Random lwIP Crashes in _POSIX_Mutex_Lock_support()
Fri Oct 23 07:31:15 UTC 2015
You can run the test suite on Qemu using the lm3s6965 BSP (you need Qemu
patches, see source directory of the BSP). I did run the tests and it
looks good.
On 22/10/15 20:37, Isaac Gutekunst wrote:
> I think I may have some information that's actually useful.
> I've managed to actually execute some tests.... and lots of them are
> failing.
> sp01 and sp02 fail quite quickly, as an assertion fails.
> assertion "first != _Chain_Tail( &ready_queues[ index ] )" failed:
> file "../../cpukit/../../../stm32f7x/lib/
> include/rtems/score/schedulerpriorityimpl.h", line 166, function:
> _Scheduler_priority_Ready_queue_first
> This failure is common to many of the failed tests so far. What does
> this mean?
The ready queue is empty. This must never happen.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
