[PATCH] Export _NCPUWORDS as variable for access from within the gnat-rts
Jan Sommer
soja-lists at aries.uberspace.de
Thu Oct 29 13:14:08 UTC 2015
Hi,
This patch will make the define _NCPUWORDS accessible for the ada runtime. It is necessary to model the pthread_attr_t implementation for rtems in Ada.
We had a stack corruption because the C an Ada declarations of the type where out of synch.
I will send the updated s-osinte-rtems.ads to gcc if this patch is accepted.
I put devel at rtems.org CC for input from the rtems developers.
Best regards,
Jan
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151029/f35a6404/attachment.bin>
