[PATCH] RTEMS CAN Rough Draft Implementation
Thu Sep 3 15:23:02 UTC 2015
This is on my list but I'm back-logged. Hopefully someone else can
check through it, preferably someone who is knowledgeable about CAN.
On Thu, Aug 27, 2015 at 2:45 PM, Isaac Gutekunst
<isaac.gutekunst at vecna.com> wrote:
> Hi All,
> Here is the RTEMS CAN driver framework I've been talking about. Please give
> me feedback, and don't worry about being harsh. I want to commit something
> of value.
> Concerns
> * Usage of return codes.
> * General higher level error handling.
> * Changing can bit rate.
> * In general, changing CAN parameters at runtime.
> * Task model: Should there really be an RX and TX task required by the RTEMS
> driver? Is the method of starting and stopping tasks acceptable?
> The motivation for this is that the CAN controller we are using, (STM32
> BxCAN) requires you to re-initialize the device to change parameters. This
> is a bit awkward with first calling open, and then IOCTL to configure the
> bus. Any thoughts?
> Thanks,
> Isaac
> P.S. I'm having trouble with git send-email. Something is not quite right
> with our mail server here. I've attached the patch instead.
> Isaac Gutekunst
> Embedded Systems Software Engineer
> www.vecna.com
> devel mailing list
> devel at rtems.org
