4.11 Branch BSP C++ Build Issues
Thu Oct 22 12:06:22 UTC 2015
On October 22, 2015 12:28:31 AM CDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>On 21/10/15 23:02, Joel Sherrill wrote:
>> NIOS2
>> Missing needed atomic operations.
>> nios2-rtems4.11-g++ -B../../../../../nios2_iss/lib/ -specs bsp_specs
>> -qrtems -mno-hw-mul -mno-hw-div -O0 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes
>> -Wnested-externs    -mno-hw-mul -mno-hw-div   -o cxx_iostream.exe
>init.o
>/data/home/joel/rtems-4.11-work/tools/bin/../lib/gcc/nios2-rtems4.11/4.9.3/libstdc++.a(ios_init.o):
>> In function `__exchange_and_add_dispatch':
>/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/nios2-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/nios2-
>This is not a general C++ issue. It is a libstdc++ issue. I would not
>disable C++ in this case. Looks again like a problem with the missing
>libatomic support for RTEMS.
I recall asking about this or filing a PR and being told nios2-elf had the atomics. Where is this configured?
--joel
