[PATCH v2] untar: do not exit with error when created directory already exists (fixes #2413).
Pavel Pisa pisa at cmp.felk.cvut.cz
Wed Sep 9 22:09:17 UTC 2015
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
 cpukit/libfs/src/imfs/imfs_load_tar.c | 12 +++++++++++-
 cpukit/libmisc/untar/untar.c          | 18 +++++++++++++++++-
 2 files changed, 28 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index 7228978..2d4ca6b 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -103,8 +103,18 @@ int rtems_tarfs_load(
         strcat(full_filename, "/");
       ++len;
       strncat(full_filename, filename, 256-len-1);
-      rv = mkdir(full_filename, S_IRWXU | S_IRWXG | S_IRWXO);
+      if ( mkdir(full_filename, S_IRWXU | S_IRWXG | S_IRWXO) != 0 ) {
+        if (errno == EEXIST) {
+          struct stat stat_buf;
+          if ( stat(full_filename, &stat_buf) == 0 ) {
+            if (  S_ISDIR(stat_buf.st_mode) )
+              continue;
+        rv = -1;
      * Create a LINEAR_FILE node
diff --git a/cpukit/libmisc/untar/untar.c b/cpukit/libmisc/untar/untar.c
index aed8fed..2c1e304 100644
--- a/cpukit/libmisc/untar/untar.c
+++ b/cpukit/libmisc/untar/untar.c
@@ -28,6 +28,7 @@
 #include <unistd.h>
+#include <errno.h>
 #include <sys/stat.h>
 #include <fcntl.h>
 #include <rtems/untar.h>
@@ -203,6 +204,13 @@ Untar_FromMemory(
     } else if (linkflag == DIRTYPE) {
       if ( mkdir(fname, S_IRWXU | S_IRWXG | S_IRWXO) != 0 ) {
+          if ( stat(fname, &stat_buf) == 0 ) {
+              continue;
         printk("Untar: failed to create directory %s\n", fname);
         retval = UNTAR_FAIL;
         break;
@@ -319,7 +327,15 @@ Untar_FromFile(
         close(out_fd);
-      (void) mkdir(fname, S_IRWXU | S_IRWXG | S_IRWXO);
+      if ( mkdir(fname, S_IRWXU | S_IRWXG | S_IRWXO) != 0 ) {
+              continue;
   free(bufr);
1.9.1
