[PATCH] Beaglebone: fix missing clobber in inline assembly.
Marcos Diaz marcos.diaz at tallertechnologies.com
Thu Sep 10 15:20:41 UTC 2015
flush_data_cache uses R0 directly but doesn't list it as a clobbered register.
Compiling with -O3 made this code break, since the function that calls flush_data_cache
already uses r0.
 c/src/lib/libbsp/arm/beagle/include/bsp.h | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/beagle/include/bsp.h b/c/src/lib/libbsp/arm/beagle/include/bsp.h
index 0250749..d9fd2ae 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bsp.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
@@ -112,7 +112,13 @@ static inline void isb(void)
 /* flush data cache */
 static inline void flush_data_cache(void)
-    asm volatile("mov r0, #0; mcr p15, #0, r0, c7, c10, #4" : : : "memory");
+    asm volatile(
+        "mov r0, #0\n"
+        "mcr p15, #0, r0, c7, c10, #4\n"
+        : /* No outputs */
+        : /* No inputs */
+        : "r0","memory"
 #define __arch_getb(a)      (*(volatile unsigned char *)(a))
1.9.1
