Per-BSP confdefs (or resource allocation)
Isaac Gutekunst isaac.gutekunst at vecna.com
Wed Oct 21 19:53:00 UTC 2015
Hi Devel,
I looked for a while, but couldn't find a way to specify what resources (semaphores, tasks,
etc) a BSP requires for an empty project (empty Init function).
I took a look at this page:
https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Initialization-Code-The-RTEMS-Configuration-Table.html
but couldn't glean the correct method.
What is the preferred way to do so?
Our BSP uses a number of resources for hardware drivers, including UART, CAN, SPI, I2C and
Ethernet.
Isaac Gutekunst
Embedded Systems Software Engineer
www.vecna.com
