[PATCH 1/6] basedefs.h: Add compiler attributes
Sebastian Huber
Fri Oct 16 06:59:30 UTC 2015
cpukit/score/include/rtems/score/basedefs.h | 41 ++++++++++++++++++++++++++++-
1 file changed, 40 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/include/rtems/score/basedefs.h b/cpukit/score/include/rtems/score/basedefs.h
index 695ab8f..8e145f5 100644
--- a/cpukit/score/include/rtems/score/basedefs.h
+++ b/cpukit/score/include/rtems/score/basedefs.h
@@ -10,7 +10,7 @@
* COPYRIGHT (c) 1989-2007.
* On-Line Applications Research Corporation (OAR).
- * Copyright (c) 2010 embedded brains GmbH.
+ * Copyright (c) 2010-2015 embedded brains GmbH.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -187,6 +187,25 @@
#endif
+ * @brief Instructs the compiler to place a specific variable or function in
+ * the specified section.
+#if defined(__GNUC__)
+ #define RTEMS_SECTION( _section ) __attribute__((__section__(_section)))
+#else
+#endif
+ * @brief Instructs the compiler that a specific variable or function is used.
+ #define RTEMS_USED __attribute__((__used__))
+#else
+#endif
* Instructs the compiler that a specific variable is deliberately unused.
* This can occur when reading volatile device memory or skipping arguments
* in a variable argument method.
@@ -316,6 +335,26 @@ extern void RTEMS_DEQUALIFY_types_not_compatible(void);
#endif /*RTEMS_DEQUALIFY_DEPTHX*/
#endif /*RTEMS_DEQUALIFY*/
+ * @brief Concatenates _x and _y without expanding.
+#define RTEMS_CONCAT( _x, _y ) _x##_y
+ * @brief Concatenates expansion of _x and expansion of _y.
+#define RTEMS_XCONCAT( _x, _y ) RTEMS_CONCAT( _x, _y )
+ * @brief Stringifies _x without expanding.
+#define RTEMS_STRING( _x ) #_x
+ * @brief Stringifies expansion of _x.
+#define RTEMS_XSTRING( _x ) RTEMS_STRING( _x )
#ifndef ASM
#ifdef RTEMS_DEPRECATED_TYPES
typedef bool boolean;
1.8.4.5
