice(fdt, p, oldn * sizeof(*p), newn * sizeof(*p));
+	if (err)
+		return err;
+	fdt_set_off_dt_struct(fdt, fdt_off_dt_struct(fdt) + delta);
+	fdt_set_off_dt_strings(fdt, fdt_off_dt_strings(fdt) + delta);
+	return 0;
+static int _fdt_splice_struct(void *fdt, void *p,
+			      int oldlen, int newlen)
+	int delta = newlen - oldlen;
+	int err;
+	if ((err = _fdt_splice(fdt, p, oldlen, newlen)))
+		return err;
+	fdt_set_size_dt_struct(fdt, fdt_size_dt_struct(fdt) + delta);
+	return 0;
+static int _fdt_splice_string(void *fdt, int newlen)
+	void *p = (char *)fdt
+		+ fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt);
+	int err;
+	if ((err = _fdt_splice(fdt, p, 0, newlen)))
+		return err;
+	fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) + newlen);
+	return 0;
+static int _fdt_find_add_string(void *fdt, const char *s)
+	char *strtab = (char *)fdt + fdt_off_dt_strings(fdt);
+	const char *p;
+	char *new;
+	int err;
+	p = _fdt_find_string(strtab, fdt_size_dt_strings(fdt), s);
+	if (p)
+		/* found it */
+		return (p - strtab);
+	new = strtab + fdt_size_dt_strings(fdt);
+	err = _fdt_splice_string(fdt, len);
+	if (err)
+		return err;
+	memcpy(new, s, len);
+	return (new - strtab);
+int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size)
+	struct fdt_reserve_entry *re;
+	int err;
+	FDT_RW_CHECK_HEADER(fdt);
+	re = _fdt_mem_rsv_w(fdt, fdt_num_mem_rsv(fdt));
+	err = _fdt_splice_mem_rsv(fdt, re, 0, 1);
+	if (err)
+		return err;
+	re->address = cpu_to_fdt64(address);
+	re->size = cpu_to_fdt64(size);
+	return 0;
+int fdt_del_mem_rsv(void *fdt, int n)
+	struct fdt_reserve_entry *re = _fdt_mem_rsv_w(fdt, n);
+	int err;
+	if (n >= fdt_num_mem_rsv(fdt))
+	err = _fdt_splice_mem_rsv(fdt, re, 1, 0);
+	if (err)
+		return err;
+	return 0;
+static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name,
+				int len, struct fdt_property **prop)
+	int oldlen;
+	int err;
+	*prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen);
+	if (! (*prop))
+		return oldlen;
+	if ((err = _fdt_splice_struct(fdt, (*prop)->data, FDT_TAGALIGN(oldlen),
+				      FDT_TAGALIGN(len))))
+		return err;
+	(*prop)->len = cpu_to_fdt32(len);
+	return 0;
+static int _fdt_add_property(void *fdt, int nodeoffset, const char *name,
+	int proplen;
+	int nextoffset;
+	int namestroff;
+	int err;
+	if ((nextoffset = _fdt_check_node_offset(fdt, nodeoffset)) < 0)
+	namestroff = _fdt_find_add_string(fdt, name);
+	if (namestroff < 0)
+		return namestroff;
+	*prop = _fdt_offset_ptr_w(fdt, nextoffset);
+	proplen = sizeof(**prop) + FDT_TAGALIGN(len);
+	err = _fdt_splice_struct(fdt, *prop, 0, proplen);
+	if (err)
+		return err;
+	(*prop)->tag = cpu_to_fdt32(FDT_PROP);
+	(*prop)->nameoff = cpu_to_fdt32(namestroff);
+	return 0;
+int fdt_set_name(void *fdt, int nodeoffset, const char *name)
+	char *namep;
+	int oldlen, newlen;
+	int err;
+	namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen);
+	if (!namep)
+		return oldlen;
+	newlen = strlen(name);
+	err = _fdt_splice_struct(fdt, namep, FDT_TAGALIGN(oldlen+1),
+				 FDT_TAGALIGN(newlen+1));
+	if (err)
+		return err;
+	memcpy(namep, name, newlen+1);
+	return 0;
+int fdt_setprop(void *fdt, int nodeoffset, const char *name,
+		const void *val, int len)
+	struct fdt_property *prop;
+	int err;
+	err = _fdt_resize_property(fdt, nodeoffset, name, len, &prop);
+	if (err == -FDT_ERR_NOTFOUND)
+		err = _fdt_add_property(fdt, nodeoffset, name, len, &prop);
+	if (err)
+		return err;
+	memcpy(prop->data, val, len);
+	return 0;
+int fdt_appendprop(void *fdt, int nodeoffset, const char *name,
+	int err, oldlen, newlen;
+	prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen);
+	if (prop) {
+		newlen = len + oldlen;
+		err = _fdt_splice_struct(fdt, prop->data,
+					 FDT_TAGALIGN(oldlen),
+					 FDT_TAGALIGN(newlen));
+		if (err)
+			return err;
+		prop->len = cpu_to_fdt32(newlen);
+		memcpy(prop->data + oldlen, val, len);
+	} else {
+		if (err)
+			return err;
+	return 0;
+int fdt_delprop(void *fdt, int nodeoffset, const char *name)
+	int len, proplen;
+	prop = fdt_get_property_w(fdt, nodeoffset, name, &len);
+	if (! prop)
+		return len;
+	proplen = sizeof(*prop) + FDT_TAGALIGN(len);
+	return _fdt_splice_struct(fdt, prop, proplen, 0);
+int fdt_add_subnode_namelen(void *fdt, int parentoffset,
+	struct fdt_node_header *nh;
+	int offset, nextoffset;
+	int nodelen;
+	int err;
+	uint32_t tag;
+	fdt32_t *endtag;
+	offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen);
+	if (offset >= 0)
+		return -FDT_ERR_EXISTS;
+	else if (offset != -FDT_ERR_NOTFOUND)
+		return offset;
+	/* Try to place the new node after the parent's properties */
+	fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
+	do {
+	} while ((tag == FDT_PROP) || (tag == FDT_NOP));
+	nh = _fdt_offset_ptr_w(fdt, offset);
+	nodelen = sizeof(*nh) + FDT_TAGALIGN(namelen+1) + FDT_TAGSIZE;
+	err = _fdt_splice_struct(fdt, nh, 0, nodelen);
+	if (err)
+		return err;
+	nh->tag = cpu_to_fdt32(FDT_BEGIN_NODE);
+	memset(nh->name, 0, FDT_TAGALIGN(namelen+1));
+	memcpy(nh->name, name, namelen);
+	endtag = (fdt32_t *)((char *)nh + nodelen - FDT_TAGSIZE);
+	*endtag = cpu_to_fdt32(FDT_END_NODE);
+	return offset;
+int fdt_add_subnode(void *fdt, int parentoffset, const char *name)
+	return fdt_add_subnode_namelen(fdt, parentoffset, name, strlen(name));
+int fdt_del_node(void *fdt, int nodeoffset)
+	int endoffset;
+	endoffset = _fdt_node_end_offset(fdt, nodeoffset);
+	if (endoffset < 0)
+		return endoffset;
+	return _fdt_splice_struct(fdt, _fdt_offset_ptr_w(fdt, nodeoffset),
+				  endoffset - nodeoffset, 0);
+static void _fdt_packblocks(const char *old, char *new,
+	int mem_rsv_off, struct_off, strings_off;
+	mem_rsv_off = FDT_ALIGN(sizeof(struct fdt_header), 8);
+	struct_off = mem_rsv_off + mem_rsv_size;
+	strings_off = struct_off + struct_size;
+	memmove(new + mem_rsv_off, old + fdt_off_mem_rsvmap(old), mem_rsv_size);
+	fdt_set_off_mem_rsvmap(new, mem_rsv_off);
+	memmove(new + struct_off, old + fdt_off_dt_struct(old), struct_size);
+	fdt_set_off_dt_struct(new, struct_off);
+	fdt_set_size_dt_struct(new, struct_size);
+	memmove(new + strings_off, old + fdt_off_dt_strings(old),
+		fdt_size_dt_strings(old));
+	fdt_set_off_dt_strings(new, strings_off);
+	fdt_set_size_dt_strings(new, fdt_size_dt_strings(old));
+int fdt_open_into(const void *fdt, void *buf, int bufsize)
+	int err;
+	int mem_rsv_size, struct_size;
+	int newsize;
+	const char *fdtstart = fdt;
+	const char *fdtend = fdtstart + fdt_totalsize(fdt);
+	char *tmp;
+	mem_rsv_size = (fdt_num_mem_rsv(fdt)+1)
+		* sizeof(struct fdt_reserve_entry);
+	if (fdt_version(fdt) >= 17) {
+		struct_size = fdt_size_dt_struct(fdt);
+	} else {
+		struct_size = 0;
+		while (fdt_next_tag(fdt, struct_size, &struct_size) != FDT_END)
+		if (struct_size < 0)
+			return struct_size;
+	if (!_fdt_blocks_misordered(fdt, mem_rsv_size, struct_size)) {
+		/* no further work necessary */
+		err = fdt_move(fdt, buf, bufsize);
+		if (err)
+			return err;
+		fdt_set_version(buf, 17);
+		fdt_set_size_dt_struct(buf, struct_size);
+		fdt_set_totalsize(buf, bufsize);
+		return 0;
+	/* Need to reorder */
+	newsize = FDT_ALIGN(sizeof(struct fdt_header), 8) + mem_rsv_size
+		+ struct_size + fdt_size_dt_strings(fdt);
+	if (bufsize < newsize)
+	/* First attempt to build converted tree at beginning of buffer */
+	tmp = buf;
+	/* But if that overlaps with the old tree... */
+	if (((tmp + newsize) > fdtstart) && (tmp < fdtend)) {
+		/* Try right after the old tree instead */
+		tmp = (char *)(uintptr_t)fdtend;
+		if ((tmp + newsize) > ((char *)buf + bufsize))
+	_fdt_packblocks(fdt, tmp, mem_rsv_size, struct_size);
+	memmove(buf, tmp, newsize);
+	fdt_set_magic(buf, FDT_MAGIC);
+	fdt_set_last_comp_version(buf, 16);
+	fdt_set_boot_cpuid_phys(buf, fdt_boot_cpuid_phys(fdt));
+	return 0;
+int fdt_pack(void *fdt)
+	int mem_rsv_size;
+	_fdt_packblocks(fdt, fdt, mem_rsv_size, fdt_size_dt_struct(fdt));
+	fdt_set_totalsize(fdt, _fdt_data_size(fdt));
+	return 0;
diff --git a/cpukit/dtc/libfdt/fdt_strerror.c b/cpukit/dtc/libfdt/fdt_strerror.c
index 0000000..e6c3cee
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_strerror.c
@@ -0,0 +1,96 @@
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+struct fdt_errtabent {
+	const char *str;
+#define FDT_ERRTABENT(val) \
+	[(val)] = { .str = #val, }
+static struct fdt_errtabent fdt_errtable[] = {
+	FDT_ERRTABENT(FDT_ERR_NOTFOUND),
+	FDT_ERRTABENT(FDT_ERR_EXISTS),
+	FDT_ERRTABENT(FDT_ERR_NOSPACE),
+	FDT_ERRTABENT(FDT_ERR_BADOFFSET),
+	FDT_ERRTABENT(FDT_ERR_BADPATH),
+	FDT_ERRTABENT(FDT_ERR_BADSTATE),
+	FDT_ERRTABENT(FDT_ERR_TRUNCATED),
+	FDT_ERRTABENT(FDT_ERR_BADMAGIC),
+	FDT_ERRTABENT(FDT_ERR_BADVERSION),
+	FDT_ERRTABENT(FDT_ERR_BADSTRUCTURE),
+	FDT_ERRTABENT(FDT_ERR_BADLAYOUT),
+#define FDT_ERRTABSIZE	(sizeof(fdt_errtable) / sizeof(fdt_errtable[0]))
+const char *fdt_strerror(int errval)
+	if (errval > 0)
+		return "<valid offset/length>";
+	else if (errval == 0)
+		return "<no error>";
+	else if (errval > -FDT_ERRTABSIZE) {
+		const char *s = fdt_errtable[-errval].str;
+		if (s)
+			return s;
+	return "<unknown error>";
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 0000000..6a80485
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -0,0 +1,288 @@
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+static int _fdt_sw_check_header(void *fdt)
+	if (fdt_magic(fdt) != FDT_SW_MAGIC)
+	/* FIXME: should check more details about the header state */
+	return 0;
+#define FDT_SW_CHECK_HEADER(fdt) \
+		int err; \
+		if ((err = _fdt_sw_check_header(fdt)) != 0) \
+			return err; \
+static void *_fdt_grab_space(void *fdt, size_t len)
+	int offset = fdt_size_dt_struct(fdt);
+	int spaceleft;
+	spaceleft = fdt_totalsize(fdt) - fdt_off_dt_struct(fdt)
+		- fdt_size_dt_strings(fdt);
+	if ((offset + len < offset) || (offset + len > spaceleft))
+		return NULL;
+	fdt_set_size_dt_struct(fdt, offset + len);
+	return _fdt_offset_ptr_w(fdt, offset);
+int fdt_create(void *buf, int bufsize)
+	void *fdt = buf;
+	if (bufsize < sizeof(struct fdt_header))
+	memset(buf, 0, bufsize);
+	fdt_set_magic(fdt, FDT_SW_MAGIC);
+	fdt_set_version(fdt, FDT_LAST_SUPPORTED_VERSION);
+	fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION);
+	fdt_set_totalsize(fdt,  bufsize);
+	fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header),
+					      sizeof(struct fdt_reserve_entry)));
+	fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt));
+	fdt_set_off_dt_strings(fdt, bufsize);
+	return 0;
+int fdt_resize(void *fdt, void *buf, int bufsize)
+	size_t headsize, tailsize;
+	char *oldtail, *newtail;
+	FDT_SW_CHECK_HEADER(fdt);
+	headsize = fdt_off_dt_struct(fdt);
+	tailsize = fdt_size_dt_strings(fdt);
+	if ((headsize + tailsize) > bufsize)
+	oldtail = (char *)fdt + fdt_totalsize(fdt) - tailsize;
+	newtail = (char *)buf + bufsize - tailsize;
+	/* Two cases to avoid clobbering data if the old and new
+	 * buffers partially overlap */
+	if (buf <= fdt) {
+		memmove(buf, fdt, headsize);
+		memmove(newtail, oldtail, tailsize);
+	} else {
+	fdt_set_off_dt_strings(buf, bufsize);
+	return 0;
+int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
+	int offset;
+	if (fdt_size_dt_struct(fdt))
+	offset = fdt_off_dt_struct(fdt);
+	if ((offset + sizeof(*re)) > fdt_totalsize(fdt))
+	re = (struct fdt_reserve_entry *)((char *)fdt + offset);
+	re->address = cpu_to_fdt64(addr);
+	fdt_set_off_dt_struct(fdt, offset + sizeof(*re));
+	return 0;
+int fdt_finish_reservemap(void *fdt)
+	return fdt_add_reservemap_entry(fdt, 0, 0);
+int fdt_begin_node(void *fdt, const char *name)
+	int namelen = strlen(name) + 1;
+	nh = _fdt_grab_space(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen));
+	if (! nh)
+	return 0;
+int fdt_end_node(void *fdt)
+	fdt32_t *en;
+	en = _fdt_grab_space(fdt, FDT_TAGSIZE);
+	if (! en)
+	*en = cpu_to_fdt32(FDT_END_NODE);
+	return 0;
+	char *strtab = (char *)fdt + fdt_totalsize(fdt);
+	const char *p;
+	int strtabsize = fdt_size_dt_strings(fdt);
+	int struct_top, offset;
+	p = _fdt_find_string(strtab - strtabsize, strtabsize, s);
+	if (p)
+		return p - strtab;
+	/* Add it */
+	offset = -strtabsize - len;
+	struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
+	if (fdt_totalsize(fdt) + offset < struct_top)
+		return 0; /* no more room :( */
+	memcpy(strtab + offset, s, len);
+	fdt_set_size_dt_strings(fdt, strtabsize + len);
+	return offset;
+int fdt_property(void *fdt, const char *name, const void *val, int len)
+	int nameoff;
+	nameoff = _fdt_find_add_string(fdt, name);
+	if (nameoff == 0)
+	prop = _fdt_grab_space(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
+	if (! prop)
+	prop->tag = cpu_to_fdt32(FDT_PROP);
+	prop->nameoff = cpu_to_fdt32(nameoff);
+	prop->len = cpu_to_fdt32(len);
+	return 0;
+int fdt_finish(void *fdt)
+	char *p = (char *)fdt;
+	fdt32_t *end;
+	int oldstroffset, newstroffset;
+	uint32_t tag;
+	/* Add terminator */
+	end = _fdt_grab_space(fdt, sizeof(*end));
+	if (! end)
+	*end = cpu_to_fdt32(FDT_END);
+	/* Relocate the string table */
+	oldstroffset = fdt_totalsize(fdt) - fdt_size_dt_strings(fdt);
+	newstroffset = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
+	memmove(p + newstroffset, p + oldstroffset, fdt_size_dt_strings(fdt));
+	fdt_set_off_dt_strings(fdt, newstroffset);
+	/* Walk the structure, correcting string offsets */
+	offset = 0;
+	while ((tag = fdt_next_tag(fdt, offset, &nextoffset)) != FDT_END) {
+		if (tag == FDT_PROP) {
+			struct fdt_property *prop =
+				_fdt_offset_ptr_w(fdt, offset);
+			int nameoff;
+			nameoff = fdt32_to_cpu(prop->nameoff);
+			nameoff += fdt_size_dt_strings(fdt);
+	if (nextoffset < 0)
+	/* Finally, adjust the header */
+	fdt_set_totalsize(fdt, newstroffset + fdt_size_dt_strings(fdt));
+	fdt_set_magic(fdt, FDT_MAGIC);
+	return 0;
diff --git a/cpukit/dtc/libfdt/fdt_wip.c b/cpukit/dtc/libfdt/fdt_wip.c
index 0000000..c5bbb68
--- /dev/null
+++ b/cpukit/dtc/libfdt/fdt_wip.c
@@ -0,0 +1,118 @@
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name,
+	void *propval;
+	int proplen;
+	propval = fdt_getprop_w(fdt, nodeoffset, name, &proplen);
+	if (! propval)
+		return proplen;
+	if (proplen != len)
+	memcpy(propval, val, len);
+	return 0;
+static void _fdt_nop_region(void *start, int len)
+	fdt32_t *p;
+	for (p = start; (char *)p < ((char *)start + len); p++)
+		*p = cpu_to_fdt32(FDT_NOP);
+int fdt_nop_property(void *fdt, int nodeoffset, const char *name)
+	int len;
+	if (! prop)
+		return len;
+	_fdt_nop_region(prop, len + sizeof(*prop));
+	return 0;
+int _fdt_node_end_offset(void *fdt, int offset)
+	int depth = 0;
+	while ((offset >= 0) && (depth >= 0))
+	return offset;
+int fdt_nop_node(void *fdt, int nodeoffset)
+	int endoffset;
+		return endoffset;
+	_fdt_nop_region(fdt_offset_ptr_w(fdt, nodeoffset, 0),
+			endoffset - nodeoffset);
+	return 0;
diff --git a/cpukit/dtc/libfdt/libfdt.h b/cpukit/dtc/libfdt/libfdt.h
index 0000000..78adb12
--- /dev/null
+++ b/cpukit/dtc/libfdt/libfdt.h
@@ -0,0 +1,1653 @@
+#ifndef _LIBFDT_H
+#define _LIBFDT_H
+ * Alternatively,
+ *        disclaimer.
+#include <libfdt_env.h>
+#include <fdt.h>
+#define FDT_FIRST_SUPPORTED_VERSION	0x10
+#define FDT_LAST_SUPPORTED_VERSION	0x11
+/* Error codes: informative error codes */
+#define FDT_ERR_NOTFOUND	1
+	/* FDT_ERR_NOTFOUND: The requested node or property does not exist */
+#define FDT_ERR_EXISTS		2
+	/* FDT_ERR_EXISTS: Attemped to create a node or property which
+	 * already exists */
+#define FDT_ERR_NOSPACE		3
+	/* FDT_ERR_NOSPACE: Operation needed to expand the device
+	 * tree, but its buffer did not have sufficient space to
+	 * contain the expanded tree. Use fdt_open_into() to move the
+	 * device tree to a buffer with more space. */
+/* Error codes: codes for bad parameters */
+#define FDT_ERR_BADOFFSET	4
+	/* FDT_ERR_BADOFFSET: Function was passed a structure block
+	 * offset which is out-of-bounds, or which points to an
+	 * unsuitable part of the structure for the operation. */
+#define FDT_ERR_BADPATH		5
+	/* FDT_ERR_BADPATH: Function was passed a badly formatted path
+	 * (e.g. missing a leading / for a function which requires an
+	 * absolute path) */
+#define FDT_ERR_BADPHANDLE	6
+	/* FDT_ERR_BADPHANDLE: Function was passed an invalid phandle
+	 * value.  phandle values of 0 and -1 are not permitted. */
+#define FDT_ERR_BADSTATE	7
+	/* FDT_ERR_BADSTATE: Function was passed an incomplete device
+	 * tree created by the sequential-write functions, which is
+	 * not sufficiently complete for the requested operation. */
+/* Error codes: codes for bad device tree blobs */
+#define FDT_ERR_TRUNCATED	8
+	/* FDT_ERR_TRUNCATED: Structure block of the given device tree
+	 * ends without an FDT_END tag. */
+#define FDT_ERR_BADMAGIC	9
+	/* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a
+	 * device tree at all - it is missing the flattened device
+	 * tree magic number. */
+#define FDT_ERR_BADVERSION	10
+	/* FDT_ERR_BADVERSION: Given device tree has a version which
+	 * can't be handled by the requested operation.  For
+	 * read-write functions, this may mean that fdt_open_into() is
+	 * required to convert the tree to the expected version. */
+#define FDT_ERR_BADSTRUCTURE	11
+	/* FDT_ERR_BADSTRUCTURE: Given device tree has a corrupt
+	 * structure block or other serious error (e.g. misnested
+	 * nodes, or subnodes preceding properties). */
+#define FDT_ERR_BADLAYOUT	12
+	/* FDT_ERR_BADLAYOUT: For read-write functions, the given
+	 * device tree has it's sub-blocks in an order that the
+	 * function can't handle (memory reserve map, then structure,
+	 * then strings).  Use fdt_open_into() to reorganize the tree
+	 * into a form suitable for the read-write operations. */
+/* "Can't happen" error indicating a bug in libfdt */
+#define FDT_ERR_INTERNAL	13
+	/* FDT_ERR_INTERNAL: libfdt has failed an internal assertion.
+	 * Should never be returned, if it is, it indicates a bug in
+	 * libfdt itself. */
+/* Errors in device tree content */
+#define FDT_ERR_BADNCELLS	14
+	/* FDT_ERR_BADNCELLS: Device tree has a #address-cells, #size-cells
+	 * or similar property with a bad format or value */
+#define FDT_ERR_BADVALUE	15
+	/* FDT_ERR_BADVALUE: Device tree has a property with an unexpected
+	 * value. For example: a property expected to contain a string list
+	 * is not NUL-terminated within the length of its value. */
+#define FDT_ERR_MAX		15
+/* Low-level functions (you probably don't need these)                */
+const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int checklen);
+static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen)
+	return (void *)(uintptr_t)fdt_offset_ptr(fdt, offset, checklen);
+uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
+/* Traversal functions                                                */
+int fdt_next_node(const void *fdt, int offset, int *depth);
+ * fdt_first_subnode() - get offset of first direct subnode
+ * @fdt:	FDT blob
+ * @offset:	Offset of node to check
+ * @return offset of first subnode, or -FDT_ERR_NOTFOUND if there is none
+int fdt_first_subnode(const void *fdt, int offset);
+ * fdt_next_subnode() - get offset of next direct subnode
+ * After first calling fdt_first_subnode(), call this function repeatedly to
+ * get direct subnodes of a parent node.
+ * @fdt:	FDT blob
+ * @offset:	Offset of previous subnode
+ * @return offset of next subnode, or -FDT_ERR_NOTFOUND if there are no more
+ * subnodes
+int fdt_next_subnode(const void *fdt, int offset);
+/* General functions                                                  */
+#define fdt_get_header(fdt, field) \
+	(fdt32_to_cpu(((const struct fdt_header *)(fdt))->field))
+#define fdt_magic(fdt) 			(fdt_get_header(fdt, magic))
+#define fdt_totalsize(fdt)		(fdt_get_header(fdt, totalsize))
+#define fdt_off_dt_struct(fdt)		(fdt_get_header(fdt, off_dt_struct))
+#define fdt_off_dt_strings(fdt)		(fdt_get_header(fdt, off_dt_strings))
+#define fdt_off_mem_rsvmap(fdt)		(fdt_get_header(fdt, off_mem_rsvmap))
+#define fdt_version(fdt)		(fdt_get_header(fdt, version))
+#define fdt_last_comp_version(fdt) 	(fdt_get_header(fdt, last_comp_version))
+#define fdt_boot_cpuid_phys(fdt) 	(fdt_get_header(fdt, boot_cpuid_phys))
+#define fdt_size_dt_strings(fdt) 	(fdt_get_header(fdt, size_dt_strings))
+#define fdt_size_dt_struct(fdt)		(fdt_get_header(fdt, size_dt_struct))
+#define __fdt_set_hdr(name) \
+	static inline void fdt_set_##name(void *fdt, uint32_t val) \
+		struct fdt_header *fdth = (struct fdt_header*)fdt; \
+		fdth->name = cpu_to_fdt32(val); \
+__fdt_set_hdr(magic);
+__fdt_set_hdr(totalsize);
+__fdt_set_hdr(off_dt_struct);
+__fdt_set_hdr(off_dt_strings);
+__fdt_set_hdr(off_mem_rsvmap);
+__fdt_set_hdr(version);
+__fdt_set_hdr(last_comp_version);
+__fdt_set_hdr(boot_cpuid_phys);
+__fdt_set_hdr(size_dt_strings);
+__fdt_set_hdr(size_dt_struct);
+#undef __fdt_set_hdr
+ * fdt_check_header - sanity check a device tree or possible device tree
+ * @fdt: pointer to data which might be a flattened device tree
+ * fdt_check_header() checks that the given buffer contains what
+ * appears to be a flattened device tree with sane information in its
+ * header.
+ * returns:
+ *     0, if the buffer appears to contain a valid device tree
+ *     -FDT_ERR_BADMAGIC,
+ *     -FDT_ERR_BADVERSION,
+ *     -FDT_ERR_BADSTATE, standard meanings, as above
+int fdt_check_header(const void *fdt);
+ * fdt_move - move a device tree around in memory
+ * @fdt: pointer to the device tree to move
+ * @buf: pointer to memory where the device is to be moved
+ * @bufsize: size of the memory space at buf
+ * fdt_move() relocates, if possible, the device tree blob located at
+ * fdt to the buffer at buf of size bufsize.  The buffer may overlap
+ * with the existing device tree blob at fdt.  Therefore,
+ *     fdt_move(fdt, fdt, fdt_totalsize(fdt))
+ * should always succeed.
+ * returns:
+ *     0, on success
+ *     -FDT_ERR_NOSPACE, bufsize is insufficient to contain the device tree
+int fdt_move(const void *fdt, void *buf, int bufsize);
+/* Read-only functions                                                */
+ * fdt_string - retrieve a string from the strings block of a device tree
+ * @fdt: pointer to the device tree blob
+ * @stroffset: offset of the string within the strings block (native endian)
+ * fdt_string() retrieves a pointer to a single string from the
+ * strings block of the device tree blob at fdt.
+ * returns:
+ *     a pointer to the string, on success
+ *     NULL, if stroffset is out of bounds
+const char *fdt_string(const void *fdt, int stroffset);
+ * fdt_num_mem_rsv - retrieve the number of memory reserve map entries
+ * Returns the number of entries in the device tree blob's memory
+ * reservation map.  This does not include the terminating 0,0 entry
+ * or any other (0,0) entries reserved for expansion.
+ * returns:
+ *     the number of entries
+int fdt_num_mem_rsv(const void *fdt);
+ * fdt_get_mem_rsv - retrieve one memory reserve map entry
+ * @address, @size: pointers to 64-bit variables
+ * On success, *address and *size will contain the address and size of
+ * the n-th reserve map entry from the device tree blob, in
+ * native-endian format.
+ * returns:
+ *     0, on success
+int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size);
+ * fdt_subnode_offset_namelen - find a subnode based on substring
+ * @parentoffset: structure block offset of a node
+ * @name: name of the subnode to locate
+ * @namelen: number of characters of name to consider
+ * Identical to fdt_subnode_offset(), but only examine the first
+ * namelen characters of name for matching the subnode name.  This is
+ * useful for finding subnodes based on a portion of a larger string,
+ * such as a full path.
+int fdt_subnode_offset_namelen(const void *fdt, int parentoffset,
+			       const char *name, int namelen);
+ * fdt_subnode_offset - find a subnode of a given node
+ * fdt_subnode_offset() finds a subnode of the node at structure block
+ * offset parentoffset with the given name.  name may include a unit
+ * address, in which case fdt_subnode_offset() will find the subnode
+ * with that unit address, or the unit address may be omitted, in
+ * which case fdt_subnode_offset() will find an arbitrary subnode
+ * whose name excluding unit address matches the given name.
+ * returns:
+ *	structure block offset of the requested subnode (>=0), on success
+ *	-FDT_ERR_NOTFOUND, if the requested subnode does not exist
+ *	-FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE tag
+ *	-FDT_ERR_BADSTRUCTURE,
+ *	-FDT_ERR_TRUNCATED, standard meanings.
+int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name);
+ * fdt_path_offset_namelen - find a tree node by its full path
+ * @path: full path of the node to locate
+ * @namelen: number of characters of path to consider
+ * Identical to fdt_path_offset(), but only consider the first namelen
+ * characters of path as the path name.
+int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen);
+ * fdt_path_offset - find a tree node by its full path
+ * fdt_path_offset() finds a node of a given path in the device tree.
+ * Each path component may omit the unit address portion, but the
+ * results of this are undefined if any such path component is
+ * ambiguous (that is if there are multiple nodes at the relevant
+ * level matching the given component, differentiated only by unit
+ * address).
+ * returns:
+ *	structure block offset of the node with the requested path (>=0), on success
+ *	-FDT_ERR_BADPATH, given path does not begin with '/' or is invalid
+ *	-FDT_ERR_NOTFOUND, if the requested node does not exist
+int fdt_path_offset(const void *fdt, const char *path);
+ * fdt_get_name - retrieve the name of a given node
+ * @nodeoffset: structure block offset of the starting node
+ * @lenp: pointer to an integer variable (will be overwritten) or NULL
+ * fdt_get_name() retrieves the name (including unit address) of the
+ * device tree node at structure block offset nodeoffset.  If lenp is
+ * non-NULL, the length of this name is also returned, in the integer
+ * pointed to by lenp.
+ * returns:
+ *	pointer to the node's name, on success
+ *		If lenp is non-NULL, *lenp contains the length of that name (>=0)
+ *	NULL, on error
+ *		if lenp is non-NULL *lenp contains an error code (<0):
+ *		-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
+const char *fdt_get_name(const void *fdt, int nodeoffset, int *lenp);
+ * fdt_first_property_offset - find the offset of a node's first property
+ * @nodeoffset: structure block offset of a node
+ * fdt_first_property_offset() finds the first property of the node at
+ * the given structure block offset.
+ * returns:
+ *	structure block offset of the property (>=0), on success
+ *	-FDT_ERR_NOTFOUND, if the requested node has no properties
+ *	-FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_BEGIN_NODE tag
+int fdt_first_property_offset(const void *fdt, int nodeoffset);
+ * fdt_next_property_offset - step through a node's properties
+ * @offset: structure block offset of a property
+ * fdt_next_property_offset() finds the property immediately after the
+ * one at the given structure block offset.  This will be a property
+ * of the same node as the given property.
+ * returns:
+ *	structure block offset of the next property (>=0), on success
+ *	-FDT_ERR_NOTFOUND, if the given property is the last in its node
+ *	-FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_PROP tag
+int fdt_next_property_offset(const void *fdt, int offset);
+ * fdt_get_property_by_offset - retrieve the property at a given offset
+ * @offset: offset of the property to retrieve
+ * fdt_get_property_by_offset() retrieves a pointer to the
+ * fdt_property structure within the device tree blob at the given
+ * offset.  If lenp is non-NULL, the length of the property value is
+ * also returned, in the integer pointed to by lenp.
+ * returns:
+ *	pointer to the structure representing the property
+ *		if lenp is non-NULL, *lenp contains the length of the property
+ *		value (>=0)
+ *	NULL, on error
+ *		if lenp is non-NULL, *lenp contains an error code (<0):
+ *		-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag
+						      int offset,
+						      int *lenp);
+ * fdt_get_property_namelen - find a property based on substring
+ * @nodeoffset: offset of the node whose property to find
+ * @name: name of the property to find
+ * Identical to fdt_get_property(), but only examine the first namelen
+ * characters of name for matching the property name.
+						    int nodeoffset,
+						    const char *name,
+						    int namelen, int *lenp);
+ * fdt_get_property - find a given property in a given node
+ * fdt_get_property() retrieves a pointer to the fdt_property
+ * structure within the device tree blob corresponding to the property
+ * named 'name' of the node at offset nodeoffset.  If lenp is
+ * non-NULL, the length of the property value is also returned, in the
+ * integer pointed to by lenp.
+ * returns:
+ *		value (>=0)
+ *	NULL, on error
+ *		-FDT_ERR_NOTFOUND, node does not have named property
+const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset,
+					    const char *name, int *lenp);
+static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset,
+						      const char *name,
+						      int *lenp)
+	return (struct fdt_property *)(uintptr_t)
+		fdt_get_property(fdt, nodeoffset, name, lenp);
+ * fdt_getprop_by_offset - retrieve the value of a property at a given offset
+ * @ffset: offset of the property to read
+ * @namep: pointer to a string variable (will be overwritten) or NULL
+ * fdt_getprop_by_offset() retrieves a pointer to the value of the
+ * property at structure block offset 'offset' (this will be a pointer
+ * to within the device blob itself, not a copy of the value).  If
+ * lenp is non-NULL, the length of the property value is also
+ * returned, in the integer pointed to by lenp.  If namep is non-NULL,
+ * the property's namne will also be returned in the char * pointed to
+ * by namep (this will be a pointer to within the device tree's string
+ * block, not a new copy of the name).
+ * returns:
+ *	pointer to the property's value
+ *		value (>=0)
+ *		if namep is non-NULL *namep contiains a pointer to the property
+ *		name.
+ *	NULL, on error
+				  const char **namep, int *lenp);
+ * fdt_getprop_namelen - get property value based on substring
+ * Identical to fdt_getprop(), but only examine the first namelen
+				const char *name, int namelen, int *lenp);
+ * fdt_getprop - retrieve the value of a given property
+ * fdt_getprop() retrieves a pointer to the value of the property
+ * named 'name' of the node at offset nodeoffset (this will be a
+ * pointer to within the device blob itself, not a copy of the value).
+ * If lenp is non-NULL, the length of the property value is also
+ * returns:
+ *		value (>=0)
+ *	NULL, on error
+static inline void *fdt_getprop_w(void *fdt, int nodeoffset,
+	return (void *)(uintptr_t)fdt_getprop(fdt, nodeoffset, name, lenp);
+ * fdt_get_phandle - retrieve the phandle of a given node
+ * @nodeoffset: structure block offset of the node
+ * fdt_get_phandle() retrieves the phandle of the device tree node at
+ * structure block offset nodeoffset.
+ * returns:
+ *	the phandle of the node at nodeoffset, on success (!= 0, != -1)
+ *	0, if the node has no phandle, or another error occurs
+uint32_t fdt_get_phandle(const void *fdt, int nodeoffset);
+ * fdt_get_alias_namelen - get alias based on substring
+ * @name: name of the alias th look up
+ * Identical to fdt_get_alias(), but only examine the first namelen
+ * characters of name for matching the alias name.
+ * fdt_get_alias - retreive the path referenced by a given alias
+ * fdt_get_alias() retrieves the value of a given alias.  That is, the
+ * value of the property named 'name' in the node /aliases.
+ * returns:
+ *	a pointer to the expansion of the alias named 'name', if it exists
+ *	NULL, if the given alias or the /aliases node does not exist
+const char *fdt_get_alias(const void *fdt, const char *name);
+ * fdt_get_path - determine the full path of a node
+ * @nodeoffset: offset of the node whose path to find
+ * @buf: character buffer to contain the returned path (will be overwritten)
+ * @buflen: size of the character buffer at buf
+ * fdt_get_path() computes the full path of the node at offset
+ * nodeoffset, and records that path in the buffer at buf.
+ * NOTE: This function is expensive, as it must scan the device tree
+ * structure from the start to nodeoffset.
+ * returns:
+ *	0, on success
+ *		buf contains the absolute path of the node at
+ *		nodeoffset, as a NUL-terminated string.
+ * 	-FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag
+ *	-FDT_ERR_NOSPACE, the path of the given node is longer than (bufsize-1)
+ *		characters and will not fit in the given buffer.
+ *	-FDT_ERR_BADSTRUCTURE, standard meanings
+int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen);
+ * fdt_supernode_atdepth_offset - find a specific ancestor of a node
+ * @nodeoffset: offset of the node whose parent to find
+ * @supernodedepth: depth of the ancestor to find
+ * @nodedepth: pointer to an integer variable (will be overwritten) or NULL
+ * fdt_supernode_atdepth_offset() finds an ancestor of the given node
+ * at a specific depth from the root (where the root itself has depth
+ * 0, its immediate subnodes depth 1 and so forth).  So
+ *	fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, NULL);
+ * will always return 0, the offset of the root node.  If the node at
+ * nodeoffset has depth D, then:
+ *	fdt_supernode_atdepth_offset(fdt, nodeoffset, D, NULL);
+ * will return nodeoffset itself.
+ * returns:
+ *	structure block offset of the node at node offset's ancestor
+ *		of depth supernodedepth (>=0), on success
+*	-FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of nodeoffset
+				 int supernodedepth, int *nodedepth);
+ * fdt_node_depth - find the depth of a given node
+ * fdt_node_depth() finds the depth of a given node.  The root node
+ * has depth 0, its immediate subnodes depth 1 and so forth.
+ * returns:
+ *	depth of the node at nodeoffset (>=0), on success
+int fdt_node_depth(const void *fdt, int nodeoffset);
+ * fdt_parent_offset - find the parent of a given node
+ * fdt_parent_offset() locates the parent node of a given node (that
+ * is, it finds the offset of the node which contains the node at
+ * nodeoffset as a subnode).
+ * structure from the start to nodeoffset, *twice*.
+ * returns:
+ *	structure block offset of the parent of the node at nodeoffset
+ *		(>=0), on success
+int fdt_parent_offset(const void *fdt, int nodeoffset);
+ * fdt_node_offset_by_prop_value - find nodes with a given property value
+ * @startoffset: only find nodes after this offset
+ * @propname: property name to check
+ * @propval: property value to search for
+ * @proplen: length of the value in propval
+ * fdt_node_offset_by_prop_value() returns the offset of the first
+ * node after startoffset, which has a property named propname whose
+ * value is of length proplen and has value equal to propval; or if
+ * startoffset is -1, the very first such node in the tree.
+ * To iterate through all nodes matching the criterion, the following
+ * idiom can be used:
+ *	offset = fdt_node_offset_by_prop_value(fdt, -1, propname,
+ *					       propval, proplen);
+ *	while (offset != -FDT_ERR_NOTFOUND) {
+ *		// other code here
+ *		offset = fdt_node_offset_by_prop_value(fdt, offset, propname,
+ * Note the -1 in the first call to the function, if 0 is used here
+ * instead, the function will never locate the root node, even if it
+ * matches the criterion.
+ * returns:
+ *	structure block offset of the located node (>= 0, >startoffset),
+ *		 on success
+ *	-FDT_ERR_NOTFOUND, no node matching the criterion exists in the
+ *		tree after startoffset
+				  const void *propval, int proplen);
+ * fdt_node_offset_by_phandle - find the node with a given phandle
+ * @phandle: phandle value
+ * fdt_node_offset_by_phandle() returns the offset of the node
+ * which has the given phandle value.  If there is more than one node
+ * in the tree with the given phandle (an invalid tree), results are
+ * undefined.
+ * returns:
+ *	structure block offset of the located node (>= 0), on success
+ *	-FDT_ERR_NOTFOUND, no node with that phandle exists
+ *	-FDT_ERR_BADPHANDLE, given phandle value was invalid (0 or -1)
+int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle);
+ * fdt_node_check_compatible: check a node's compatible property
+ * @nodeoffset: offset of a tree node
+ * @compatible: string to match against
+ * fdt_node_check_compatible() returns 0 if the given node contains a
+ * 'compatible' property with the given string as one of its elements,
+ * it returns non-zero otherwise, or on error.
+ * returns:
+ *	0, if the node has a 'compatible' property listing the given string
+ *	1, if the node has a 'compatible' property, but it does not list
+ *		the given string
+ *	-FDT_ERR_NOTFOUND, if the given node has no 'compatible' property
+ * 	-FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag
+			      const char *compatible);
+ * fdt_node_offset_by_compatible - find nodes with a given 'compatible' value
+ * @compatible: 'compatible' string to match against
+ * fdt_node_offset_by_compatible() returns the offset of the first
+ * node after startoffset, which has a 'compatible' property which
+ * lists the given compatible string; or if startoffset is -1, the
+ * very first such node in the tree.
+ *	offset = fdt_node_offset_by_compatible(fdt, -1, compatible);
+ *		offset = fdt_node_offset_by_compatible(fdt, offset, compatible);
+ * returns:
+ *		 on success
+ * fdt_stringlist_contains - check a string list property for a string
+ * @strlist: Property containing a list of strings to check
+ * @listlen: Length of property
+ * @str: String to search for
+ * This is a utility function provided for convenience. The list contains
+ * one or more strings, each terminated by \0, as is found in a device tree
+ * "compatible" property.
+ * @return: 1 if the string is found in the list, 0 not found, or invalid list
+int fdt_stringlist_contains(const char *strlist, int listlen, const char *str);
+ * fdt_stringlist_count - count the number of strings in a string list
+ * @property: name of the property containing the string list
+ * @return:
+ *   the number of strings in the given property
+ *   -FDT_ERR_BADVALUE if the property value is not NUL-terminated
+ *   -FDT_ERR_NOTFOUND if the property does not exist
+int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property);
+ * fdt_stringlist_search - find a string in a string list and return its index
+ * @string: string to look up in the string list
+ * Note that it is possible for this function to succeed on property values
+ * that are not NUL-terminated. That's because the function will stop after
+ * finding the first occurrence of @string. This can for example happen with
+ * small-valued cell properties, such as #address-cells, when searching for
+ * the empty string.
+ * @return:
+ *   the index of the string in the list of strings
+ *   -FDT_ERR_NOTFOUND if the property does not exist or does not contain
+			  const char *string);
+ * fdt_stringlist_get() - obtain the string at a given index in a string list
+ * @index: index of the string to return
+ * @lenp: return location for the string length or an error code on failure
+ * Note that this will successfully extract strings from properties with
+ * non-NUL-terminated values. For example on small-valued cell properties
+ * this function will return the empty string.
+ * If non-NULL, the length of the string (on success) or a negative error-code
+ * (on failure) will be stored in the integer pointer to by lenp.
+ * @return:
+ *   A pointer to the string at the given index in the string list or NULL on
+ *   failure. On success the length of the string will be stored in the memory
+ *   location pointed to by the lenp parameter, if non-NULL. On failure one of
+ *   the following negative error codes will be returned in the lenp parameter
+ *   (if non-NULL):
+			       const char *property, int index,
+			       int *lenp);
+/* Read-only functions (addressing related)                           */
+ * FDT_MAX_NCELLS - maximum value for #address-cells and #size-cells
+ * This is the maximum value for #address-cells, #size-cells and
+ * similar properties that will be processed by libfdt.  IEE1275
+ * requires that OF implementations handle values up to 4.
+ * Implementations may support larger values, but in practice higher
+ * values aren't used.
+#define FDT_MAX_NCELLS		4
+ * fdt_address_cells - retrieve address size for a bus represented in the tree
+ * @nodeoffset: offset of the node to find the address size for
+ * When the node has a valid #address-cells property, returns its value.
+ * returns:
+ *	0 <= n < FDT_MAX_NCELLS, on success
+ *      2, if the node has no #address-cells property
+ *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid #address-cells property
+int fdt_address_cells(const void *fdt, int nodeoffset);
+ * fdt_size_cells - retrieve address range size for a bus represented in the
+ *                  tree
+ * @nodeoffset: offset of the node to find the address range size for
+ * When the node has a valid #size-cells property, returns its value.
+ * returns:
+ *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid #size-cells property
+int fdt_size_cells(const void *fdt, int nodeoffset);
+/* Write-in-place functions                                           */
+ * fdt_setprop_inplace - change a property's value, but not its size
+ * @nodeoffset: offset of the node whose property to change
+ * @name: name of the property to change
+ * @val: pointer to data to replace the property value with
+ * @len: length of the property value
+ * fdt_setprop_inplace() replaces the value of a given property with
+ * the data in val, of length len.  This function cannot change the
+ * size of a property, and so will only work if len is equal to the
+ * current length of the property.
+ * This function will alter only the bytes in the blob which contain
+ * the given property value, and will not alter or move any other part
+ * of the tree.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, if len is not equal to the property's current length
+ *	-FDT_ERR_NOTFOUND, node does not have the named property
+			const void *val, int len);
+ * fdt_setprop_inplace_u32 - change the value of a 32-bit integer property
+ * @val: 32-bit integer value to replace the property with
+ * fdt_setprop_inplace_u32() replaces the value of a given property
+ * with the 32-bit integer value in val, converting val to big-endian
+ * if necessary.  This function cannot change the size of a property,
+ * and so will only work if the property already exists and has length
+ * 4.
+ * of the tree.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, if the property's length is not equal to 4
+static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset,
+					  const char *name, uint32_t val)
+	fdt32_t tmp = cpu_to_fdt32(val);
+	return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp));
+ * fdt_setprop_inplace_u64 - change the value of a 64-bit integer property
+ * @val: 64-bit integer value to replace the property with
+ * fdt_setprop_inplace_u64() replaces the value of a given property
+ * with the 64-bit integer value in val, converting val to big-endian
+ * 8.
+ * of the tree.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, if the property's length is not equal to 8
+static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset,
+					  const char *name, uint64_t val)
+	fdt64_t tmp = cpu_to_fdt64(val);
+ * fdt_setprop_inplace_cell - change the value of a single-cell property
+ * This is an alternative name for fdt_setprop_inplace_u32()
+static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset,
+	return fdt_setprop_inplace_u32(fdt, nodeoffset, name, val);
+ * fdt_nop_property - replace a property with nop tags
+ * @nodeoffset: offset of the node whose property to nop
+ * @name: name of the property to nop
+ * fdt_nop_property() will replace a given property's representation
+ * in the blob with FDT_NOP tags, effectively removing it from the
+ * tree.
+ * the property, and will not alter or move any other part of the
+ * tree.
+ * returns:
+ *	0, on success
+int fdt_nop_property(void *fdt, int nodeoffset, const char *name);
+ * fdt_nop_node - replace a node (subtree) with nop tags
+ * @nodeoffset: offset of the node to nop
+ * fdt_nop_node() will replace a given node's representation in the
+ * blob, including all its subnodes, if any, with FDT_NOP tags,
+ * effectively removing it from the tree.
+ * the node and its properties and subnodes, and will not alter or
+ * move any other part of the tree.
+ * returns:
+ *	0, on success
+int fdt_nop_node(void *fdt, int nodeoffset);
+/* Sequential write functions                                         */
+int fdt_create(void *buf, int bufsize);
+int fdt_resize(void *fdt, void *buf, int bufsize);
+int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size);
+int fdt_finish_reservemap(void *fdt);
+int fdt_begin_node(void *fdt, const char *name);
+int fdt_property(void *fdt, const char *name, const void *val, int len);
+static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val)
+	return fdt_property(fdt, name, &tmp, sizeof(tmp));
+static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val)
+static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val)
+	return fdt_property_u32(fdt, name, val);
+#define fdt_property_string(fdt, name, str) \
+	fdt_property(fdt, name, str, strlen(str)+1)
+int fdt_end_node(void *fdt);
+int fdt_finish(void *fdt);
+/* Read-write functions                                               */
+int fdt_create_empty_tree(void *buf, int bufsize);
+int fdt_open_into(const void *fdt, void *buf, int bufsize);
+int fdt_pack(void *fdt);
+ * fdt_add_mem_rsv - add one memory reserve map entry
+ * @address, @size: 64-bit values (native endian)
+ * Adds a reserve map entry to the given blob reserving a region at
+ * address address of length size.
+ * This function will insert data into the reserve map and will
+ * therefore change the indexes of some entries in the table.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, there is insufficient free space in the blob to
+ *		contain the new reservation entry
+ *	-FDT_ERR_BADLAYOUT,
+int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size);
+ * fdt_del_mem_rsv - remove a memory reserve map entry
+ * @n: entry to remove
+ * fdt_del_mem_rsv() removes the n-th memory reserve map entry from
+ * the blob.
+ * This function will delete data from the reservation table and will
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOTFOUND, there is no entry of the given index (i.e. there
+ *		are less than n+1 reserve map entries)
+int fdt_del_mem_rsv(void *fdt, int n);
+ * fdt_set_name - change the name of a given node
+ * @name: name to give the node
+ * fdt_set_name() replaces the name (including unit address, if any)
+ * of the given node with the given string.  NOTE: this function can't
+ * efficiently check if the new name is unique amongst the given
+ * node's siblings; results are undefined if this function is invoked
+ * with a name equal to one of the given node's siblings.
+ * This function may insert or delete data from the blob, and will
+ * therefore change the offsets of some existing nodes.
+ * returns:
+ *	0, on success
+ *		to contain the new name
+int fdt_set_name(void *fdt, int nodeoffset, const char *name);
+ * fdt_setprop - create or change a property
+ * @val: pointer to data to set the property value to
+ * fdt_setprop() sets the value of the named property in the given
+ * node to the given value and length, creating the property if it
+ * does not already exist.
+ * returns:
+ *	0, on success
+ *		contain the new property value
+ * fdt_setprop_u32 - set a property to a 32-bit integer
+ * @val: 32-bit integer value for the property (native endian)
+ * fdt_setprop_u32() sets the value of the named property in the given
+ * node to the given 32-bit integer value (converting to big-endian if
+ * necessary), or creates a new property with that value if it does
+ * not already exist.
+ * returns:
+ *	0, on success
+static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name,
+				  uint32_t val)
+	return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp));
+ * fdt_setprop_u64 - set a property to a 64-bit integer
+ * @val: 64-bit integer value for the property (native endian)
+ * fdt_setprop_u64() sets the value of the named property in the given
+ * node to the given 64-bit integer value (converting to big-endian if
+ * returns:
+ *	0, on success
+static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name,
+				  uint64_t val)
+ * fdt_setprop_cell - set a property to a single cell value
+ * This is an alternative name for fdt_setprop_u32()
+static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name,
+				   uint32_t val)
+	return fdt_setprop_u32(fdt, nodeoffset, name, val);
+ * fdt_setprop_string - set a property to a string value
+ * @str: string value for the property
+ * fdt_setprop_string() sets the value of the named property in the
+ * given node to the given string value (using the length of the
+ * string to determine the new length of the property), or creates a
+ * new property with that value if it does not already exist.
+ * returns:
+ *	0, on success
+#define fdt_setprop_string(fdt, nodeoffset, name, str) \
+	fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
+ * fdt_appendprop - append to or create a property
+ * @name: name of the property to append to
+ * @val: pointer to data to append to the property value
+ * @len: length of the data to append to the property value
+ * fdt_appendprop() appends the value to the named property in the
+ * given node, creating the property if it does not already exist.
+ * This function may insert data into the blob, and will therefore
+ * change the offsets of some existing nodes.
+ * returns:
+ *	0, on success
+ * fdt_appendprop_u32 - append a 32-bit integer value to a property
+ * @val: 32-bit integer value to append to the property (native endian)
+ * fdt_appendprop_u32() appends the given 32-bit integer value
+ * (converting to big-endian if necessary) to the value of the named
+ * property in the given node, or creates a new property with that
+ * value if it does not already exist.
+ * returns:
+ *	0, on success
+static inline int fdt_appendprop_u32(void *fdt, int nodeoffset,
+	return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp));
+ * fdt_appendprop_u64 - append a 64-bit integer value to a property
+ * @val: 64-bit integer value to append to the property (native endian)
+ * fdt_appendprop_u64() appends the given 64-bit integer value
+ * returns:
+ *	0, on success
+static inline int fdt_appendprop_u64(void *fdt, int nodeoffset,
+ * fdt_appendprop_cell - append a single cell value to a property
+ * This is an alternative name for fdt_appendprop_u32()
+static inline int fdt_appendprop_cell(void *fdt, int nodeoffset,
+	return fdt_appendprop_u32(fdt, nodeoffset, name, val);
+ * fdt_appendprop_string - append a string to a property
+ * @str: string value to append to the property
+ * fdt_appendprop_string() appends the given string to the value of
+ * the named property in the given node, or creates a new property
+ * with that value if it does not already exist.
+ * returns:
+ *	0, on success
+#define fdt_appendprop_string(fdt, nodeoffset, name, str) \
+	fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
+ * fdt_delprop - delete a property
+ * fdt_del_property() will delete the given property.
+ * This function will delete data from the blob, and will therefore
+ * returns:
+ *	0, on success
+int fdt_delprop(void *fdt, int nodeoffset, const char *name);
+ * fdt_add_subnode_namelen - creates a new node based on substring
+ * Identical to fdt_add_subnode(), but use only the first namelen
+ * characters of name as the name of the new node.  This is useful for
+ * creating subnodes based on a portion of a larger string, such as a
+ * full path.
+ * fdt_add_subnode - creates a new node
+ * fdt_add_subnode() creates a new node as a subnode of the node at
+ * structure block offset parentoffset, with the given name (which
+ * should include the unit address, if any).
+ * This function will insert data into the blob, and will therefore
+ * returns:
+ *	structure block offset of the created nodeequested subnode (>=0), on success
+ *	-FDT_ERR_EXISTS, if the node at parentoffset already has a subnode of
+ *		the given name
+ *	-FDT_ERR_NOSPACE, if there is insufficient free space in the
+ *		blob to contain the new node
+int fdt_add_subnode(void *fdt, int parentoffset, const char *name);
+ * fdt_del_node - delete a node (subtree)
+ * fdt_del_node() will remove the given node, including all its
+ * subnodes if any, from the blob.
+ * returns:
+ *	0, on success
+int fdt_del_node(void *fdt, int nodeoffset);
+/* Debugging / informational functions                                */
+const char *fdt_strerror(int errval);
+#endif /* _LIBFDT_H */
diff --git a/cpukit/dtc/libfdt/libfdt_env.h b/cpukit/dtc/libfdt/libfdt_env.h
new file mode 100644
index 0000000..9dea97d
--- /dev/null
+++ b/cpukit/dtc/libfdt/libfdt_env.h
@@ -0,0 +1,111 @@
+#ifndef _LIBFDT_ENV_H
+#define _LIBFDT_ENV_H
+ * libfdt - Flat Device Tree manipulation
+ * Copyright (C) 2006 David Gibson, IBM Corporation.
+ * Copyright 2012 Kim Phillips, Freescale Semiconductor.
+ * libfdt is dual licensed: you can use it either under the terms of
+ * the GPL, or the BSD license, at your option.
+ *  a) This library is free software; you can redistribute it and/or
+ *     modify it under the terms of the GNU General Public License as
+ *     published by the Free Software Foundation; either version 2 of the
+ *     License, or (at your option) any later version.
+ *     This library is distributed in the hope that it will be useful,
+ *     but WITHOUT ANY WARRANTY; without even the implied warranty of
+ *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ *     GNU General Public License for more details.
+ *     You should have received a copy of the GNU General Public
+ *     License along with this library; if not, write to the Free
+ *     Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
+ *     MA 02110-1301 USA
+ * Alternatively,
+ *  b) Redistribution and use in source and binary forms, with or
+ *     without modification, are permitted provided that the following
+ *     conditions are met:
+ *     1. Redistributions of source code must retain the above
+ *        copyright notice, this list of conditions and the following
+ *        disclaimer.
+ *     2. Redistributions in binary form must reproduce the above
+ *        disclaimer in the documentation and/or other materials
+ *        provided with the distribution.
+ *     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
+ *     CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
+ *     INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ *     MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ *     DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
+ *     CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ *     SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ *     NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ *     LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ *     HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ *     CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ *     OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
+ *     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <stddef.h>
+#include <stdint.h>
+#include <string.h>
+#ifdef __CHECKER__
+#define __force __attribute__((force))
+#define __bitwise __attribute__((bitwise))
+#else
+#define __force
+#define __bitwise
+#endif
+typedef uint16_t __bitwise fdt16_t;
+typedef uint32_t __bitwise fdt32_t;
+typedef uint64_t __bitwise fdt64_t;
+#define EXTRACT_BYTE(x, n)	((unsigned long long)((uint8_t *)&x)[n])
+#define CPU_TO_FDT16(x) ((EXTRACT_BYTE(x, 0) << 8) | EXTRACT_BYTE(x, 1))
+#define CPU_TO_FDT32(x) ((EXTRACT_BYTE(x, 0) << 24) | (EXTRACT_BYTE(x, 1) << 16) | \
+			 (EXTRACT_BYTE(x, 2) << 8) | EXTRACT_BYTE(x, 3))
+#define CPU_TO_FDT64(x) ((EXTRACT_BYTE(x, 0) << 56) | (EXTRACT_BYTE(x, 1) << 48) | \
+			 (EXTRACT_BYTE(x, 2) << 40) | (EXTRACT_BYTE(x, 3) << 32) | \
+			 (EXTRACT_BYTE(x, 4) << 24) | (EXTRACT_BYTE(x, 5) << 16) | \
+			 (EXTRACT_BYTE(x, 6) << 8) | EXTRACT_BYTE(x, 7))
+static inline uint16_t fdt16_to_cpu(fdt16_t x)
+	return (__force uint16_t)CPU_TO_FDT16(x);
+static inline fdt16_t cpu_to_fdt16(uint16_t x)
+	return (__force fdt16_t)CPU_TO_FDT16(x);
+static inline uint32_t fdt32_to_cpu(fdt32_t x)
+	return (__force uint32_t)CPU_TO_FDT32(x);
+static inline fdt32_t cpu_to_fdt32(uint32_t x)
+	return (__force fdt32_t)CPU_TO_FDT32(x);
+static inline uint64_t fdt64_to_cpu(fdt64_t x)
+	return (__force uint64_t)CPU_TO_FDT64(x);
+static inline fdt64_t cpu_to_fdt64(uint64_t x)
+	return (__force fdt64_t)CPU_TO_FDT64(x);
+#undef CPU_TO_FDT64
+#undef CPU_TO_FDT32
+#undef CPU_TO_FDT16
+#undef EXTRACT_BYTE
+#endif /* _LIBFDT_ENV_H */
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 0000000..02cfa6f
--- /dev/null
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -0,0 +1,95 @@
+#ifndef _LIBFDT_INTERNAL_H
+#define _LIBFDT_INTERNAL_H
+ * Alternatively,
+ *        disclaimer.
+#include <fdt.h>
+#define FDT_ALIGN(x, a)		(((x) + (a) - 1) & ~((a) - 1))
+#define FDT_TAGALIGN(x)		(FDT_ALIGN((x), FDT_TAGSIZE))
+#define FDT_CHECK_HEADER(fdt) \
+		int __err; \
+		if ((__err = fdt_check_header(fdt)) != 0) \
+			return __err; \
+int _fdt_check_node_offset(const void *fdt, int offset);
+int _fdt_check_prop_offset(const void *fdt, int offset);
+const char *_fdt_find_string(const char *strtab, int tabsize, const char *s);
+int _fdt_node_end_offset(void *fdt, int nodeoffset);
+static inline const void *_fdt_offset_ptr(const void *fdt, int offset)
+	return (const char *)fdt + fdt_off_dt_struct(fdt) + offset;
+static inline void *_fdt_offset_ptr_w(void *fdt, int offset)
+	return (void *)(uintptr_t)_fdt_offset_ptr(fdt, offset);
+static inline const struct fdt_reserve_entry *_fdt_mem_rsv(const void *fdt, int n)
+	const struct fdt_reserve_entry *rsv_table =
+		(const struct fdt_reserve_entry *)
+		((const char *)fdt + fdt_off_mem_rsvmap(fdt));
+	return rsv_table + n;
+static inline struct fdt_reserve_entry *_fdt_mem_rsv_w(void *fdt, int n)
+	return (void *)(uintptr_t)_fdt_mem_rsv(fdt, n);
+#define FDT_SW_MAGIC		(~FDT_MAGIC)
+#endif /* _LIBFDT_INTERNAL_H */
diff --git a/cpukit/dtc/libfdt/preinstall.am b/cpukit/dtc/libfdt/preinstall.am
index 0000000..2c5c51d
--- /dev/null
+++ b/cpukit/dtc/libfdt/preinstall.am
@@ -0,0 +1,46 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES = $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES += $(TMPINSTALL_FILES)
+$(PROJECT_LIB)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_LIB)
+	@: > $(PROJECT_LIB)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/fdt.h: fdt.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/fdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/fdt.h
+$(PROJECT_INCLUDE)/libfdt.h: libfdt.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libfdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libfdt.h
+$(PROJECT_INCLUDE)/libfdt_env.h: libfdt_env.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libfdt_env.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libfdt_env.h
+$(PROJECT_LIB)/libfdt.a: libfdt.a $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/libfdt.a
+TMPINSTALL_FILES += $(PROJECT_LIB)/libfdt.a
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index ed773c4..d775c77 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
 _SUBDIRS = POSIX
+_SUBDIRS += libfdt01
 _SUBDIRS += defaultconfig01
 _SUBDIRS += pwdgrp02
 _SUBDIRS += shell01
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 4924e0f..89ca57f 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -79,6 +79,7 @@ AM_CONDITIONAL(DLTESTS,[test x"$TEST_LIBDL" = x"yes"])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+libfdt01/Makefile
 defaultconfig01/Makefile
 pwdgrp02/Makefile
 shell01/Makefile
diff --git a/testsuites/libtests/libfdt01/Makefile.am b/testsuites/libtests/libfdt01/Makefile.am
index 0000000..880d221
--- /dev/null
+++ b/testsuites/libtests/libfdt01/Makefile.am
@@ -0,0 +1,20 @@
+rtems_tests_PROGRAMS = libfdt01
+libfdt01_SOURCES = init.c some.c
+libfdt01_LDADD = -lfdt
+dist_rtems_tests_DATA = libfdt01.scn libfdt01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(libfdt01_OBJECTS) $(libfdt01_LDADD)
+LINK_LIBS = $(libfdt01_LDLIBS)
+libfdt01$(EXEEXT): $(libfdt01_OBJECTS) $(libfdt01_DEPENDENCIES)
+	@rm -f libfdt01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/libfdt01/init.c b/testsuites/libtests/libfdt01/init.c
index 0000000..a13fc82
--- /dev/null
+++ b/testsuites/libtests/libfdt01/init.c
@@ -0,0 +1,145 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+#include <libfdt.h>
+#include "some.h"
+ * To generate the FDT blob use:
+ * dtc some.dts -O asm > some.s
+ * as some.s -o some.o
+ * objcopy -O binary some.o some.bin
+ * rtems-bin2c some.bin some.c
+const char rtems_test_name[] = "LIBFDT 1";
+static void test(void)
+  const void *fdt = some_bin;
+  int status;
+  uint32_t size;
+  const char *alias;
+  int root;
+  int cells;
+  const char *prop;
+  fdt32_t *prop_32;
+  int len;
+  int d;
+  int m;
+  int t;
+  int node;
+  uint32_t phandle;
+  uint32_t cell;
+  status = fdt_check_header(fdt);
+  rtems_test_assert(status == 0);
+  size = fdt_totalsize(fdt);
+  rtems_test_assert(size == some_bin_size);
+  alias = fdt_get_alias(fdt, "nix");
+  rtems_test_assert(alias == NULL);
+  alias = fdt_get_alias(fdt, "k");
+  rtems_test_assert(strcmp(alias, "/m at 1248") == 0);
+  root = fdt_path_offset(fdt, "nix");
+  rtems_test_assert(root == -FDT_ERR_BADPATH);
+  root = fdt_path_offset(fdt, "/");
+  rtems_test_assert(root >= 0);
+  cells = fdt_address_cells(fdt, root);
+  rtems_test_assert(cells == 1);
+  cells = fdt_size_cells(fdt, root);
+  rtems_test_assert(cells == 2);
+  status = fdt_node_check_compatible(fdt, root, "a,b");
+  status = fdt_node_check_compatible(fdt, root, "blub");
+  rtems_test_assert(status == 1);
+  prop = fdt_getprop(fdt, root, "model", &len);
+  rtems_test_assert(len == 2);
+  rtems_test_assert(memcmp(prop, "c", 2) == 0);
+  d = fdt_subnode_offset(fdt, root, "slurf");
+  rtems_test_assert(d == -FDT_ERR_NOTFOUND);
+  d = fdt_subnode_offset(fdt, root, "d");
+  rtems_test_assert(d >= 0);
+  prop = fdt_getprop(fdt, d, "e", &len);
+  rtems_test_assert(memcmp(prop, "f", 2) == 0);
+  prop = fdt_getprop(fdt, d, "g", &len);
+  rtems_test_assert(len == 0);
+  rtems_test_assert(prop != NULL);
+  m = fdt_subnode_offset(fdt, root, "m at 1248");
+  rtems_test_assert(m >= 0);
+  t = fdt_subnode_offset(fdt, root, "t");
+  rtems_test_assert(t >= 0);
+  prop_32 = (fdt32_t *) fdt_getprop(fdt, t, "u", &len);
+  rtems_test_assert(len == 4);
+  phandle = fdt32_to_cpu(*prop_32);
+  node = fdt_node_offset_by_phandle(fdt, phandle);
+  rtems_test_assert(node == m);
+  prop_32 = (fdt32_t *) fdt_getprop(fdt, m, "n", &len);
+  rtems_test_assert(len == 8);
+  cell = fdt32_to_cpu(prop_32[0]);
+  rtems_test_assert(cell == 0xdeadbeef);
+  cell = fdt32_to_cpu(prop_32[1]);
+  rtems_test_assert(cell == 0x12345678);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/libfdt01/libfdt01.doc b/testsuites/libtests/libfdt01/libfdt01.doc
index 0000000..1e9ab97
--- /dev/null
+++ b/testsuites/libtests/libfdt01/libfdt01.doc
@@ -0,0 +1,20 @@
+This file describes the directives and concepts tested by this test set.
+test set name: libfdt01
+directives:
+  - fdt_address_cells()
+  - fdt_check_header()
+  - fdt_get_alias()
+  - fdt_getprop()
+  - fdt_node_check_compatible()
+  - fdt_node_offset_by_phandle()
+  - fdt_path_offset()
+  - fdt_size_cells()
+  - fdt_subnode_offset()
+  - fdt_totalsize()
+concepts:
+  - Ensure that some libfdt functions work as expected.
diff --git a/testsuites/libtests/libfdt01/libfdt01.scn b/testsuites/libtests/libfdt01/libfdt01.scn
index 0000000..7ea6971
--- /dev/null
+++ b/testsuites/libtests/libfdt01/libfdt01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST LIBFDT 1 ***
+*** END OF TEST LIBFDT 1 ***
diff --git a/testsuites/libtests/libfdt01/some.c b/testsuites/libtests/libfdt01/some.c
index 0000000..5eed911
--- /dev/null
+++ b/testsuites/libtests/libfdt01/some.c
@@ -0,0 +1,52 @@
+ *  Declarations for C structure representing binary file some.bin
+ *  WARNING: Automatically generated -- do not edit!
+#include <sys/types.h>
+const unsigned char some_bin[] = {
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
+  0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1a,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x01,
+  0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61,
+  0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34, 0x38, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40, 0x31, 0x32,
+  0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34, 0x56, 0x78,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x34,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
+  0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x46,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62,
+  0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d,
+  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d,
+  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c, 0x00,
+  0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00, 0x6c, 0x69, 0x6e, 0x75,
+  0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x70, 0x00,
+  0x72, 0x00, 0x75, 0x00,
+const size_t some_bin_size = sizeof(some_bin);
diff --git a/testsuites/libtests/libfdt01/some.dts b/testsuites/libtests/libfdt01/some.dts
index 0000000..ac15825
--- /dev/null
+++ b/testsuites/libtests/libfdt01/some.dts
@@ -0,0 +1,54 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+/dts-v1/;
+	compatible = "a,b";
+	#address-cells = <1>;
+	#size-cells = <2>;
+	model = "c";
+	d {
+		e = "f";
+		g;
+		h at 0 {
+		h at 1 {
+			w = <123>;
+	aliases {
+		k = "/m at 1248";
+	l: m at 1248 {
+		n = <0xdeadbeef 0x12345678>;
+		o {
+			p;
+		q {
+			r = "s";
+	t {
+		u = <&l>;
diff --git a/testsuites/libtests/libfdt01/some.h b/testsuites/libtests/libfdt01/some.h
index 0000000..e2e0135
--- /dev/null
+++ b/testsuites/libtests/libfdt01/some.h
@@ -0,0 +1,15 @@
+ *  Extern declarations for C structure representing binary file some.bin
+#ifndef __some_h
+#define __some_h
+extern const unsigned char some_bin[];
+extern const size_t some_bin_size;
+#endif
1.8.4.5
