[PATCH] Fix CppCheck errors
Wed Sep 2 13:35:50 UTC 2015
Apply to 4.11 and master
On Wed, Sep 2, 2015 at 9:35 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Looks OK to me.
> On Tue, Sep 1, 2015 at 3:10 PM, Martin Galvan
> <martin.galvan at tallertechnologies.com> wrote:
>> This patch fixes the following CppCheck errors found throughout the code:
>> [c/src/lib/libbsp/shared/umon/umon.h:21]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
>> [cpukit/libmisc/dumpbuf/dumpbuf.c:69]: (error) Undefined behavior: Variable 'line_buffer' is used as parameter and destination in s[n]printf().
>> [cpukit/libmisc/dumpbuf/dumpbuf.c:76]: (error) Undefined behavior: Variable 'line_buffer' is used as parameter and destination in s[n]printf().
>> [cpukit/libnetworking/rtems/rtems_dhcp.c:401]: (error) Common realloc mistake: 'dhcp_hostname' nulled but not freed upon failure
>> [cpukit/posix/include/rtems/posix/ptimer.h:33]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
>> [cpukit/rtems/include/rtems/rtems/dpmemimpl.h:104]: (error) Invalid number of character ({) when these macros are defined: '__cplusplus'.
>> [tools/cpu/nios2/memory.c:99]: (error) Uninitialized variable: memory
>> [tools/cpu/nios2/ptf.c:582]: (error) Memory leak: new_prefix
>> Closes #2405.
>>  c/src/lib/libbsp/shared/umon/umon.h          |  4 +++
>>  cpukit/libmisc/dumpbuf/dumpbuf.c             | 41 ++++++++++++++++------------
>>  cpukit/libnetworking/rtems/rtems_dhcp.c      | 18 ++++++++----
>>  cpukit/posix/include/rtems/posix/ptimer.h    |  5 +++-
>>  cpukit/rtems/include/rtems/rtems/dpmemimpl.h |  6 +++-
>>  tools/cpu/nios2/memory.c                     |  5 ++--
>>  tools/cpu/nios2/ptf.c                        | 24 +++++++++-------
>>  7 files changed, 65 insertions(+), 38 deletions(-)
>> diff --git a/c/src/lib/libbsp/shared/umon/umon.h b/c/src/lib/libbsp/shared/umon/umon.h
>> index 3c5bdf9..d25a781 100644
>> --- a/c/src/lib/libbsp/shared/umon/umon.h
>> +++ b/c/src/lib/libbsp/shared/umon/umon.h
>> @@ -61,4 +61,8 @@ int rtems_initialize_tfs_filesystem(
>>  int umoncons_poll_read(int minor);
>> +#ifdef __cplusplus
>>  #endif
>> +#endif /* __rtems_umon_h */
>> diff --git a/cpukit/libmisc/dumpbuf/dumpbuf.c b/cpukit/libmisc/dumpbuf/dumpbuf.c
>> index 9d34d42..aca32f3 100644
>> --- a/cpukit/libmisc/dumpbuf/dumpbuf.c
>> +++ b/cpukit/libmisc/dumpbuf/dumpbuf.c
>> @@ -6,7 +6,7 @@
>> - *  COPYRIGHT (c) 1997-2007.
>> + *  COPYRIGHT (c) 1997-2015.
>>   *  On-Line Applications Research Corporation (OAR).
>>   *  The license and distribution terms for this file may in
>> @@ -24,6 +24,9 @@
>>  #include <rtems/dumpbuf.h>
>>  #include <rtems/bspIo.h>
>> +#define BUFFER_LENGTH 120
>> +#define PADDING_LENGTH 16
>>   *  Put the body below rtems_print_buffer so it won't get inlined.
>> @@ -59,27 +62,29 @@ static inline void Dump_Line(
>>    int                  length
>> +  unsigned int i;
>> +  static unsigned char line_buffer[BUFFER_LENGTH];
>> +  static unsigned char tmp[BUFFER_LENGTH] = "";
>> -  int  i;
>> -  char line_buffer[120];
>> -  line_buffer[0] = '\0';
>> -  for( i=0 ; i<length ; i++ )
>> -    sprintf( line_buffer, "%s%02x ", line_buffer, buffer[ i ] );
>> +  for ( i = 0; i < length; ++i ) {
>> +    sprintf(tmp, "%02x ", buffer[i]);
>> +    strncat(line_buffer, tmp, strlen(tmp));
>> -  for( ; i<16 ; i++ )
>> -    strcat( line_buffer, "   " );
>> +  for ( ; i < PADDING_LENGTH; ++i ) {
>> +    strcat(line_buffer, "   ");
>> -  strcat( line_buffer, "|" );
>> -    sprintf( line_buffer, "%s%c", line_buffer,
>> -             isprint( buffer[ i ] ) ? buffer[ i ] : '.' );
>> +  strcat(line_buffer, "|");
>> +    sprintf(tmp, "%c", isprint(buffer[i]) ? buffer[i] : '.');
>> -  strcat( line_buffer, "|\n" );
>> -  printk( line_buffer );
>> +  printk("%s|\n", line_buffer);
>> diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
>> index c938ee0..87be238 100644
>> --- a/cpukit/libnetworking/rtems/rtems_dhcp.c
>> +++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
>> @@ -394,15 +394,23 @@ process_options (unsigned char *optbuf, int optbufSize)
>>            printf ("dhcpc: hostname >= %d bytes\n", MAXHOSTNAMELEN);
>>            len = MAXHOSTNAMELEN-1;
>> -        if (sethostname (p, len) < 0)
>> +        if (sethostname (p, len) < 0) {
>>            printf ("dhcpc: can't set host name");
>>          if (dhcp_hostname != NULL)
>> -          dhcp_hostname = realloc (dhcp_hostname, len);
>> -          strncpy (dhcp_hostname, p, len);
>> -        else
>> +          char *tmp = realloc (dhcp_hostname, len);
>> +          if (tmp != NULL) {
>> +            dhcp_hostname = tmp;
>> +            strncpy (dhcp_hostname, p, len);
>> +          } else {  /* realloc failed */
>> +            printf ("dhcpc: realloc failed (%s:%d)", __FILE__, __LINE__);
>> +            free (dhcp_hostname);
>> +            dhcp_hostname = NULL;
>> +        } else { /* dhcp_hostname == NULL */
>>            dhcp_hostname = strndup (p, len);
>>          break;
>>        case 7:
>> diff --git a/cpukit/posix/include/rtems/posix/ptimer.h b/cpukit/posix/include/rtems/posix/ptimer.h
>> index 7cc0516..16ac2b8 100644
>> --- a/cpukit/posix/include/rtems/posix/ptimer.h
>> +++ b/cpukit/posix/include/rtems/posix/ptimer.h
>> @@ -87,6 +87,9 @@ int timer_getoverrun(
>>    timer_t   timerid
>> +#ifdef __cplusplus
>> +#endif
>> -#endif
>> +#endif /* _RTEMS_POSIX_PTIMER_H */
>> diff --git a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
>> index 9fd2e6c..d2d7a4f 100644
>> --- a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
>> +++ b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
>> @@ -20,6 +20,10 @@
>>  #include <rtems/rtems/dpmem.h>
>>  #include <rtems/score/objectimpl.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>>   * @defgroup ClassicDPMEMImpl Dual Ported Memory Manager Implementation
>> @@ -104,5 +108,5 @@ RTEMS_INLINE_ROUTINE Dual_ported_memory_Control *_Dual_ported_memory_Get (
>>  #endif
>> -#endif
>> +#endif /* _RTEMS_RTEMS_DPMEM_INL */
>>  /* end of include file */
>> diff --git a/tools/cpu/nios2/memory.c b/tools/cpu/nios2/memory.c
>> index cd88b8b..cb1ea7f 100644
>> --- a/tools/cpu/nios2/memory.c
>> +++ b/tools/cpu/nios2/memory.c
>> @@ -18,7 +18,8 @@ memory_desc *find_memory(device_desc *devices)
>>    struct ptf *p;
>>    struct ptf_item pi;
>> -  memory_desc *tmd, *memory;
>> +  memory_desc *tmd;
>> +  memory_desc *memory = NULL;
>>    /* Check which of the devices are memory, sort by size */
>> @@ -29,8 +30,6 @@ memory_desc *find_memory(device_desc *devices)
>>      struct ptf_item pi;
>>      device_desc *dd;
>> -    memory = NULL;
>>      for(dd = devices; dd; dd=dd->next)
>>        p = ptf_find(dd->ptf->sub, &pi, item, "Is_Memory_Device", "1");
>> diff --git a/tools/cpu/nios2/ptf.c b/tools/cpu/nios2/ptf.c
>> index 7a31c11..07d6183 100644
>> --- a/tools/cpu/nios2/ptf.c
>> +++ b/tools/cpu/nios2/ptf.c
>> @@ -567,17 +567,21 @@ void ptf_printf(FILE *s, struct ptf *tree, char *prefix)
>>            new_prefix_len += strlen(leaf->value) + 1;
>>          new_prefix = (char *)malloc(new_prefix_len);
>> -        strcpy(new_prefix, prefix);
>> -        strcat(new_prefix, leaf->name);
>> -        if(leaf->value != NULL && leaf->value[0] != 0)
>> +        if (new_prefix != NULL)
>> -          strcat(new_prefix, ":");
>> -          strcat(new_prefix, leaf->value);
>> -        strcat(new_prefix, "/");
>> -        fputs(new_prefix, s);
>> -        fputs("\n", s);
>> -        ptf_printf(s, leaf->sub, new_prefix);
>> +          strcpy(new_prefix, prefix);
>> +          strcat(new_prefix, leaf->name);
>> +          if(leaf->value != NULL && leaf->value[0] != 0)
>> +            strcat(new_prefix, ":");
>> +            strcat(new_prefix, leaf->value);
>> +          strcat(new_prefix, "/");
>> +          fputs(new_prefix, s);
>> +          fputs("\n", s);
>> +          ptf_printf(s, leaf->sub, new_prefix);
>> +          free(new_prefix);
>>          break;
>> 2.5.1
