[PATCH v2 4/5] cpukit/libmisc/dumpbuf/dumpbuf.c: Fix undefined behavior for sprintf()
Thu Sep 3 16:21:27 UTC 2015
On 9/2/2015 4:54 PM, Martin Galvan wrote:
> I also used the 'n' versions of the string functions, #define'd magic numbers
> and added a few comments.
Great on the 'n' versions!
One comment. Why is the output buffer now static? I know it
moves it off the stack but what's the consensus on an 80
byte array on a stack?
> Updates #2405.
>   cpukit/libmisc/dumpbuf/dumpbuf.c | 121 ++++++++++++++++++++++++---------------
>   1 file changed, 75 insertions(+), 46 deletions(-)
> diff --git a/cpukit/libmisc/dumpbuf/dumpbuf.c b/cpukit/libmisc/dumpbuf/dumpbuf.c
> index 9d34d42..bb63997 100644
> --- a/cpukit/libmisc/dumpbuf/dumpbuf.c
> +++ b/cpukit/libmisc/dumpbuf/dumpbuf.c
> @@ -6,7 +6,7 @@
> - *  COPYRIGHT (c) 1997-2007.
> + *  COPYRIGHT (c) 1997-2015.
>    *  On-Line Applications Research Corporation (OAR).
>    *  The license and distribution terms for this file may in
> @@ -24,62 +24,91 @@
>   #include <rtems/dumpbuf.h>
>   #include <rtems/bspIo.h>
> +#define HEX_FMT_LENGTH 3   /* Length of the formatted hex string. */
> +#define ASCII_FMT_LENGTH 1 /* Length of the formatted ASCII string. */
> +#define BYTES_PER_ROW 16    /* Amount of bytes from buffer shown in each row. */
> +#define BARS 2             /* Amount of bars in each row. */
> +/* Max length of each row string. */
> +#define ROW_LENGTH (BYTES_PER_ROW * (HEX_FMT_LENGTH + ASCII_FMT_LENGTH) + BARS)
>    *  Put the body below rtems_print_buffer so it won't get inlined.
> -static inline void Dump_Line(
> -  const unsigned char *buffer,
> -  int                  length
> +static void Dump_Line(const unsigned char *buffer, const unsigned int length);
> -void rtems_print_buffer(
> -  int                  length
> + * @brief Print \p length bytes from \p buffer, both in hex and ASCII.
> + * Printing will be done in rows, each showing BYTES_PER_ROW bytes.
> + * @details Non-printable chars will appear as dots.
> + * @param buffer The buffer we'll print.
> + * @param length Amount of bytes from \p buffer we'll print. This can't be
> + * unsigned because we don't have a way to check if we're erroneously getting
> + * a negative \p length.
> +void rtems_print_buffer(const unsigned char *buffer, const int length)
> +  unsigned int i, mod, max;
> -  int i, mod, max;
> -  if ( !length ) return;
> +  if (length > 0) {
> +    mod = length % BYTES_PER_ROW;
> -  mod = length % 16;
> +    max = length - mod;
> -  max = length - mod;
> +    /* Print length / BYTES_PER_ROW rows. */
> +    for (i = 0; i < max; i += BYTES_PER_ROW) {
> +      Dump_Line(&buffer[i], BYTES_PER_ROW);
> -  for ( i=0 ; i<max ; i+=16 )
> -    Dump_Line( &buffer[ i ], 16 );
> -  if ( mod )
> -    Dump_Line( &buffer[ max ], mod );
> +    /* Print another row with the remaining bytes. */
> +    if (mod > 0) {
> +      Dump_Line(&buffer[max], mod);
> +  } else {
> +    printk("Error: length must be greater than zero.");
> -  int                  length
> -  int  i;
> -  char line_buffer[120];
> -  line_buffer[0] = '\0';
> -  for( i=0 ; i<length ; i++ )
> -    sprintf( line_buffer, "%s%02x ", line_buffer, buffer[ i ] );
> -  for( ; i<16 ; i++ )
> -    strcat( line_buffer, "   " );
> -  strcat( line_buffer, "|" );
> -    sprintf( line_buffer, "%s%c", line_buffer,
> -             isprint( buffer[ i ] ) ? buffer[ i ] : '.' );
> -  strcat( line_buffer, "|\n" );
> -  printk( line_buffer );
> +  unsigned int i;
> +  static unsigned char line_buffer[ROW_LENGTH] = "";
> +  size_t tmp_len;
> +  /* Output the hex value of each byte. */
> +  for (i = 0; i < length; ++i) {
> +    snprintf(&line_buffer[i * HEX_FMT_LENGTH], HEX_FMT_LENGTH + 1,
> +             "%02x ", buffer[i]);
> +  /* Fill the remaining space with whitespace (if necessary). */
> +  for (; i < BYTES_PER_ROW; ++i) {
> +    strncat(line_buffer, "   ", HEX_FMT_LENGTH);
> +  /* Append a bar. */
> +  strncat(line_buffer, "|", 1);
> +  tmp_len = strnlen(line_buffer, ROW_LENGTH);
> +  /* Now output the ASCII glyphs of printable chars. */
> +    snprintf(&line_buffer[tmp_len + i], ASCII_FMT_LENGTH + 1,
> +             "%c", isprint(buffer[i]) ? buffer[i] : '.');
> +  for(; i < BYTES_PER_ROW; i++) {
> +    strncat(line_buffer, " ", ASCII_FMT_LENGTH);
> +  /* Append another bar and print the resulting string. */
> +  printk("%s|\n", line_buffer);
