[PATCH] CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error checked
Nick Withers nick.withers at anu.edu.au
Tue Oct 20 22:41:40 UTC 2015
A couple of doco typos...
On Tue, 2015-10-20 at 14:47 -0500, Joel Sherrill wrote:
> closes #2431.
>  cpukit/sapi/include/confdefs.h       |   14 ++++++++
>  doc/user/conf.t                      |   55 ++++++++++++++++++++++++++++++++++
>  testsuites/psxtests/psximfs02/init.c |    4 +-
>  3 files changed, 71 insertions(+), 2 deletions(-)
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index 66c8c7e..db2bedd 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -3823,5 +3823,19 @@ const rtems_libio_helper rtems_fs_init_helper =
>    #endif
>  #endif
> + * IMFS block size for in memory files (memfiles) must be a power of
> + * two between 16 and 512 inclusive.
> +#if ((CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 16) && \
> +     (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 32) && \
> +     (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 64) && \
> +     (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 128) && \
> +     (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 256) && \
> +     (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 512))
> +  #error "IMFS Memfile block size must be a power of 2 between 16 and 512"
> +#endif
>  #endif
>  /* end of include file */
> diff --git a/doc/user/conf.t b/doc/user/conf.t
> index ec9b1f8..9905454 100644
> --- a/doc/user/conf.t
> +++ b/doc/user/conf.t
> @@ -2749,6 +2749,61 @@ options will be defined as well
>  @end itemize
>  @c
> + at c === CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK ===
> + at c
> + at subsection Specify Block Size for IMFS
> + at findex CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
> + at table @b
> + at item CONSTANT:
> + at code{CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK}
> + at item DATA TYPE:
> +Boolean feature macro.
> + at item RANGE:
> +Valid values for this configuration parameter are are a power of two (2)
There's a double "are" there.
> +between 16 and 512 inclusively.  In other words, valid values are 16,
> +32, 64, 128, 257,and 512.
"257,and" -> "256 and". Since I'm here, I'd say "inclusive" rather than
"inclusively" too, but maybe that's just me.
Cheers!
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
