rtems_set_errno_and_return_minus_one in driver not returning correct value
Fri Sep 11 08:18:21 UTC 2015
On 11/09/15 10:10, Inderjit Singh wrote:
> Can I presume that using errno with RTEMS does not work? To me I'm
> baffled that a RTEMS_SUCCESSFULL value must be returned in order to
> retain the errno value.
The standard drivers are quite primitive. You may have a look at IMFS
generic nodes, if you want more control:
https://docs.rtems.org/doxygen/cpukit/html/group__IMFSGenericNodes.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
