cppcheck errors
Gedare Bloom gedare at gwu.edu
Wed Sep 2 13:38:17 UTC 2015
On Tue, Sep 1, 2015 at 5:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 9/1/2015 2:10 PM, Martin Galvan wrote:
>> Hi everyone!
>> I just ran CppCheck again on a fresh clone of the git repo and saw the
>> number of error reports was quite smaller than what I reported before.
>> That's because my previous run was on a (quite older) version; most of
>> those must've been fixed already.
>> Some of the error reports remain, though. I opened a ticket for that
>> and will send a patch that fixes the issues Joel mentioned as worth
>> looking at. I'll open separate tickets for issues reported as
>> "warning" and "portability" (such as the void * thing), and send their
>> respective patches when they're done.
>> While working the fixes I noticed that the following error:
>> [cpukit/librpc/src/rpc/netnamer.c:331]: (error) Resource leak: fd
>> seems to be a false positive. getnetid will be stuck in an endless for
>> loop until it exits through one of the return statements; all of them
>> seem to have their corresponding fclose (if necessary).
> Great. This code did not originate from RTEMS. It is the original Sun
> RPC/XDR code. :)
>> I also noticed some new error reports. It would be nice if Joel (or
>> anyone else who knows the code base better than me) took a look at
>> these and pointed out which ones are third-party code:
>> [cpukit/libfs/src/dosfs/msdos_format.c:1105]: (error) Uninitialized
>> struct member: fmt_params.mbr_copy_sec
>> [cpukit/libfs/src/nfsclient/src/rpcio.c:1203]: (error) Uninitialized
>> variable: stat
>> [cpukit/libmisc/shell/print-ls.c:108]: (error) Invalid number of
>> character ({) when these macros are defined: 'RTEMS_REMOVED'.
> These are ours to fix.
>> [cpukit/libnetworking/libc/getifaddrs.c:251]: (error) Deallocation of
>> an auto-variable results in undefined behaviour.
>> [cpukit/libnetworking/libc/getifaddrs.c:256]: (error) Deallocation of
> This code originated in FreeBSD but it sounds interesting enough to look at.
>> [cpukit/libnetworking/net/radix.c:935]: (error) Uninitialized variable:
>> error
>> [cpukit/libnetworking/net/radix.c:977]: (error) Uninitialized variable:
>> error
>> [cpukit/libnetworking/netinet/in.c:647]: (error) Memory leak: inm
>> [cpukit/libnetworking/netinet/ip_fw.c:690]: (error) Memory leak: fwc
> FreeBSD code.
But, we are maintaining this for now as an in-tree fork of the
upstream. So feel free to fix anything in libnetworking.
>> [cpukit/mghttpd/mongoose.c:2811] -> [cpukit/mghttpd/mongoose.c:1221]:
>> (error) Mismatching allocation and deallocation: dir
>> [cpukit/mghttpd/mongoose.c:2852] -> [cpukit/mghttpd/mongoose.c:1221]:
> This code is from another project and we are trying to replace it but
> this looks odd enough to investigate and fix.
We also maintain this code base as an in-tree fork. So patches are
fine. We can no longer use the upstream due to re-licensing problem.
Gedare
