[wwwdocs] GCC 6 Release Notes for RTEMS
    Sebastian Huber
    Fri Sep  4 06:26:53 UTC 2015
Index: htdocs/gcc-6/changes.html
RCS file: /cvs/gcc/wwwdocs/htdocs/gcc-6/changes.html,v
retrieving revision 1.25
diff -u -r1.25 changes.html
--- htdocs/gcc-6/changes.html   25 Aug 2015 22:27:46 -0000      1.25
+++ htdocs/gcc-6/changes.html   4 Sep 2015 06:21:14 -0000
@@ -203,6 +203,23 @@
  <!-- <h3 id="freebsd">FreeBSD</h3> -->
+<!-- <h3 id="rtems">RTEMS</h3> -->
+  <ul>
+    <li>The RTEMS thread model implementation changed.  For the mutexes
+    self-contained objects defined in Newlib <sys/lock.h> are used
+    instead of Classic API semaphores.  The keys for thread specific
data and
+    the once function are directly defined via <pthread.h>.
+    Self-contained condition variables are provided via Newlib
+    <sys/lock.h>.  The RTEMS thread model supports now the C++11
+    threads.</li>
+    <li>The OpenMP support uses now self-contained objects provided by
Newlib
+    <sys/lock.h> and offers a significantly better performance
compared
+    to the POSIX configuration of <code>libgomp</code>.  It is possible to
+    configure thread pools for each scheduler instance via the environment
+    variable <code>GOMP_RTEMS_THREAD_POOLS</code>.</li>
+  </ul>
  <!-- <h3 id="vxmils">VxWorks MILS</h3> -->
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
