[PATCH] smp: Documentation
Thu Sep 3 15:09:43 UTC 2015
On Thu, Sep 3, 2015 at 8:46 AM, Sebastian Huber
>  doc/user/smp.t | 66 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 66 insertions(+)
> diff --git a/doc/user/smp.t b/doc/user/smp.t
> index 2ab9aaf..a06be8a 100644
> --- a/doc/user/smp.t
> +++ b/doc/user/smp.t
> @@ -465,6 +465,72 @@ architecture please consult the @cite{RTEMS CPU Architecture Supplement}.
>  The only remaining user of task variables in the RTEMS code base is the Ada
>  support.  So basically Ada is not available on RTEMS SMP.
> + at subsection OpenMP
> +OpenMP support for RTEMS is available via the GCC provided libgomp.  There is
> +libgomp support for RTEMS in the POSIX configuration since GCC 4.9 (requires a
> +Newlib snapshot after 2015-03-12). In GCC 6.1 or later (requires a Newlib
> +snapshot after 2015-07-30 for <sys/lock.h> provided self-contained
Do these versions relate to any release versions of RTEMS, e.g. did
this stuff make it into the toolchains for 4.11? Translating between
gcc/newlib versions and RTEMS versions is a bit of work for casual
user to know if this support will be available or not for them.
> +synchronization objects) there is RTEMS support in a RTEMS specific
hyphenate: "RTEMS-specific" here and below.
> +configuration which offers a significantly better performance compared to the
"libgomp configuration"
> +POSIX configuration (the term configuration refers here to the libgomp
> +configuration and should not be confused with the POSIX API provided by RTEMS).
> +In addition scheduler instance specific thread pools may be defined.
Last sentence doesn't say why that matters. Perhaps just say something
about discussing this further below.
> +The run-time configuration of libgomp is done via environment variables
> +documented in the @uref{https://gcc.gnu.org/onlinedocs/libgomp/, libgomp
> +manual}.  The environment variables are evaluated in a constructor function
> +which executes in the context of the first initialization task before the
> +actual initialization task function is called (just like a global C++
> +constructor).  To set application specific values, a higher priority
hyphenate: "application-specific"
> +constructor function must be used to set up the environment variables.
> + at example
> + at group
> +#include <stdlib.h>
> +static void __attribute__((constructor(1000))) config_libgomp( void )
> +  setenv( "OMP_DISPLAY_ENV", "VERBOSE", 1 );
> +  setenv( "GOMP_SPINCOUNT", "30000", 1 );
> +  setenv( "GOMP_RTEMS_THREAD_POOLS", "1$2@@SCHD", 1 );
> + at end group
> + at end example
The following discussion may warrant it's own subsection on Thread Pools.
> +The environment variable @env{GOMP_RTEMS_THREAD_POOLS} is RTEMS specific.  It
> +determines the scheduler instance specific thread pools.  The format for
hyphenate: "instance-specific"
> + at env{GOMP_RTEMS_THREAD_POOLS} is a list of optional
> + at code{<thread-pool-count>[$<priority>]@@<scheduler-name>} configurations
> +separated by @code{:} where:
> + at itemize @bullet
> + at item @code{<thread-pool-count>} is the thread pool count for this scheduler
> +instance.
> + at item @code{$<priority>} is an optional priority for the worker threads of a
> +thread pool according to @code{pthread_setschedparam}.  In case a priority
> +value is omitted, then a worker thread will inherit the priority of the OpenMP
> +master thread that created it.  The priority of the worker thread is not
> +changed after creation, even if a new OpenMP master thread using the worker has
This statement "priority of the worker thread is not changed after
creation" probably is not accurate, in case of PIP/PCP or API calls to
change priority. It might be better to state that the priority is not
changed despite a change in the master thread?
> +a different priority.
> + at item @code{@@<scheduler-name>} is the scheduler instance name according to the
> +RTEMS application configuration.
> + at end itemize
> +In case no thread pool configuration is specified for a scheduler instance,
> +then each OpenMP master thread of this scheduler instance will use its own
> +dynamically allocated thread pool.  To limit the worker thread count of the
> +thread pools, each OpenMP master thread must call @code{omp_set_num_threads}.
> +Lets suppose we have three scheduler instances @code{IO}, @code{WRK0}, and
> + at code{WRK1} with @env{GOMP_RTEMS_THREAD_POOLS} set to
> + at code{"1@@WRK0:3$4@@WRK1"}.  Then there are no thread pool restrictions for
> +scheduler instance @code{IO}.  In the scheduler instance @code{WRK0} there is
> +one thread pool available.  Since no priority is specified for this scheduler
> +instance, the worker thread inherits the priority of the OpenMP master thread
> +that created it.  In the scheduler instance @code{WRK1} there are three thread
> +pools available and their worker threads run at priority four.
>  @subsection Thread Dispatch Details
>  This section gives background information to developers interested in the
> 1.8.4.5
> devel mailing list
> devel at rtems.org
