Random lwIP Crashes in _POSIX_Mutex_Lock_support()
Isaac Gutekunst isaac.gutekunst at vecna.com
Wed Oct 21 12:56:22 UTC 2015
On 10/21/2015 08:24 AM, Sebastian Huber wrote:
> On 21/10/15 14:13, Isaac Gutekunst wrote:
>> Thanks for the reply.
>> On 10/21/2015 01:50 AM, Sebastian Huber wrote:
>>> On 20/10/15 16:02, Isaac Gutekunst wrote:
>>>> As far as I can tell this would only occur if the caller of pthread_mutex_lock was in a "bad"
>>>> state. I don't believe it is in an interrupt context, and don't know what other bad states
>>>> could exist.
>>> We have
>>> #define _CORE_mutex_Check_dispatch_for_seize(_wait) \
>>>    (!_Thread_Dispatch_is_enabled() \
>>>      && (_wait) \
>>>      && (_System_state_Get() >= SYSTEM_STATE_UP))
>>> What is the thread dispatch disable level and the system state at this point?
>>> In case the thread dispatch disable level is not zero, then something is probably broken in the
>>> operating system code which is difficult to find. Could be a general memory corruption problem
>>> too. Which RTEMS version do you use?
>> The thread dispatch disable level is usually -1 or -2.
>> (0xFFFFFFFE or 0xFFFFFFD).
> A negative value is very bad, but easy to detect via manual instrumentation (only an hand full
> of spots touch this variable) or hardware breakpoints/watchpoints. Looks the rest of
> _Per_CPU_Information all right?
It looks like it's only the thread_dispatch_disable_level that's broken.
We'll go and grep for all places for all the places it's touched, and look for something.
The problem with watchpoints is they fire exceptionally often, and putting in a conditional
watchpoint slows the code to a crawl, but that may be worth it.
Here are some printouts of the relevant structs right after a crash:
$4 = {
   cpu_per_cpu = {<No data fields>},
   isr_nest_level = 0,
   thread_dispatch_disable_level = 4294967295,
   executing = 0xc01585c8,
   heir = 0xc0154038,
   dispatch_necessary = true,
   time_of_last_context_switch = {
     sec = 2992,
     frac = 10737447432380511034
   Stats = {<No data fields>}
This might be excessive information, but the executing struct looks good too:
p *(cpu_self->executing)
$6 = ((null) ?) {
   Object = {
     Node = {
       next = 0xc0153558,
       previous = 0xc0004568
     id = 184614914,
     name = {
       name_p = 0x0,
       name_u32 = 0
   current_state = 0,
   current_priority = 240,
   real_priority = 240,
   priority_generation = 0,
   priority_restore_hint = false,
   resource_count = 0,
   Wait = {
     Node = {
       Chain = {
         next = 0xc015b764,
         previous = 0xc015b760
       RBTree = {
         Node = {
           rbe_left = 0xc015b764,
           rbe_right = 0xc015b760,
           rbe_parent = 0xc0158644,
           rbe_color = 134262661
     id = 1124139010,
     count = 3222636040,
     return_argument = 0x8032101 <_User_extensions_Fatal_visitor>,
     return_argument_second = {
       mutable_object = 0xc0158644,
       immutable_object = 0xc0158644
     option = 1461858615,
     return_code = 0,
     timeout_code = 116,
     queue = 0x0,
     flags = 1028,
     operations = 0x80966d0 <_Thread_queue_Operations_default>,
     spare_heads = 0xc015b760
   Timer = {
     Node = {
       next = 0xc015304c,
       previous = 0xc014f9ec
     state = WATCHDOG_INACTIVE,
     initial = 78,
     delta_interval = 64,
     start_time = 2991580,
     stop_time = 2991580,
     routine = 0x8031cdd <_Thread_Timeout>,
     id = 0,
     user_data = 0xc01585c8
   is_preemptible = true,
   is_fp = true,
   Scheduler = {
     node = 0xc0158784
   cpu_time_budget = 18,
   budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE,
   budget_callout = 0x0,
   cpu_time_used = {
     sec = 22,
     frac = 11951614103676580982
   Start = {
     entry_point = 0x808c149 <tcpip_thread>,
     prototype = THREAD_START_POINTER,
     pointer_argument = 0x0,
     numeric_argument = 0,
     isr_level = 0,
     initial_priority = 240,
     core_allocated_stack = true,
     Initial_stack = {
       size = 4096,
       area = 0xc01690f0
     stack = 0xc01690f0,
     tls_area = 0x0
   Post_switch_actions = {
     Chain = {
       Head = {
         Node = {
           next = 0xc01586b0,
           previous = 0x0
         fill = 0xc01586ac
       Tail = {
         fill = 0xc01586b0,
         Node = {
           next = 0x0,
           previous = 0xc01586ac
   Registers = {
     register_r4 = 3222651512,
     register_r5 = 0,
     register_r6 = 0,
     register_r7 = 3222708080,
     register_r8 = 0,
     register_r9 = 0,
     register_r10 = 0,
     register_r11 = 0,
     register_lr = 0x802f269 <_Thread_Do_dispatch+124>,
     register_sp = 0xc0169f70,
     isr_nest_level = 1,
     register_d8 = 0,
     register_d9 = 0,
     register_d10 = 0,
     register_d11 = 0,
     register_d12 = 0,
     register_d13 = 0,
     register_d14 = 0,
     register_d15 = 0
   libc_reent = 0xc0158890,
   API_Extensions = {0xc0158794, 0xc01587c0},
   task_variables = 0x0,
   Key_Chain = {
     Head = {
       Node = {
         next = 0xc015873c,
         previous = 0x0
       fill = 0xc0158738
     Tail = {
       fill = 0xc015873c,
       Node = {
         next = 0x0,
         previous = 0xc0158738
   Life = {
     Action = {
       Node = {
         next = 0x0,
         previous = 0xc000a998 <rtems_libio_iops+56>
       handler = 0x80312b9 <_Thread_Life_action_handler>
     state = THREAD_LIFE_NORMAL,
     terminator = 0x0
   Capture = {
     flags = 0,
     control = 0x0
   extensions = 0xc0158760
> On Cortex-M interrupt disable around operating system calls leads to unpredictable system
> behaviour.
