[PATCH] Add STM32 HAL Files for F4 and F7
Isaac Gutekunst isaac.gutekunst at vecna.com
Wed Oct 21 17:13:19 UTC 2015
I haven't actually looked at every file individually, but AFIK yes.
Isaac
On 10/21/2015 11:55 AM, Gedare Bloom wrote:
> Isaac,
> Is all the code attached licensed under a 2/3-bsd?
> Gedare
> On Wed, Oct 14, 2015 at 4:54 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 10/14/2015 3:35 PM, Gedare Bloom wrote:
>>> I don't have a problem on the surface of it, but can we get a clear
>>> statement of the licensing for the included code?
>> The patch is huge but includes the license in pdf and rtf format.
>> Based on the one source file I looked at, the license is BSD
>> w/advertising. I am not sure if this is the same with all files.
>> This is a cut and paste from a file added:
>> +  * <h2><center>© COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
>> +  * Redistribution and use in source and binary forms, with or without
>> modification,
>> +  * are permitted provided that the following conditions are met:
>> +  *   1. Redistributions of source code must retain the above copyright
>> notice,
>> +  *      this list of conditions and the following disclaimer.
>> +  *   2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> +  *      this list of conditions and the following disclaimer in the
>> documentation
>> +  *      and/or other materials provided with the distribution.
>> +  *   3. Neither the name of STMicroelectronics nor the names of its
>> contributors
>> +  *      may be used to endorse or promote products derived from this
>> software
>> +  *      without specific prior written permission.
>> +  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
>> IS"
>> +  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> +  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE ARE
>> +  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
>> LIABLE
>> +  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> +  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> OR
>> +  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> HOWEVER
>> +  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> LIABILITY,
>> +  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF
>> THE USE
>> +  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>>> On Mon, Sep 28, 2015 at 4:25 PM, Isaac Gutekunst
>>> <isaac.gutekunst at vecna.com> wrote:
>>>> Hi Devel,
>>>> As mentioned earlier, Vecna has developed two BSP families using the HAL
>>>> code provide by ST as a foundation. The code isn't perfect, but it let us
>>>> get up to speed very fast, and provides a consistent abstraction across a
>>>> number of processors.
>>>> I formatted a giant patch with all the relevant files needed for the new
>>>> BSP
>>>> that will be arriving later. The plan is to get this code approved and
>>>> merged, and then add the BSP piece by piece to reduce the amount of code
>>>> coming in at once.
>>>> This includes some HAL files that we aren't using in the BSP just yet.
>>>> Let
>>>> me know if we should remove them. It's a rather absurd amount of code :)
>>>> As before, I can't get git-send-email to work. In addition, the patches
>>>> are
>>>> giant, so I've inserted links to files in Google Drive.
>>>> https://drive.google.com/open?id=0BxaqNLUoI5onZ3lUUDNrYXlyX1U
>>>> https://drive.google.com/open?id=0BxaqNLUoI5onM3JsenRJRkotWm8
>>>> Isaac Gutekunst
>>>> Embedded Systems Software Engineer
>>>> www.vecna.com
>>>> Cambridge Research Laboratory
>>>> Vecna Technologies, Inc.
>>>> 36 Cambridge Park Drive
>>>> Cambridge, MA 02140
>>>> Office: (617) 864-0636 x3069
>>>> Fax: (617) 864-0638
>>>> http://vecna.com
>>>> Better Technology, Better World (TM)
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
