Per-BSP confdefs (or resource allocation)
Thu Oct 22 05:57:53 UTC 2015
On 22/10/15 07:45, Chris Johns wrote:
> On 22/10/2015 4:41 pm, Sebastian Huber wrote:
>> >If you use C11, C++11, libgomp or libbsd synchronization objects, then
>> >the storage space for them is provided by the user and not the workspace.
> Typically drivers in BSPs have used documented APIs. Is this approach
> and support documented and available for users? Is it available in 4.11?
With "would be" I meant that it is technically possible. There is some
work necessary to actually use it. My approach would be to move the
FreeBSD synchronization objects from libbsd to RTEMS, since they offer
the best designed APIs.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
