[rtems commit] bsp/qoriq: Use U-Boot provided FDT
Tue Oct 20 10:10:43 UTC 2015
On 20/10/15 00:46, Chris Johns wrote:
> Was this patch posted todevel at rtems.org  for review?
No, since this is a BSP specific patch.
> I do not remember any discussion about how BSPs and FDT will be
> supported.
U-Boot supports FDT for several years now. So, all U-Boot based BSPs may
use this option.
>   I posted an RTEMS API for FDT which seems to have been ignored.
I didn't ignore this, but I thought this is an optional add-on? The
libfdt is a well established API. I don't see an immediate need for an
RTEMS specific API on top of this. The FDT is used before the high level
parts of RTEMS are available, e.g. files.
> Can you please describe this use of FDT in RTEMS and how this can used
> by more than the immediate use you have for your BSP?
The use of FDT for BSPs is to get U-Boot provided parameters.
> Where is the documentation on how this is to be used by the BSP it is
> designed to support? I do not see now a user is to build an application
> to use this.
This is not for the user. This is for device driver parameters and the
low-level system startup.
> Which BSPs is this new BSP API intended for?
> I do not support this change and would like it reverted until a better
> proposal is put forward.
What is your alternative? There is no way for a QorIQ device as complex
as a T4240 without FDT.
> On 19/10/2015 6:53 pm, Sebastian Huber wrote:
>> >  c/src/lib/libbsp/shared/include/fdt.h             | 30 +++++++
>> >  c/src/lib/libbsp/shared/src/bsp-fdt.c             | 59 ++++++++++++++
> This is being adding the shared BSP API. Why?
This is useful for more than one BSP.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
