[PATCH] Update RTEMS multilib for SPARC
Daniel Hellstrom daniel at gaisler.com
Mon Sep 28 12:13:07 UTC 2015
Now that muser-mode is default the multilib definitions does not require to
specify that switch any more. Add UT699 to multilib after recent patches. Add
AT697F multilib since there are many LEON2 users running RTEMS.
To gcc/ChangeLog:
gcc/
	* config/sparc/t-rtems: Remove -muser-mode, add ut699 and at697f
 gcc/config/sparc/t-rtems |   25 +++++++++++++++----------
 1 files changed, 15 insertions(+), 10 deletions(-)
diff --git a/gcc/config/sparc/t-rtems b/gcc/config/sparc/t-rtems
index adb6dcb..6f7cc6f 100644
--- a/gcc/config/sparc/t-rtems
+++ b/gcc/config/sparc/t-rtems
@@ -17,15 +17,20 @@
 # <http://www.gnu.org/licenses/>.
-MULTILIB_OPTIONS = msoft-float mcpu=v8/mcpu=leon3/mcpu=leon3v7 muser-mode
-MULTILIB_DIRNAMES = soft v8 leon3 leon3v7 user-mode
+MULTILIB_OPTIONS = msoft-float mcpu=v8/mcpu=leon3/mcpu=leon3v7/mcpu=leon \
+		   mfix-ut699/mfix-at697f
+MULTILIB_DIRNAMES = soft v8 leon3 leon3v7 leon ut699 at697f
 MULTILIB_MATCHES = msoft-float=mno-fpu
-MULTILIB_EXCEPTIONS = muser-mode
-MULTILIB_EXCEPTIONS += mcpu=leon3
-MULTILIB_EXCEPTIONS += mcpu=leon3v7
-MULTILIB_EXCEPTIONS += msoft-float/mcpu=leon3
-MULTILIB_EXCEPTIONS += msoft-float/mcpu=leon3v7
-MULTILIB_EXCEPTIONS += msoft-float/muser-mode
-MULTILIB_EXCEPTIONS += msoft-float/mcpu=v8/muser-mode
-MULTILIB_EXCEPTIONS += mcpu=v8/muser-mode
+MULTILIB_EXCEPTIONS = mfix-ut699
+MULTILIB_EXCEPTIONS += msoft-float/mfix-ut699
+MULTILIB_EXCEPTIONS += msoft-float/mcpu=v8/mfix-ut699
+MULTILIB_EXCEPTIONS += msoft-float/mcpu=leon3*/mfix-ut699
+MULTILIB_EXCEPTIONS += mcpu=v8/mfix-ut699
+MULTILIB_EXCEPTIONS += mcpu=leon3*/mfix-ut699
+MULTILIB_EXCEPTIONS += mfix-at697f
+MULTILIB_EXCEPTIONS += msoft-float/mfix-at697f
+MULTILIB_EXCEPTIONS += msoft-float/mcpu=v8/mfix-at697f
+MULTILIB_EXCEPTIONS += msoft-float/mcpu=leon3*/mfix-at697f
+MULTILIB_EXCEPTIONS += mcpu=v8/mfix-at697f
+MULTILIB_EXCEPTIONS += mcpu=leon3*/mfix-at697f
1.7.0.4
