[PATCH] cpukit/libnetworking/rtems/rtems_dhcp.c: Fix compilation error
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Thu Sep  3 20:44:49 UTC 2015
Should be committed now.
I guess one of us should have compiled it. :)
--joel
On 9/3/2015 3:25 PM, Martin Galvan wrote:
> Apparently 'free' is defined as a macro which takes two arguments and calls
> rtems_bsdnet_free. When fixing #2405 I added a missing 'free' but didn't notice
> it was non-standard.
> Closes #2410.
>   cpukit/libnetworking/rtems/rtems_dhcp.c | 2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
> index 87be238..cb6966d 100644
> --- a/cpukit/libnetworking/rtems/rtems_dhcp.c
> +++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
> @@ -405,7 +405,7 @@ process_options (unsigned char *optbuf, int optbufSize)
>               strncpy (dhcp_hostname, p, len);
>             } else {  /* realloc failed */
>               printf ("dhcpc: realloc failed (%s:%d)", __FILE__, __LINE__);
> -            free (dhcp_hostname);
> +            free (dhcp_hostname, 0);
>               dhcp_hostname = NULL;
>           } else { /* dhcp_hostname == NULL */
