[PATCH] [RTEMS] Update RTEMS thread model
Fri Sep 18 08:24:52 UTC 2015
On 17/09/15 16:36, Aurelio Remonda wrote:
>> It is printing the "real time" but the time is set to a date early
>> >in the RTEMS development history. Look at the year. That's about the
>> >time the test was initially written.
>> >It is likely running faster than "real time" because it is a simulator.
>> >The numbers not ending in "5" is a bit unusual. The test consists of
>> >four tasks:
>> >+ one runs every 5 seconds
>> >+ one every 10
>> >+ one every 15
>> >+ IDLE
>> >It exits when one notices it has gone over 30 seconds.
> Thank you Joel! I have another question if you don't mind: where i can find the realview_pbx_a9_qemu.exp file?
> I can't find it in dejagnu/boards.
Sorry, I check this file in.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
