Memory protection on RTEMS?
    Peter Dufault
    dufault at hda.com
    Thu Sep 10 07:37:35 UTC 2015
> On Sep 9, 2015, at 19:02 , Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> As Sebastian mentioned if you make the task stack accessible by only
> a single stack, you have to be careful not to pass pointers to objects
> on the stack into paths where they will be used by another task.
I’ve worked on multi-processor systems with this attribute and I think it’s a good option, stack was private and “cheap” in terms of overhead on a processor.  If you use shared memory semantics you'll have portable code that works on multi-process (process, not processor) systems, it requires a little more design formalism up front.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
