[PATCH] Add STM32 HAL Files for F4 and F7
Wed Oct 21 15:55:54 UTC 2015
Isaac,
Is all the code attached licensed under a 2/3-bsd?
Gedare
On Wed, Oct 14, 2015 at 4:54 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 10/14/2015 3:35 PM, Gedare Bloom wrote:
>> I don't have a problem on the surface of it, but can we get a clear
>> statement of the licensing for the included code?
> The patch is huge but includes the license in pdf and rtf format.
> Based on the one source file I looked at, the license is BSD
> w/advertising. I am not sure if this is the same with all files.
> This is a cut and paste from a file added:
> +  * <h2><center>© COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
> +  * Redistribution and use in source and binary forms, with or without
> modification,
> +  * are permitted provided that the following conditions are met:
> +  *   1. Redistributions of source code must retain the above copyright
> notice,
> +  *      this list of conditions and the following disclaimer.
> +  *   2. Redistributions in binary form must reproduce the above copyright
> notice,
> +  *      this list of conditions and the following disclaimer in the
> documentation
> +  *      and/or other materials provided with the distribution.
> +  *   3. Neither the name of STMicroelectronics nor the names of its
> contributors
> +  *      may be used to endorse or promote products derived from this
> software
> +  *      without specific prior written permission.
> +  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE ARE
> +  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> LIABLE
> +  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> +  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> OR
> +  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> HOWEVER
> +  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> LIABILITY,
> +  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF
> THE USE
> +  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> On Mon, Sep 28, 2015 at 4:25 PM, Isaac Gutekunst
>> <isaac.gutekunst at vecna.com> wrote:
>>> Hi Devel,
>>> As mentioned earlier, Vecna has developed two BSP families using the HAL
>>> code provide by ST as a foundation. The code isn't perfect, but it let us
>>> get up to speed very fast, and provides a consistent abstraction across a
>>> number of processors.
>>> I formatted a giant patch with all the relevant files needed for the new
>>> BSP
>>> that will be arriving later. The plan is to get this code approved and
>>> merged, and then add the BSP piece by piece to reduce the amount of code
>>> coming in at once.
>>> This includes some HAL files that we aren't using in the BSP just yet.
>>> Let
>>> me know if we should remove them. It's a rather absurd amount of code :)
>>> As before, I can't get git-send-email to work. In addition, the patches
>>> are
>>> giant, so I've inserted links to files in Google Drive.
>>> https://drive.google.com/open?id=0BxaqNLUoI5onZ3lUUDNrYXlyX1U
>>> https://drive.google.com/open?id=0BxaqNLUoI5onM3JsenRJRkotWm8
>>> Isaac Gutekunst
>>> Embedded Systems Software Engineer
>>> www.vecna.com
>>> Cambridge Research Laboratory
>>> Vecna Technologies, Inc.
>>> 36 Cambridge Park Drive
>>> Cambridge, MA 02140
>>> Office: (617) 864-0636 x3069
>>> Fax: (617) 864-0638
>>> http://vecna.com
>>> Better Technology, Better World (TM)
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
