rtems_set_errno_and_return_minus_one in driver not returning correct value
Fri Sep 11 11:34:16 UTC 2015
On 11/09/15 13:28, Inderjit Singh wrote:
> So basically you're saying is that i cannot use errno when using the primitve driver standard driver but use IMFS instead if I want to retain an errno value set in driver and that is recieved by the app.
Yes, if you are unlucky with what rtems_status_code_to_errno() does for you.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
