PCI CAN interface emulation updated for QEMU 2.4
Pavel Pisa
pisa at cmp.felk.cvut.cz
Mon Sep 7 23:51:38 UTC 2015
Hello everybody,
the project implements simple CAN SJA1000 interface emulation
with option to connect emulated CAN buses to host system
SocketCAN bus. Project has been started by Jin Yang in frame
of RTEMS provided GSoC 2013 slot.
Code has been cleaned and is maintained to be up-to
date with actual QEMU releases. I would be happy to
follow suggestions and review for its possible
mainlining if there is interrest. If preferred,
I send patches inline to QEMU list.
Code is available from
https://github.com/CTU-IIG/qemu/tree/can-pci
The "can-pci" branch has been updated for QEMU-2.4 now.
The previous 2.3 support moved on "can-pci-2.3" branch.
Older support and support for PCI MF624 data acquisition
card can be found on merged branches merged-2.1,
merged-2.3 and merged-2.4.
Documentation
https://rtime.felk.cvut.cz/can/can-qemu/
https://devel.rtems.org/wiki/Developer/Simulators/QEMU/CANEmulation
Relevant commits
commit 2d873a9ed3bcb8301a247f36b77227b1cd9211c0
Author: Pavel Pisa <pisa at cmp.felk.cvut.cz>
Date: Mon Sep 7 15:24:56 2015 +0200
CAN bus simple SJA1000 PCI card emulation for QEMU
The work is based on Jin Yang GSoC 2013 work funded
by Google and mentored in frame of RTEMS project GSoC
slot donated to QEMU.
Rewritten for QEMU-2.0+ versions and architecture cleanup
by Pavel Pisa (Czech Technical University in Prague).
The core SJA1000 support is independent of provided
PCI board. The simple core CAN bus infrastructure
is independent as well.
Connection to the real host CAN bus network through
SocketCAN network interface is available for Linux
host system as well.
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
commit 3eda61e54b947f1508a05f8b67277dd717a8c963
Date: Mon Sep 7 15:27:08 2015 +0200
CAN bus Kvaser PCI CAN-S (single SJA1000 channel) emulation added.
Best wishes,
Pavel Pisa
