[PATCH] Fix CppCheck errors
Martin Galvan martin.galvan at tallertechnologies.com
Tue Sep 1 19:10:34 UTC 2015
This patch fixes the following CppCheck errors found throughout the code:
[c/src/lib/libbsp/shared/umon/umon.h:21]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
[cpukit/libmisc/dumpbuf/dumpbuf.c:69]: (error) Undefined behavior: Variable 'line_buffer' is used as parameter and destination in s[n]printf().
[cpukit/libmisc/dumpbuf/dumpbuf.c:76]: (error) Undefined behavior: Variable 'line_buffer' is used as parameter and destination in s[n]printf().
[cpukit/libnetworking/rtems/rtems_dhcp.c:401]: (error) Common realloc mistake: 'dhcp_hostname' nulled but not freed upon failure
[cpukit/posix/include/rtems/posix/ptimer.h:33]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
[cpukit/rtems/include/rtems/rtems/dpmemimpl.h:104]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
[tools/cpu/nios2/memory.c:99]: (error) Uninitialized variable: memory
[tools/cpu/nios2/ptf.c:582]: (error) Memory leak: new_prefix
Closes #2405.
 c/src/lib/libbsp/shared/umon/umon.h          |  4 +++
 cpukit/libmisc/dumpbuf/dumpbuf.c             | 41 ++++++++++++++++------------
 cpukit/libnetworking/rtems/rtems_dhcp.c      | 18 ++++++++----
 cpukit/posix/include/rtems/posix/ptimer.h    |  5 +++-
 cpukit/rtems/include/rtems/rtems/dpmemimpl.h |  6 +++-
 tools/cpu/nios2/memory.c                     |  5 ++--
 tools/cpu/nios2/ptf.c                        | 24 +++++++++-------
 7 files changed, 65 insertions(+), 38 deletions(-)
diff --git a/c/src/lib/libbsp/shared/umon/umon.h b/c/src/lib/libbsp/shared/umon/umon.h
index 3c5bdf9..d25a781 100644
--- a/c/src/lib/libbsp/shared/umon/umon.h
+++ b/c/src/lib/libbsp/shared/umon/umon.h
@@ -61,4 +61,8 @@ int rtems_initialize_tfs_filesystem(
 int umoncons_poll_read(int minor);
+#ifdef __cplusplus
 #endif
+#endif /* __rtems_umon_h */
diff --git a/cpukit/libmisc/dumpbuf/dumpbuf.c b/cpukit/libmisc/dumpbuf/dumpbuf.c
index 9d34d42..aca32f3 100644
--- a/cpukit/libmisc/dumpbuf/dumpbuf.c
+++ b/cpukit/libmisc/dumpbuf/dumpbuf.c
@@ -6,7 +6,7 @@
- *  COPYRIGHT (c) 1997-2007.
+ *  COPYRIGHT (c) 1997-2015.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may in
@@ -24,6 +24,9 @@
 #include <rtems/dumpbuf.h>
 #include <rtems/bspIo.h>
+#define BUFFER_LENGTH 120
+#define PADDING_LENGTH 16
  *  Put the body below rtems_print_buffer so it won't get inlined.
@@ -59,27 +62,29 @@ static inline void Dump_Line(
   int                  length
+  unsigned int i;
+  static unsigned char line_buffer[BUFFER_LENGTH];
+  static unsigned char tmp[BUFFER_LENGTH] = "";
-  int  i;
-  char line_buffer[120];
-  line_buffer[0] = '\0';
-  for( i=0 ; i<length ; i++ )
-    sprintf( line_buffer, "%s%02x ", line_buffer, buffer[ i ] );
+  for ( i = 0; i < length; ++i ) {
+    sprintf(tmp, "%02x ", buffer[i]);
+    strncat(line_buffer, tmp, strlen(tmp));
-  for( ; i<16 ; i++ )
-    strcat( line_buffer, "   " );
+  for ( ; i < PADDING_LENGTH; ++i ) {
+    strcat(line_buffer, "   ");
-  strcat( line_buffer, "|" );
-    sprintf( line_buffer, "%s%c", line_buffer,
-             isprint( buffer[ i ] ) ? buffer[ i ] : '.' );
+  strcat(line_buffer, "|");
+    sprintf(tmp, "%c", isprint(buffer[i]) ? buffer[i] : '.');
-  strcat( line_buffer, "|\n" );
-  printk( line_buffer );
+  printk("%s|\n", line_buffer);
diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
index c938ee0..87be238 100644
--- a/cpukit/libnetworking/rtems/rtems_dhcp.c
+++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
@@ -394,15 +394,23 @@ process_options (unsigned char *optbuf, int optbufSize)
           printf ("dhcpc: hostname >= %d bytes\n", MAXHOSTNAMELEN);
           len = MAXHOSTNAMELEN-1;
-        if (sethostname (p, len) < 0)
+        if (sethostname (p, len) < 0) {
           printf ("dhcpc: can't set host name");
         if (dhcp_hostname != NULL)
-          dhcp_hostname = realloc (dhcp_hostname, len);
-          strncpy (dhcp_hostname, p, len);
-        else
+          char *tmp = realloc (dhcp_hostname, len);
+          if (tmp != NULL) {
+            dhcp_hostname = tmp;
+            strncpy (dhcp_hostname, p, len);
+          } else {  /* realloc failed */
+            printf ("dhcpc: realloc failed (%s:%d)", __FILE__, __LINE__);
+            free (dhcp_hostname);
+            dhcp_hostname = NULL;
+        } else { /* dhcp_hostname == NULL */
           dhcp_hostname = strndup (p, len);
         break;
       case 7:
diff --git a/cpukit/posix/include/rtems/posix/ptimer.h b/cpukit/posix/include/rtems/posix/ptimer.h
index 7cc0516..16ac2b8 100644
--- a/cpukit/posix/include/rtems/posix/ptimer.h
+++ b/cpukit/posix/include/rtems/posix/ptimer.h
@@ -87,6 +87,9 @@ int timer_getoverrun(
   timer_t   timerid
+#ifdef __cplusplus
+#endif
-#endif
+#endif /* _RTEMS_POSIX_PTIMER_H */
diff --git a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
index 9fd2e6c..d2d7a4f 100644
--- a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
@@ -20,6 +20,10 @@
 #include <rtems/rtems/dpmem.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
  * @defgroup ClassicDPMEMImpl Dual Ported Memory Manager Implementation
@@ -104,5 +108,5 @@ RTEMS_INLINE_ROUTINE Dual_ported_memory_Control *_Dual_ported_memory_Get (
 #endif
-#endif
+#endif /* _RTEMS_RTEMS_DPMEM_INL */
 /* end of include file */
diff --git a/tools/cpu/nios2/memory.c b/tools/cpu/nios2/memory.c
index cd88b8b..cb1ea7f 100644
--- a/tools/cpu/nios2/memory.c
+++ b/tools/cpu/nios2/memory.c
@@ -18,7 +18,8 @@ memory_desc *find_memory(device_desc *devices)
   struct ptf *p;
   struct ptf_item pi;
-  memory_desc *tmd, *memory;
+  memory_desc *tmd;
+  memory_desc *memory = NULL;
   /* Check which of the devices are memory, sort by size */
@@ -29,8 +30,6 @@ memory_desc *find_memory(device_desc *devices)
     struct ptf_item pi;
     device_desc *dd;
-    memory = NULL;
     for(dd = devices; dd; dd=dd->next)
       p = ptf_find(dd->ptf->sub, &pi, item, "Is_Memory_Device", "1");
diff --git a/tools/cpu/nios2/ptf.c b/tools/cpu/nios2/ptf.c
index 7a31c11..07d6183 100644
--- a/tools/cpu/nios2/ptf.c
+++ b/tools/cpu/nios2/ptf.c
@@ -567,17 +567,21 @@ void ptf_printf(FILE *s, struct ptf *tree, char *prefix)
           new_prefix_len += strlen(leaf->value) + 1;
         new_prefix = (char *)malloc(new_prefix_len);
-        strcpy(new_prefix, prefix);
-        strcat(new_prefix, leaf->name);
-        if(leaf->value != NULL && leaf->value[0] != 0)
+        if (new_prefix != NULL)
-          strcat(new_prefix, ":");
-          strcat(new_prefix, leaf->value);
-        strcat(new_prefix, "/");
-        fputs(new_prefix, s);
-        fputs("\n", s);
-        ptf_printf(s, leaf->sub, new_prefix);
+          strcpy(new_prefix, prefix);
+          strcat(new_prefix, leaf->name);
+          if(leaf->value != NULL && leaf->value[0] != 0)
+            strcat(new_prefix, ":");
+            strcat(new_prefix, leaf->value);
+          strcat(new_prefix, "/");
+          fputs(new_prefix, s);
+          fputs("\n", s);
+          ptf_printf(s, leaf->sub, new_prefix);
+          free(new_prefix);
         break;
2.5.1
