[PATCH v2 5/5] cpukit/libnetworking/rtems/rtems_dhcp.c: Fix leak on realloc failure for dhcp_hostname.
Martin Galvan martin.galvan at tallertechnologies.com
Wed Sep 2 21:54:25 UTC 2015
Closes #2405.
 cpukit/libnetworking/rtems/rtems_dhcp.c | 18 +++++++++++++-----
 1 file changed, 13 insertions(+), 5 deletions(-)
diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
index c938ee0..87be238 100644
--- a/cpukit/libnetworking/rtems/rtems_dhcp.c
+++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
@@ -394,15 +394,23 @@ process_options (unsigned char *optbuf, int optbufSize)
           printf ("dhcpc: hostname >= %d bytes\n", MAXHOSTNAMELEN);
           len = MAXHOSTNAMELEN-1;
-        if (sethostname (p, len) < 0)
+        if (sethostname (p, len) < 0) {
           printf ("dhcpc: can't set host name");
         if (dhcp_hostname != NULL)
-          dhcp_hostname = realloc (dhcp_hostname, len);
-          strncpy (dhcp_hostname, p, len);
-        else
+          char *tmp = realloc (dhcp_hostname, len);
+          if (tmp != NULL) {
+            dhcp_hostname = tmp;
+            strncpy (dhcp_hostname, p, len);
+          } else {  /* realloc failed */
+            printf ("dhcpc: realloc failed (%s:%d)", __FILE__, __LINE__);
+            free (dhcp_hostname);
+            dhcp_hostname = NULL;
+        } else { /* dhcp_hostname == NULL */
           dhcp_hostname = strndup (p, len);
         break;
       case 7:
2.5.1
